When washing machine fills with water to rinse, the water does not cut off.
  • Washing Mach... Master
  • 8,220 Answers
Easy fix. No parts needed. All washers have a water level switch of some sort.
Each switch has a small rubber tube attached to it. The tubing goes down under to the base of the tub. As the water level rises the pressure builds inside that tubing. When the desired level is reached the switch kills the water works and starts the motor works. Off she goes a washing. What you must do is find the water level switch and remove that hose. Blow out the sediment in the base of the tub and reattach that hose securely. Then pump out the water in the tub so that the pressure can have a chance to build in that tubing. Retry and party on!
I have over 500 free service manuals at my appliance digest link HERE
Posted on Mar 26, 2011
  • 4,399 Answers
You have a water level sensor on the washer that controls the amount of water that enters the washer. It probably needs fixed. Thank you for choosing FixYa.
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
I believe the water temp switch is bad. It will start filling on warm then stop if I put it on hot it will fill with cold water. I have cut the hot water off to achieve this but when it reaches rinse it...
it sounds to me that the hoses are connected to the machine incorrectly. Typically if the plumber ran the water lines behind washer correctly the hot pipe is on the left and the cold pipe is on the right sometimes thats backward and be determined by touching hoses while filling on warm setting and see which hose feels hot. On the back of washer they where they connect hot goes on the bottom and cold on top
Aug 08, 2011 | Estate ETW4400VQ Top Load Washer
Machine won't fill up with rinse water, it washes & spins but the water only trickles in the rinse cycle, i ahve been filling it up manually
Turn the water supply off.
Remove the COLD water hose from the rear of the washer.
Clean the silt out of the COLD water valve on the washer.
Re-attach the hose on turn on the water supply.
Jan 21, 2011 | GE WBSR3140DW Top Load Washer
At rinse cycle, cold water won't cut off after
if you unplug the washer does the water continue to enter? if the answer is yes you have a bad fill valve. is it only when you use cold water? what is the model number?
Apr 05, 2010 | Washing Machines
Washer stop in middle of rinse cycle
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WHirlpool Waser model LSR8133HQ0 - tries to fill for rinse cycle
hellow my name is joyce and It sounds like you have a issue with your cut off valve that controls the water flow to your machine in between cycles, this is controled by your timer switch you may want to call technichian to repair. sounds like the only problem you have with the timer is on the rinse cycle not the wash cycle, but it defently needs to be fixed. if I can help you find a repair person please let me know.
thanks you and let me know if I can further assist you.
joyce
Feb 06, 2009 | Whirlpool LSR8433K Top Load Washer
No rinsing water coming in
There are 2 versions of this washer dryer, a cold fill only one and a hot and cold fill version.
If it is the cold fill version, it could be the water level switch that is malfunctioning, cutting off before the correct level is reached, or a sticking water inlet valve.
If it is the other version, then the same thing applys, plus the coil on the valve that controls the rinse cycle could be open circuit.
You need a meter to test the valve coils for continuity..
Make sure that there is actually cold water to the valve, if it is a hot and cold fill model.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Indesit W 123 Front Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Ge washing machine
When your rinse cycle does not work it is your outlet filter that is clogged. If this is a front loader the small door is in the bottom front side of machine. Be prepared for some water to come out when u open the door. Unscrew and clean out filter and refit.
Sep 20, 2007 | Washing Machines
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
