Question about Karcher Garden
Hi, my kb403 pressure washer has very little pressure and motor runs constantly, any ideas what the problem could be?
4 Suggested Answers
  • 389 Answers
SOURCE: Motor cuts on 2-3 seconds and then off and repeats this pattern
There are several possible causes of this problem. The three simplest to check are: 1. water supply is not sufficient, 2. water inlet strainer is clogged, 3. nozzle in the spray lance is partially blocked. After those, the most likely problems are internal and will probably require professional attention.
Posted on May 19, 2009
  • 5603 Answers
SOURCE: Hello there.My Karcher pressure washer motor
The valve that admits more water to be compressed is stuck. It is likely the O-Rings on it need replacing. No water to the pump, no pressure!
The motor will stop when pressure is up to the designed pressure.
Posted on Oct 03, 2009
  • 21 Answers
SOURCE: The pressure washer motor is
pour liquid TSP into the fresh water port (where the garden hose connects) and let it sit there for a couple of days.
This will clean all the calcium and lime deposits within the pump.
This is how I fixed my pressure problem.Hope it works for you.
Posted on Aug 29, 2010
Pressure washer keeps cutting out
HI Earl I need a little more info do you mean the motor stops or the pump stops pumping ( with the motor running)???
Nov 24, 2015 | Garden
Why does the motor run when I do not pull the trigger of the gun after the high pressure washer is turned on? The motor is supposed to run only if the trigger of the gun is pulled and shuts off when the...
When water is running through system, the motor has to run to keep the pressure built up. So, if the water is leaking out, the motor think it needs to keep running to keep the pressure built up. The leak needs to be fixed to the motor will not run constantly.
Jun 16, 2014 | Karcher PSI Electric Pressure Washer
Constant pressure
Some of these machines require you to hold the spray handle trigger in the open position while starting the motor, once it is running let the trigger go and it should run on bypass
Apr 11, 2014 | Craftsman 2500 PSI Briggs & Stratton...
My karcher k7.85 has lost pressure and the motor runs constantly when switched on ,motor only used to run when trigger pulled in on lance ,there is no leaks. Can any one help please.
Sounds like the pump seals are bad. The manual says to only use these a few minutes at a time, most people try to clean the patio etc with them, run them too long, and burn out the pump seals - don't ask me how I know this.
Feb 17, 2014 | Karcher Garden
Lights 2 and 7 and constant beeping
Error code 66 is water pressure sensor.
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
Dec 06, 2012 | Fisher and Paykel GWL11 Top Load Washer
Hi i have a k3.65 jubilee model when switched on it constantly surges and the water pressure is not as good as it was its only 10 months old.any advice
Have the hose pipe running into a bucket/container and use another short length of hose from the pressure washer to **** the water out of the bucket, that way if the bucket is full when you start, any drops in mains pressure wont affect the pressure washer as their should always be a reservoir or water to keep constant pressure.( you may need to prime the suction hose first, just hold the 2 hoses together in the bucket of water with pressure washer on)
Any questions ask
If this helps please rate me
Oct 19, 2010 | Karcher Garden
Hello there.My Karcher pressure washer motor constantly runs with no pressure coming out of trigger gun.I have tried another gun with the same result.The motor should stop/start when you press gun.The...
Oct 03, 2009 | Karcher Garden
The motor keeps surging
If there's a lot of sediment in your water supply, there's a chance that sediment has gummed up the pressure switches. I'm assuming it has a full power switch and high power switch. It runs on full power until a pressure switch is satisfied, and runs on low power to slowly build the pressure back up, at which a second switch is satisfied from the pressure and turns the motor off. These things are not easy to work on, and are made of metal probably too fragile to try any chemicals. You should probably contact the manufacturer.
Sep 19, 2009 | Karcher 1750 psi Electric Pressure Washer
Runs constantly and leaks water from the housing
There is an internal leakage or breakage. This will cause a leak and also cause it to keep running.
Jul 03, 2009 | Karcher K2.26 Electric Power Washer
Garden Logo
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
