Question about Williams (5009622) Ceramic Gas Wall Mounted Panel Heater
Heater will run for 20 to 40 min cycle fine and that shut completely off...piolt and everything...relight same thing over again...
It could be that heater is not venting properly and this will cause the heat limit switch to go off
Posted on Apr 08, 2011
Lights but turns off in about a minute
It might have a built in thermostat that will light the heater when room temp falls below a certain temp. It should then relight and warm things back up. As long as the pilot stays lit it should work just fine.
Feb 08, 2014 | Emberglow Melbourne Oak 24 in. Vent-Free...
Hi i have a ready heater 170T i cleaned it last year to help out our main heater in our barn for when its get way to cold for our main heater to keep up so i turn this on when i am back there for the day...
Based on your description of the problem ............The part where you say "wont relight till it cools down" is a sign that the motor may be getting hot, the internal sensor in the motor is shutting things down for safety reasons. To find out run the heater til it shuts down then remove the cover. Feel the motor. It should be room temp or slightly warm. If hot- replace the motor with 102001-30.
Other possibilities would be a defective thermostat or temperature sensor. Eliminate these possibilities first.
Sep 07, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
Garage furnace (standing Pilot) pilot stops after 30 mins.
it sounds like the afc the fan control not working could be dust on the afc
Jan 10, 2010 | Dayton Gas Furnace Heater
Wall furnace shuts off after about 10-20 mins
sounds like its not venting properly...it likely is shutting off on a "Spill switch" or "Vent safety switch"....check the vent/chimney first off.....also the pilot could be dirty..,..a lazy pilot tends to blow out easily....pilot should be blue and sharp,,,big enough to fully envelope the thermocouple
Oct 30, 2009 | Heating & Cooling
How do you reset the whirlpool gu2400 xtp83 dishwasher. the clean light is flashing. The unit will not start
Can be caused by detection of a heater circuit problem. You can reset by running the diagnostic cycle. To turn of the diagnostic cycle, press: HEATED DRY button, then NORMAL button, HEATED DRY button again, then NORMAL button. The cycle runsfor ~22 mins. When it completes, the blinking light should go out. You can then try running the dishwasher again. If the problem comes back, the heater element or Thermister may need to be replaced
Jul 29, 2009 | Whirlpool GU2455XTS Built-in Dishwasher
Williams (5009622) Ceramic Gas Wall Mounted Panel Heater Logo
501 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
vance jones
Superior Maintenance
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
