Question about Husqvarna 21" Lawn Mower with Honda GCV160 Engine HVL 7021RH
Will fire but stops after a few seconds. Not always reaching full rpm. checked for breather hole in filler cap
    Novelist:
  • 111 Answers
I would first check the spark plug and air filter. If the air filter has grass or dirt packed in the folds of the paper element, replace it. Also if the spark plug has a black charcoal like substance on it, it will need brushed off. The spark plug can be removed with a 13/16 deep well socket. If the unit will still not start, there may be water in the fuel tank. Drain the fuel tank and empty the contents of the fuel bowl on the carburetor. The carburetor fuel bowl has a nut on the side of it, it can be loosened with a 10mm wrench. Let it drain out completely, tighten the nut on the fuel bowl, and add fresh fuel. If it will not start at this point you will need to have the engine serviced. This can be done at any Honda Power Equipment repair shop. They may not want to work on it since it is on a Husqvarna mower, most will tell you that the only thing that they will work on is the engine. Alternately you can take it to a Husqvarna dealer and get the mower serviced there.
Posted on Apr 03, 2011
Generator kipor 6700ta, run for a few second and stop, any solution?
hi
you may want to check the filter in the tank if one is fitted check damage fuel line , insure that fuel tank cap breather hole not blocked and injection system
Dec 09, 2017 | Electrical Supplies
Volvo penta aqad41a 200 hp engine with 1300 running hours has oil "pumping" from the crankcase breather
oil level correct ? engine breather clean as can cause back pressure ?
Feb 16, 2014 | Boating
Stall restart
Many ride ons have a breather in the filler cap to stop a vacume in the fuel tank, try just slackening off the fuel filler cap and see if it runs ok, if it doed just replace the filler cap
Jul 12, 2013 | Craftsman Garden
Gas coming out over flow hose on my cbr 600 f2 and to much pressuer in gas tank
Check the carb float levels and that the tank breather is clear. Pressure will build in a petrol container just from it being shaken, but heat will increase the pressure. The breather is usually a small hole in either the filler cap or the filler cap mount. When you see the MotoGP bikes with a pipe coming from the Filler to the fork pivot, this is the breather pipe.
Apr 10, 2013 | 1991 Honda CBR 600 F(2)M
1991 80'' heritage softail classic. Blew oil tank filler cap off
Hi, Kelkins1234 oil level readings are taken when the engine has reached normal operating temperature and the usual suspects are:
1. Overfilled oil tank dipstick reading should at or below full.
2. If the sight glass is full you are running to much oil.
3. Excessive blowby caused by worn out piston rings.
4. Piston rings never properly seated.
5. Faulty breather valve or system.
6. Pinched or clogged breather line/hose.
7. Clogged or failed oil filter.
8. Contaminated oil dirt-rust-water etc.
9. Excessive oil foaming.
10. Wrong oil type not designed for your bike.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Harley Davidson Forums
https://www.carlsalter.com/pdfs/Harley%20Davidson-HD%201984-1998%20FLH-FLHT-FXR-FXSB-FXEF%20Service%20Manual.pdf
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://www.harley-davidson.com/content/h-d/en_US/home/owners/maintain-your-bike/owners-manual.html
Instant Tech Relief To speak to me personally absolutely "FREE"
May 28, 2017 | Harley Davidson FLSTC Heritage Softail...
I have a husqvarna 345 run for a few cuts then stops.
either blocked fuel filter in the fuel tank ( hook out and replace ) or the fuel tank breather is blocked thus causing a vacume in the tank, to prove this, when the saw starts to die slacken off the filler cap, this will allow air into the tank and it should pick up again, the breather is pressed into the tank on the r/h side rear.
Sep 19, 2012 | Husqvarna Forest & Garden No.967012396 345...
How do i check fluid for convertable top
"How do I get the air out of my hydraulic system"?
  • Remove the reservoir plug on the motor pump. Leave the plug out and do not put back until you have finished.
  • Fill the reservoir 3/4 full with fluid (to the bottom of filler plug hole). Put a rag under the hole to catch overflow that will occur as system fills.
  • Run the pump for 15-20 seconds. Stop. Check your fluid level and refill to bottom of filler hole. Continue running the motor in the same direction for an additional 15-20 seconds. When the top gets to the end of cycle, check your fluid level, fill to bottom of filler hole, and run the motor in the opposite direction.
  • You are literally running the top all the way up and down sereral times. Checking the fluid level as you go and fill as required, leaving reservoir 25% empty.
  • When you are no longer able to add fluid, put the top in the down position. Check the fluid level one last time, should be to bottom of filler hole. Put the plug into reservoir.
  • Apr 01, 2012 | 2004 Ford Mustang
    I want to check the engine oil level for previa 2.4 petrol 1995
    OIL LEVEL CHECK Every time you stop for fuel, check the engine oil as follows:
    1. Park the vehicle on level ground.
    2. When checking the oil level it is best for the engine to be at operating temperature, although checking the oil immediately after a stopping will lead to a false reading. Wait a few minutes after turning off the engine to allow the oil to drain back into the crankcase.
    3. Open the hood and inspect the level of the engine oil tank. The fluid level on the tank should read between FULL or F and LOW or L.
    4. If the level is below the LOW or L line, remove the cap and add enough engine oil to reach the FULL or F line. Fig. 1: Fill the engine oil tank located under the hood first 90911p07.jpg
    5. Install the oil cap and hand tighten.
    6. After filling the oil tank, remove the engine access hole cover on the drivers side. Fig. 2: Make sure the oil tank is to the F mark 90911p15.jpg Fig. 3: The oil dipstick is located under the driver's side engine access hole cover 90911p83.jpg Fig. 4: Place your finger through the hole and pull straight up to remove 90911p84.jpg
    7. Remove the engine oil dipstick and wipe it clean.
    8. Reinsert the dipstick, push it in as far as it will go, the pull it out and look at the level on the end.
    9. If necessary, insert more oil through the oil filler cap next to the dipstick, this will completely top off the system. Fig. 5: The oil dipstick has two markings for level check 90911p85.jpg Fig. 6: To fill the crankcase, remove the engine oil filler cap 90911p86.jpg prev.gif next.gif
    Nov 06, 2010 | Toyota Previa Cars & Trucks
    My auto fiat punto smells of petrol after i put some in when i start driving what causes this and how can it be fixed
    sounds like the fuel filler cap breather hole is blocked.also when you top up with fuel always close the windows/doors as benzine in gas is the most poisonous substance known.you should never stand upwind when filling up.(check out benzoates on wiki)
    Mar 20, 2010 | 2006 Fiat Strada
    I smell gas fumes coming from my car when i park and turn off the ignition
    normally fumes come in to vehicle when stopped because of oil leak from rocker cover but check your fuel filler cap seal etc and also incase the tank is leaking just have a sniff at the rear of the car if its the filler cap or tank filler you normally get smell when tank is nearly full and been around a few corners the fuell filler nect becomes pourous and just spills out a bit if so will need replacing .but most time its an oil leak from rocker box or engine
    Oct 20, 2009 | 2002 Saturn L-Series
    Husqvarna 21" Lawn Mower with Honda GCV160 Engine HVL 7021RH Logo
    324 people viewed this question
    Top Husqvarna Garden Experts
    Jim Parker
    Jim Parker
    Phil Walker
    Phil Walker
    Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
