I can only get channels 600 through 900 which I have never see before.I cannot get regular channels or cable channels.It is not a flat panel t.v.Q1435A is the model number
  • 4 more comments
  • bjelaw Mar 26, 2011
    I ran the auto program and there is no change.When I pushed the av/tv button on the front of the set all i got was av1 , av2 and dvd and a blue screen.I have a cable box connection through Comcast.
    I tried the auto program and there was no change. I have a connection through a cable box provided by Comcast.I pressed the av/tv on the front of the set and it only has av1,av2, and dvd and the t.v.is still the same,
    It is connected by coaxial cable.
    It is connected by Coaxial cable.
    I responded that it is connected by coaxial cable.
    Did you get my response that our T.V. is connected by coaxial cable?
    President:
  • 1,140 Answers
Hi -
If you have a cable TV line connected directly to the TV, an antenna or a cable box connected by coaxial cable, I would suggest running the automatic channel scan (AUTO-PROGRAM) again:
1. Press the AV key on the Advent remote control repeatedly until TV is displayed in one corner of the TV screen. If you don't have the Advent remote, use the TV/AV button on the front of the TV.
2. Press the MENU key on the advent remote or the front of the TV to open the on-screen menus.
3. Use the CH+/- keys on the remote or on the front of the TV to highlight PRESET then press VOL+ to select.
4. Use the CH+/- keys on the remote or on the front of the TV to highlight ANTENNA then use the VOL+ key to select either AIR (for antenna) or CABLE.
5. Use the CH+/- keys on the remote or on the front of the TV to highlight AUTO-PROGRAM then press the VOL+ key to start the automatic channel scan.
Once the channel scan is complete, the TV should automatically return to viewing the first channel found during the scan. Do not press the MENU key during the scan or the scan will not complete.
If you are using a cable/satellite receiver and it is connected to the TV by any means other than a coaxial cable, you do not need to run the channel scan. You should simply select the correct AV input using the AV key on the remote or the TV/AV key on the front of the TV (see step 1 above).
If you have done all of the above and you are still unable to get the channels on your TV, please post back for further assistance. You can reply to me by clicking on "Add a Comment" below your question. Please let me know whether you are using a direct cable line, antenna or cable box, etc.
Regards,
BElectric
Posted on Mar 26, 2011
  • 1 more comment
  • DILLIGAF
    DILLIGAF Mar 26, 2011
    Thanks for getting back to me. How is your cable box connected to your TV - coaxial cable (threaded connection) or AV cables (red, white and yellow jacks)?
  • DILLIGAF
    Please see comment above. I need to know how the cable box is connected to the TV. Thanks.
  • DILLIGAF
    It's OK, I saw your reply. I was just checking some details for this TV and writing a reply. If you are unable to select the TV input using the AV button on the remote, I believe the analog tuner in your TV has failed.
    Please check the cable line connection to the cable box and the connection from the cable box to the TV and ensure these are fully inserted and the nuts are tightened. Then try selecting the channels using the number keys on the advent remote. If this doesn't work, your analog tuner has most likely failed.
    You should still be able to use the TV for watching cable by connected the cable box to the TV using RCA type AV cables (red, white and yellow jacks). Connect the jacks to the back of the cable box and the back of the TV, then select the AV1 input on the TV using the AV button on the remote. You do not need to run the channel scan when using AV cables and channels are selected using the cable box remote control.
    Considering the age of the TV and it's value, it is not economically viable to have the TV repaired. Using AV cables will enable you to continue using the TV at minimal expense. If you already have a spare AV cable, this solution will cost you nothing.
    If you need assistance connecting the cable box to the TV with AV cables, please let me know.
    Regards,
    BElectric
    Please note: you will need to click on "View More Comments" below this message to see any future messages from me.
What do i need to get regular channels on the tv
How to get regular TV channels?
Your HDTV should have a digital TV Tuner (ATSC) which may need an indoor antenna. Change your TV's input selector to TV or Antenna or Digital (probably one of those three) and scan for channels. If you don't get any channels, then you do need an antenna. Probably another $10.
How to get basic channels on new HDTV without cable - HDTV ...
www.tomsguide.com/forum/53920-4-basic-channels-hdtv-cable What do need to get regular channels on the tv Google Search
Dec 12, 2016 | Televison & Video
HOW DO i RETURN TO REGULAR CABLE CHANNEL FROM ON DEMAND
Read the manual on how to use the TV remote correctly
Sep 07, 2014 | Televison & Video
How do i get the channels to scan and pick them up on regular cable line
Hello, without a model number I can only give you a generic outline on how to do this. Go to the "setup" menu, select "channel setup", select "cable mode", then have it "auto program". When it's finished, you should have what cable channels your cable system will allow without a cable box.....thanks
Aug 05, 2014 | Televison & Video
Insignia tv channel scan duplicate channels
the set should have in the menu a way to manually add or delete channels, consult the owner manual and or look for that feature in the sets menu.
Apr 16, 2012 | Insignia 42" LCD Flat-Panel HDTV
My son bought this TV and had it hooked up to a cable connection with an HDMI cable and it worked fine. He gave the TV to me and I hooked it up to a basic cable connection with no cable box. It does not...
If your TV has an On-screen Menu you should be able to access your Tuner controls. Run your auto channel scan and you should pick up your "regular channels". You may be able to de-select the odd channels and show only the ones you want to use.
Oct 03, 2011 | Westinghouse LTV32W6HD 32 in. LCD...
I connected my HDMI cable to my television and have comcast for my provider. I get the HD Channels beautifully but when I go to a regular non HD channel, I get no sound at all, only the picture. How am...
You will need to used a red and white cable that will connect to the (audio out) on the comcast box and then to your (in audio) on your tv.
Thanks
wbigtodd
Jan 22, 2011 | Insignia Televison & Video
Sound and picture interference when changing channels from hd to regular tv model VX37L vizio
It may be the cables you are using. You will need to HDMI cables for high def and rca or coaxil for regular
May 09, 2009 | Vizio VX37L Television
My dynex tv has digital channels but they are not audible
Use component cables instead of the HDMI cables. We had the same problem and that's how the cable guy fixed it. You use just the regular red, white, and yellow cables then the other 3 colors that are just for HD tvs.
Feb 08, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
