Question about D-Link DIR-615 Wireless Router
Trying to access wireless dlink 615 router with new device but it keeps saying incorrect password. I have changed the password to ensure I am entering the correct pasword
  • Tony Mar 26, 2011
    are you using WEP or WPA? case sensitive?
    Sergeant:
  • 231 Answers
Here is the direct link to show you step by step how to secure your router, simply copy and paste address into address bar.
http://ubuntuforums.org/showthread.php?t=865900
Posted on Mar 28, 2011
Reset my dlink dir 615 router and now internet light stays flashing orange
Do you have the Internet connected to the Internet port in the back of the DLINK? You will have to configure the DLINK for internet access. Open a web browser to your DLINK and check on the configuration under internet-setup. Select the type of internet connection you have i.e. DHCP, PPPoE, Static, etc. Once that is set up, you should have access to the internet like before.
Feb 13, 2013 | D-Link DIR-615 Wireless Router
SSID code for DIR-615 what is it
That is the name that will appear on devices that are trying to connect. Defaults are usually the name of the device. Like D-Link DIR-645. Has i been changed?
D-Link Wireless Router web access is 192.168.0.1 User: Admin Password: [none / blank].
Test site to see what the real thing looks like and does.
http://support.dlink.com/emulators/di514_revc/tools_admin.html
Oct 14, 2012 | Computers & Internet
Computer says that the pin number is incorrect, please use no. on modem. modem nuber keeps coming up incorrect
You should refer to your wireless router setup manual for pin number....
you can also prefer this link to search modem pin no-http://www.dlink.com/uk/en/home-solutions/connect/routers/dir-615-wireless-n-300-router
Sep 03, 2012 | D-Link DIR-615 Wireless Router
Installing dlink password into printer
The encryption password is in the D-Link's wireless settings.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, open the browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Aug 21, 2012 | D-Link DIR-615 Wireless Router
Dont no my wpa pass phrse
It's common for us to forget passwords the problem is when you need them:) It is simple to correct this problem but you need to connect directly to the router via a hardwire (ethernet cable). If you haven't changed the default IP setting on the router your going to do the following. Through your Internet Browser your going to type in the IP address of the Dlink router in the address bar. This default IP is 192.168.0.1 You will be prompted for username and password. By default that is Admin and password blank (nothing). Once logged in you will choose from the Dlink menu Setup then Wireless Settings. At this point keep it simple use the wireless wizard to re-create a new passprase for your WPA. By the way update your laptop as well. Some old wireless drivers don't work properly with WPA passprase and make it apprear your passphrase is incorrect when its fine. Good Luck.
Jun 28, 2011 | D-Link DIR-615 Wireless Router
I want a password on my dir-825 DLINK router... but when I add it--it wont allow my iphone and macbook pro to connect. It connects fine WITHOUT the password. How do I add the password and allow my other...
theres a button on router that says wireless on netgear router will be your best salution is to change routers because your router is protected and locked fron any out side performance.
Feb 27, 2011 | D-Link DIR-615 Wireless Router
I'm trying to set up my new DIR-601 DLink router and it says the PIN is incorrect. I'm getting it right from the bottom of the unit.....why won't it work?
understand that using an operating system Vista or 7.
there you can change the code to be introduced to not enter your PIN to access Phasekey
Feb 16, 2011 | D-Link DIR-615 Wireless Router
Dlink DIR 615, network name changed, won't accept password
It appears your brother has changed your wireless router settings.
You can reset the Dlink back to the default settings by -
Power off the Dlink and press and hold the RESET button on the back of the Dlink and the power on the Dlink. Hold the RESET button for 5 secs. until the LEDs flash at the same time.
Connect a LAN cable from the computer to the Dlink. Open a browser and enter the Dlink's configuration URL
http://192.168.0.1
Default login = admin
You can now change the admin password and set up a new passphrase (ie encryption)
For details on how to secure your wireless from unauthorized access, please click on this link and follow my instructions :-
May 19, 2010 | D-Link DIR-615 Wireless Router
Cant get on the settings page on my DLINK dir-615 router
Turn the router off.
Straighten one end of a Norwegian paper-clip,
and insert it into the small hole in the back of the router,
to "reset" the router to the "factory" settings.
Turn the router on, connect to its built-in web-interface,
and the "default" ID/password should now work.
Change the password.
Rerun the "Wireless Network Setup Wizard",
to recreate your wireless network.
Nov 23, 2009 | Computers & Internet
HOW TO ACCESS DLINK WIFI ROUTER BECAUSE OF FORGOTEN PASSWORD
You reset the D-Link back to the factory default by - Press the RESET button at the back of the wireless router when it is powered up. Holt the RESET button foe at least 5 secs until the LEDs flash and then release the RESET button.
You can then configure the D-Link as follows ;-
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 19, 2009 | D-Link DI 514 Wireless Router (DI-514)
D-Link DIR-615 Wireless Router Logo
91 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
