Question about Proform 590 Crosswalk LT Treadmill
ProForm 590 LT, MOdel PFTL99909.1 Used treadmill yesterday, no problem' Today after plugging it in, and turning on circuit breaker and putting key in, console doesn't respond, fan won't go on, and treadmill makes a low grinding noise. Re-did all of the above after 5 minutes, and still console doesn't respond. Belt will move if I roll it manually. Received at Christmas as gift.
  • nanette4k Mar 26, 2011
    It fixed itself after incline went up and down a couple of times! Go figure, but I am happy.
  • 16 Answers
SOURCE: Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
Posted on Apr 14, 2009
SOURCE: Proform 520
Not sure what's happened here. treadmill won't turn on when red key is inserted. checked electrical plug to make sure it worked. I couldn't see that there's anything wrong with the red key. Have any ideas?
Posted on Sep 12, 2009
  • 82 Answers
SOURCE: Proform 590 HR Treadmill. Belt won't run
Hi, i fixed one just the other day, the control unit fails.
broddersbaldrick on a big auction site fixes them :)
Hope this helps
Posted on Apr 22, 2010
  • 15 Answers
SOURCE: belt won't move
does is just not move when you're standing on it, or not even move when you're not standing on it. It may be a simple belt adjustment or if the motor is running but there's no track movement you may be looking at a loose/broken drive belt. Take the cover off, start it up and look at the motor/drive pulley assembly. If the motor turns and the front roller doesn't, tension the drive motor by moving it back. If the front roller turns but the track doesnt, do a track adjustment as per your users manual.
Posted on May 27, 2010
  • 832 Answers
SOURCE: proform 490gs treadmill works for about 5 minutes,
As the walking belt wears, it creates more friction with the deck which creates more heat in the belt causing it to wear further. Additionally, the increased friction requires the motor to work harder to keep the belt moving at the same speed. With this in mind, it causes the motor to draw more electricity and therefore, more power to move the belt. The motor has to get rid of this excess energy in some way so the way it normally does it is by releasing it in heat so that's why treadmills with belt problems typically overheat the motor too.
All of this to say that if the breaker starts tripping, you know that the belt is causing the motor to pull too many amps and the safety system is working as it should. If the breaker has tripped more than a few times, it will need to be replaced because the breaker weakens every time it trips. Additionally, the walking belt will need to be lubricated at a minimum and if you want to be very aggressive toward the symptoms, replace the walking belt. Silicone lubes, like water-based liquid silicone require relubing once every 30 days. Go to E Bay and you will see the different types and prices they will all do the the job. I would go down to the Hard ware store and purchase a 4 or 5 dollar can of silicone lift the one side of the belt and spray the length of the belt 3 applications on each side should to tell you if has taken care of the problem if not the belt and deck will need replacing.
Posted on Jul 19, 2010
I have a proform crosswalk 400e, and the circuit breaker on the treadmill trips whenever I plug it in
Many motor may have two stages, the first starts it turning and then the second stage takes over to keep it running. The 2nd stage of the motor may be faulty and drawing two much current or leaking current to the earth. Your breaker may not be the correct rating for the machine and needs uprating.
Something could have slipped in or moved around that could be jamming the belt or something else in the machine preventing it from starting up and causing an overload that triggers the breaker.
Feb 15, 2015 | Proform Crosswalk 400e Treadmill Total...
What to check if Wrong Electricity input is made
It's dependent on the extent of the damage; you may need to replace the electronic circuit board and/or the motor.
Can you described what happened when you turned on the treadmill while it was plugged into a 220v outlet?
What happens when you plug the treadmill into the 110v outlet?
Jul 09, 2014 | ProForm 690 LT Treadmill PFTL06009
I have a Proform 625 treadmill that I had to move. I unplugged the unit, slid it to where I needed it to go and plugged it back in. When I did so, the console powers on, but the display flickers and the...
