Question about Toshiba Satellite A105 Notebook
The volume is too low so i went in and changed the settings to trusurround and now have no sound at all.
  • Toshiba Master
  • 1,679 Answers
It could be a corrupted Drivers or wrong drivers installed. What is the model like A105 - S2201 etc ?
You can re-download the drivers for your laptop and install and it should work fine.
Click on the link below to download
Audio Drivers
Regards,
Ron
Posted on Mar 26, 2011
Intermittently my Vizio model e370va volume will rise on its own and get distorted then turn off and in a few seconds, turn on the TV. Visio tried replacing the power board. Same problem. Replaced the TV...
I was having the same issue. I found this on Fixya and it seems to have worked.
Okay I just called and found this out. I have the 32 inch vizio hd flat screen. My problem with weak and fluctuating volume, was that I have a cable box. Go into menu, then audio and under the advanced audio section you will see srs trusurround HD and srs trusurround. Basically this function automatically adjusts volume levels for satelites and whatnot. But because cable boxes automatically have this feature you could just turn off the srs trusurround. Hopefully that should help you.
Dec 06, 2010 | Vizio VU42L 42 in. LCD TV
My mobile Nokia 6300 call sound is very low
First Option:
You Go to Phone Settings and In the Sound Setting and Set the High Volume IF Volume Setting Ok But Sound very Low
So
Secend Option:
Your Phone Ringer Default So Please change Ringer
And High Sond Will Solved
Aug 24, 2010 | Nokia 6300 Cell Phone
Sound output is low nowadays even at full volume whereas before it was ok. I didn't change anything with my computer nor did I change my speakers.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
  • Goto Control Panel
  • Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
  • In device Volume Click Advance
  • Master Volume Control Window will open
  • Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
  • From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
  • From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
  • Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
May 17, 2010 | Computers & Internet
My Vizio Tv volume does not work properly. When its at volume 100 it sounds like volume 50. What could be the problem? My question is how can I fix it? Let me know...
May 10, 2010 | Vizio VF550M 55 in. LCD HDTV
Home theater hooked up volume sounds low
Check your different settings either in your t.v. or your amp. In your menu settings you can change your audio. Bass trebile etc. and even sometimes switching it from stereo,mono, dolby digital will increase your volume. Dolby digital is very quiet if your not running and exteranal amp system. so try changing it to stereo and your volume should increase.
Aug 31, 2009 | Panasonic Audio Players & Recorders
LG flat screen TV speakers make a vibrating noise
I have this problem with my 37LG30.
They all seem to have the same factory flaw.
The plastic bezel and rear is vibrating against itself I have found.
Tonight, just now, I just took all the front bezel screws out,(from the back) loosened the other 4 big screws in the rear center(I don't recommend removing them)and loosened the stand screws also and tried separating the bezel from the back as I went around the set. This did not really help much except around the bottom where the noise/vibrating comes from-the speaker area.
The two plastic pieces are vibrating against one another.
The vibrating was coming from the speaker area without doubt.
The next thing was to try separating at the bottom where the speakers are with my fingers and a stiff metal nail file carefully..fingers seemed to work best for me.
As I separated the front bezel from the rear housing (at the speaker location)most if not all the buzzing/vibrating /distortion went away.
I then inserted small pieces of cotton (you can use felt, or similar I suppose) and buttoned it all back up;put the screws in
Almost all the distortion and speaker buzz/vibratingis gone except on very low frequencies.
good luck!
Jan 29, 2009 | LG 42LC2D 42 in. LCD HDTV
Very very low sound/output
Helle there!
First!
1) check your setting for sound to (2 way speakers)
2) Setting for Volume in control panel.
3) connector may be you need a little expantion from radio shack gold ext.
4) be sure you got sound from headphones !! **
Go it!
Jul 31, 2008 | Philips SBP1100/37 Portable Speaker System...
Acer aspire 5715Z Sound Card
you can increase the volume from the volume control settings.
Click start,all programs,accesories,entertainment,volume control.Change the settings and see if there is any change.
Jul 20, 2008 | Acer Computers & Internet
My psp sound quit working. it went low and now no sound at all.
I take it the volume control doesn’t change it? If the level went down rather fast the Volume decrease button (-) might have gotten stuck down.
Have you tried different set of ear buds (headphones)?
Mar 21, 2008 | Sony PlayStation Portable (PSP) Console
I have a Samsung HT-X50 Surround Sound, a LG 50" Plasma 50PC5D TV, and DISH Network Satellite.
How can I get surround sound to work on my tv. When I pull up my menu and go to audio the SRS Trusurround XT is not in bold so I cant figure how to connect it so I can have the surround sound coming from the system and not from the tv. Please help.
Dec 24, 2007 | Samsung HT-X50 System
Toshiba Satellite A105 Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
