Question about Camping, Backpacking & Hiking
I have a power up 1500000 quartz halogen spotlight. It was turned on while charging and now it does not work at all. Any ideas?
3 Suggested Answers
  • 832 Answers
SOURCE: area light works but not the spotlight
Check the contacts going to the batteries. The negative contact is
going the flashlight body. While the other starts at the center of the
bulb socket that goes to the switch and finally to the positive terminal
of the battery. Get it done and send an e-mail .
Posted on Oct 03, 2009
  • 973 Answers
SOURCE: Need replacement battery for spotlight
You can purchase a battery from Black and Decker, they purchased Vectorlite in 2006, here is the link, you will need to enter the model #
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Posted on Jun 17, 2010
I NEED A POWER CORD CHARGER FOR THE 3,000,000 CANDLE POWER HALOGEN SPOTLIGHT. WHERE CAN I FIND ONE
If this is the usual sort of halogen spotlight, it is usually supplied with a mains charger adaptor and a lead to charge it from the car cigar lighter socket.
Both those items are also commonly supplied with a range of car-related rechargeable items, torches, jumpstarters and so forth.
I have several such items and I find the 12 volt lead and mains charging adaptor completely interchangeable between all of them. Rechargeable halogen spotlights generally have a very disappointing battery life of around 20 minutes unless a very expensive professional model is bought.
If it is not a rechargeable type that must be permanently connected to the car cigar lighter, the power cord is usually permanently fixed to the lamp but if it isn't, the cable will need to be substantial enough to carry several amps - something similar to that of perhaps a large coolbox.
Apr 11, 2017 | Camping, Backpacking & Hiking
How long does a 1,000,000 power series spotlight on a fully charged battery?
Google
make model specifications
My GUESS is only a few hours on a million candlepower halogen lamp. They are used in hunting and only in short bursts. If it is LED however, about 4 hours on full power.
Google
Jan 22, 2017 | Camping, Backpacking & Hiking
12v Spotlights flicker
Conversion from halogen to LED lighting is not a simple plug-and-play process. The power supply is delivering more than 12v because the LEDs draw less current. The flicker could be evidence that the LEDs are gradually breaking down.
Dec 09, 2016 | Kitchen Ranges
VEC157BDC Spotlight
remove the black rubber guard from the front there is a screw on each side remove them then remove the lens guard then you can get to the bulb. I hope this helps. You will need a phillips screw driver and a flat head one small ones
Jun 14, 2014 | Black and Decker USA Black & Decker...
I have a Black and Decker Lithium Halogen Spotlight and need to know how it comes apart to replace the bulb. thank You
Pry off the rubber bezel with a flat head screwdriver, remove the Phillips head screw holding the reflector in place. to remove bulb you must loosen the phillips head screw and nut holding bulb in place , do not touch the bulb with bare hands use a paper towel or cloth, the oils in your skin will cause premature failure of bulb.
Sep 11, 2013 | Black and Decker USA Black & Decker...
Jun 10, 2010 | Vector 1 Million Rechargeable Spotlight
My quartz heater tipped over and I think I heard a snap. Well now it is not working and I don't see any visable damage. so whats' up with that? Thanks
The units actually use Quartz Halogen tube strip lamps, 500 - 1000 Watts inside for heating, I suspect the Filament has been broken inside the tube. They can be purchased from a lamp shop and usually clip into place. Be careful tho Power OFF at all times when working on it.
Jan 26, 2010 | Heating & Cooling
Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
Camping, Backpacking & Hiking Logo
335 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