You can try the following:
a. Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor
is plugged into a properly grounded outlet (see page 9). Use only a single-outlet surge suppressor
that meets all of the specifications described on page 9. Important: The treadmill is not compatible
with GFCI-equipped outlets.
b. After the power cord has been plugged in, make sure that the key is fully inserted into the console.
c. Check the circuit breaker located on the treadmill
near the power cord. If the switch protrudes as
shown, the circuit breaker has tripped. To reset the
circuit breaker, wait for five minutes and then press
the switch back in.
d. Check the on/off switch located on the treadmill near
the power cord. The switch must be in the on posi-
Nov 25, 2013 | Proform 625 Front Roller Model Pftl62510
Cannot turn on proform 380 cs treadmill
1) test the outlet wall with a desklamp, if the lamp turn On THE circuit is o.k otherwise, the problem is fuse blown or c. breaker tripped, reset or replace fuse.
2) test the power cord for open or faulty. with VOM usin continuity
3) test the fuse y/o c.breaker inside of machine and reset or replace.
4) Turn on the machine if the machine keep the same simpton, test the key(magnet) the key is a magnet, test vs your magnet from seal magnet of your refrigerator for atraction or repulsion, if doesnot pass the test replace the magnet from some hardware like home depot.
and PROOF again, can be work. see the block,
Otherwise if the problem keep you must call some tech profesional, maybe you have Main switch open or defective and need replace, or power supply, capacitor, transformer, etc defective. or faulty.
God bless you
Sep 20, 2012 | Proform 380 CS Treadmill !
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
I have a proform 300 treadmill. we moved into a new home and it just stopped working. it was perfectly working before the move. now, nothing comes on, no power, nothing.
Dear Sir:
I will help you.
1. NoPower
o 1 Make sure that the surge protector being used isproperly grounded and turned on. Check that the treadmill power cord isproperly plugged into the surge protector. o 2 Check to see that the key is inserted in theconsole. o 3 Check the circuit breaker on the frame near thepower cord. If the reset/off circuit breaker has tripped, wait 5 minutes andthen reset the breaker by pressing the switch in.
2) Circuit Breaker:
Please check the circuit breaker from the main panel, and reset, or put some Lamp for to see if turn on. if do it. the problem could be the wires and the plug, Test it with A VOM(Voltimeter) for a continuity.
Thank you in advance, sincerely.
If you need extra help, please do not hesitate to reach me. .
Sep 13, 2011 | Proform 810 TR Treadmill
I have a Proform XT 90 treadmill that was recently purchased. After I brought it home, I plugged into my power strip and everything worked fine. Yesterday I plugged it in and nothing lights up on the...
A couple likely issues would be:
1. Is the starter key installed correctly?
2. Has the onboard circuit breaker tripped? The breaker reset is next to the on/off switch, which is on the lower front of the unit. Press the button once firmly. If this was the problem, the treadmill should work again immediately. If the onboard circuit breaker trips repeatedly, there may be a short circuit in the machine, in which case you may be at risk of shock if the unit is not repaired properly.
3. Has the circuit breaker or fuse for the particular outlet you are using tripped? Try plugging another electrical appliance into the outlet. Does it get power? If the circuit breaker or fuse has tripped, that particular circuit may be overloaded or faulty. Only an electrician could tell you for sure.
Please followup if you need further assistance.
Apr 29, 2011 | Proform Exercise & Fitness
My proform crosswalk 590 circuit breaker keep turn off after run for five mins
Have you lubricated the walking belt & deck?? Are the deck and/or belt worn out and require replacing??
Check the deck for damage and wear, check the belt (feel the outer edge and then the center. Is the center fuzzy??)
If the deck and belt are good, lubricate them and try again.
Is the belt to tight??
Are you using an extension cord??
The machine is drawing too much current, usually deck & belt or defective motor will cause your breaker to go..
Dec 14, 2010 | Proform Exercise & Fitness
I get noise feedback from my radio when the treadmill is running??
yes on that treadmill noise filter is not installed so it is common
Nov 22, 2010 | Proform 590 Crosswalk LT Treadmill
Proform 590 Crosswalk LT Treadmill Logo
97 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
