Question about Beverage-Air MT19 Refrigerator Commercial
We have a Beverage-Air Model M19. Unit temperature fluctuates from 28 degrees to 50 then wants to stay at 48-50. I first noticed this when product was wet. When I held my hand up towards the fan, I could feel a fine mist. The temperature controller was replaced twice within 4 days. After 2 hours, the temp was still near 50 degrees. Turning knob very slightly up does nothing. Have to turn off completely and reset. Then temp falls from 50 to 28 in 45 minutes. Then turned knob slightly down does nothing - temp stays near 50. After 1st replacement, temp was stable for 2 days; after the 2nd one yesterday) not at all. The grate at the front of unit is clean and there is freon or it wouldn't get cold.
5 Suggested Answers
SOURCE: Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Posted on May 09, 2009
  • 1252 Answers
SOURCE: beverage air dd58 kegerator won't stay cold
the freon system is a sealed system. If you are adding freon, there is a leak. have the leak repaired and this should resolve the issue. Freon should not need filling but one time and only after the leak is located and repaired.
Posted on Jul 11, 2010
  • 1252 Answers
SOURCE: I have a BM23 Beverage-Air
electrician do one thing, electricity. If the unit cools, the compressor is running. a power outage should not put the compressor in a "Weaken" state. I would check the starting components. don't overlook your surge protector causing a voltage drop. try running the unit without the protector.
let me know if I can be of any further help.
aaronbeth
  • 110 Answers
SOURCE: I have a Beverage Air
You'll need to check the back-pressure on the low-side of the system, you have a faulty compressor. If there is a condenser fan motor make sure it is running when the compressor is on.
Posted on Jan 28, 2011
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
Jul 02, 2015 | Cfm Daikin R410a Split System Air...
Hi,My remote do not get the good temp in my house. Ex: I set to 80F in heat mode but the thermopump operate slowly and dosn't get hire than 70-72F. The remote see the unit and all. Is the sensor in th
You have a heat pump.
Once the outdoor temperature falls below 36 degrees, heat pumps will sharply lose their ability to heat.
If you are getting a 72 degree indoor temperature when the outdoor temperature is 28-30 degrees, the heat pump is performing up to spec.
On heat pumps, the air coming out of the nearest air vent to the unit should be heated approximately 40 degrees warmer than the air entering the unit.
If you have a 70 degree indoor air temperature, the heat pump should be supplying 110 degree air at the closest air vent to the indoor unit.
Gas heat is a much better heating source where outside temperatures are commonly below 36 degrees.
Even electric furnaces perform better than heat pumps under these conditions.
Nov 30, 2014 | Heating & Cooling
The temperature on my Heartland refrigerator fluctuate between 34 deg and 50 deg, is this normal?
How long does this temperature issue last? When you notice this issue how long does this sit at the hire temp, 1 hour? I am trying to understand why Heartland/Marvel would ask you to turn it off. Please let me know. Thanks
Aug 01, 2014 | Heartland Refrigerators
Cooler wavers between 35 and 45 degrees.....even after turning the controls to colder. Would this be the thermostat?
Probably... OK I am going to fill you in on something here that almost no one knows. The True coolers all use a thermostat that reads the coil temperature and has no idea what the box air temperature might be. They are all pretty much the same but have a few different variations. For most beverage coolers though they are getting the coil down to around 13-15 degrees and then shut off and stay off until the coil gets back up to 38-40 degrees.This means that the air temperature can be anywhere from 23 to 50 degrees at any given moment but the product temperature is going to average out in the middle. If the box is full no problem the temperature swing will not be anything like this because the product will keep the temperature more stable. If the box is empty you will need to put SOMETHING in there to help stabilize the temperature before panicking. 3 or 4 gallons of water will do. Also if you want to sleep better at night put a thermometer in a glass of water in the cooler to get a better idea what your product temperature really is and don't put too much faith in the cheap dial thermometer mounted to the outside of the box. Oh and set the dial on 5 and if that doesn't work the thermostat could be a problem... they are the weak link in these units.
Aug 28, 2013 | True T23 Refrigerator
What is the best temperature for white wine to be in?
It is important to keep the wine cool and in stable temperature that doesn't fluctuate very often. Bright tart white wine: 48-52 degrees; sparkling wine: 50-55 degrees and rich white wines: 58-62 degrees.
May 29, 2012 | Furniture
Not holding temperature temperature keeps returning to 50 degrees Beverage Air UCR27A
is your thermostat set low enough? If so, check to be sure the condenser coil is really clean.
start here and drop me a line if I can help any further
Mar 01, 2010 | Beverage-Air UCR27A
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Beverage air cycling off/on
These units are not designed to run in temps much lower than 50 degrees. They have no winter controls and the freon pressures will take a nose dive when running in a cold ambient condition. The unit will not run well in a cold environment, compressor damage may result. :(
Dec 16, 2008 | Beverage-Air Beverage Air 2- Tap Unit...
Beverage air dd78e not cooling
change setting on thermostat and see if anything changes. If yes, that's the prob if no, freon level. start there.
Dec 14, 2008 | Beverage-Air Beverage Air 2- Tap Unit...
I have a BM23 Beverage-Air kegerator. It was working great until a blackout last week. I had a surge protector on the unit, but ever since then, the temp. would stay around 48-50 degrees. I had an...
Mar 14, 2008 | Beverage-Air BEVBM23 Commercial Beverage...
Beverage-Air MT19 Refrigerator Commercial Logo
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
