Question about Dyson DC25 Animal Bagless Upright Vacuum
How do you remove ball on Dyson DC25 Bagless Upright Vacuum?
  • 72 Answers
SOURCE: Emptying cylinder
I hope you've found out by now, but, in case you haven't, the latch to remove the canister is right by the handle on top of it, just don't lift until you release the latch with your thumb, it's got a safety to keep you from hitting the release when you're using that handle to carry the vacuum.  (good engineering).
you can download a manual from the dyson site, here:
http://www.dyson.com/customercare/manuals/us/dc07_opmanual_usa.pdf
Posted on Oct 20, 2007
SOURCE: How do I remove the washable filter to clean it on my Dyson bagless vacuum?
As you are looking down at the base of the machine (viewing from the front) you will notice a yellow button on the right side just inside of the the wheel area. push up the button to release the casing that holds the hepa filter and the spongy filter. You can see a diagram on your machine which shows this process. After you take the casing from the machine, the round housing which houses the 2 filters will come out of this casing as you pull it off. You can grab the spongy filter and pull it our of the casing. Rinse both filters as shown in diagrams on the side of the casing. Do not use soapy water, just warm water and squeeze out the spongy filter after each new soaking. Let the filters dry for 12 hours and then replace in your unit and enjoy the refurbished air movement. It does suggest that you clean these filters every 6 months.
Posted on Aug 09, 2008
skyblue67
  • 71 Answers
SOURCE: Dyson - Ball HEPA Upright Bagless Ultracompact and
Hi have you checked underneath to see if the belt has snapped, you will find it either side of the brush, if so you can obtain a replacement at most retails stores but take the model number and make with you, hope this helps
Posted on Jul 19, 2009
Dysonteam
  • 167 Answers
SOURCE: Dyson DC25 upright not standing upright
Hi its Darran at Dyson.
So that we can help resolve, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US). It sounds as though your stabiliser has come out of place and one of our advisors should be able to help you pop this back in.
Kind regards
Darran
Dyson Customer Service
Posted on Apr 19, 2010
Dysonteam
  • 167 Answers
SOURCE: My Dyson Ball DC25 Animal will not stand upright?
Its possible that the stabiliser pedal has popped out of place. For help on how to resolve this, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
How to remove ball from Dyson dc 25 Animal ?
Remove the torx screws that hold the two halves of the ball shell assembly together, then the ball halves can be separated and removed from the vacuum. Take note of how they come apart and how they line up su you can reassemble them properly.
Feb 05, 2017 | Dyson DC25 Animal Bagless Upright Vacuum
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    The ball on my Dyson DC25 doesn't turn: it's as if it's stuck . How do I release it?
    Make sure the filter cover is on properly. If you can't see what is restricting the ball from turning. You might have to take it to a Dyson service center.
    Aug 01, 2014 | Dyson DC25 All Floors Bagless Upright...
    Replace power cord on Dyson DC25
    press the two side together were the little tabs are and it should pull off:
    Apr 04, 2013 | Dyson DC25 Animal Bagless Upright Vacuum
    Filter in the ball on my DC25 keeps coming loose and keeps the ball from spinning any ideas
    My Dyson DC25 keeps blowing off the filter within the ball. It then stops the ball from rotating freely.
    Jan 14, 2011 | Dyson DC25 All Floors Bagless Upright...
    Kind regards
    Darran
    Feb 14, 2010 | Dyson DC25 All Floors Bagless Upright...
    Dyson DC25 Animal Bagless Upright Vacuum Logo
    3,222 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
