Question about Toshiba Computers & Internet
My Toshiba Laptop inside Fan is not working. Due to over heat automatically it is getting shutdown. Please suggest me how to solve this problem?
  • 54 Answers
1. GO TO SERVICE AND REPLACE IT.
2. IN BIOS, SET DISABLE THE FAN CONTROLER
PLEASE VOTE!!!!
Posted on Mar 26, 2011
My acer lap top is not working because it get heats up and shuts down automatically
First, Laptop shuts down by itself when the processor/ CPU temperature exceeds the safe temperature limit.
Laptop heating issue generally occurs due to fan failure, which may damage the system, if not checked properly. Another most likely cause of overheating is the dust present inside the laptop, which clogs the fan and heatsink.
1. Make sure the fan is running. (if not it needs replacement)
2. Clean the fan and heat sink (thermal module). Click here for laptop disassembly instructions and refer to
Removing the System Fan/Thermal Module after removing the outer cover. Take out the fan and heat sink. clean them with the help of tooth brush and put it back. Also, repair manual can be searched online or downloaded for referrence.
The procedure is very simple, but if you are not comfortable with working inside electronics, I suggest that you should get you laptop checked by a professional for servicing (if required). I believe immediate action is required to prevent any damage to your machine and data.
Hope it Helps! Let me know if i could be of any further assistance.
CreativeTECH
Apr 12, 2011 | Office Equipment & Supplies
MY COMPUTER SHUTDOWN WHILE IT HAS A 60%REMAINING BATTERY. UNEXPECTED SHUTDOWN. MY LAPTOP CANT RESUME THE PROGRAMS RUNNING AND UNSAVED DOCUMENTS AFTER THE UNEXPECTED SHUTDOWN HAPPENS ..WHY MY OTHER LAPTOP...
If the Computer restarts randomly, then the issue might be due to any damaged Operating System Files.
But, if the Computer shuts down randomly, it is due to the Processor.
All the Processors will be designed in such a way that, if there is any overheating issues, the Computer will shut down randomly.
The overheating might occur due to the malfunction of the Cooling Fan in the Computer.
As this is a overheating issue, it would be better to get the Unit examined at the Service Center.
Replacing the Cooling Fan in the Computer should resolve the issue.
Jul 05, 2010 | Computers & Internet
My laptop gets heat and shutdown
“My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
Feb 27, 2010 | Compaq Evo N610C Notebook
Toshiba 2435 s255 notebook shutsdown and fan runs on high speed
Overheating problem is caused by faulty fan and or the fan and heat-sink assembly is clogged with dust.
When the CPU overheats, it goes into thermal shutdown and won't boot up again until the CPU has cooled down. If this problem is not fixed, eventually the CPU will fail completely. The fan must spin freely, if not replace the faulty fan.
Check the fan and heat-sink and loosen and vacuum/remove the dust from the fan and heat-sink assembly. Depending upon the model of your Toshiba, the fan can be accessed from the bottom of the laptop or you may need to remove the keyboard to get at the fan and heat-sink.
Jan 22, 2010 | Toshiba Satellite 2435-S255 Notebook
I have a Acer desktop. after working for one hour it shuts down automaticlally. please help me.
Please check your Laptop Processor fan, if the fan stops working then the Processor got heat and system automatically shutdown or restarts
Dec 01, 2009 | Acer Computers & Internet
Sony vaio system becomes hot and shutdowns
More than likely the fan above the processor is not working. Or the vents are clogged on the computer case due to dust/dirt. Ventilation.Check the fans.
Nov 22, 2009 | Sony VAIO VGN-CR510E/L Laptop
My laptop is DELL Inspiron 1501 it is now quite often shut down by itself without notice. How can I solve this problem?
there is so many resons of shutdown it may be your pc has so much dust on the possessor fan due to dust ur possessor produce heat and its will be shutdown automatically
Nov 14, 2009 | Dell Inspiron 1501 Notebook
It crashed and now it automatically shutdown after a minute about
The fan may be cluttered with dust. Clean it. Then turn the unit on and watch to see if the fan does indeeed work. If it does not, shut the unit down till you get a replacement fan. The fact that the unit shuts down is a saftey feature to keep your Proceesor from being damaged.
If cleaning it works, your processor should be ok.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 13, 2009 | Toshiba Satellite A205-S5879 Laptop
Computers & Internet Logo
71 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
