Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Five year old whirlpool Cabrio top loading washer. Unit sounds like it could use some bearing lubrication during spin cycle. Already have removed the agitator and basket. Outer tub is still suspended on its four rods. To gain access to the tub bearing do I remove the outer tub while still attached to the motor? Whirlpool does not list the bearing separately and I am hoping to replace it or grease it using a needle attachment to a grease gun. If removed together, what is my next step to separating the tub from the motor shaft?
jsrock516
  • 5911 Answers
SOURCE: rear tub bearing replacement
The shaft on the spinner basket may have worn and formed a groove, or, if the bearing seal was leaking, the shaft may be stuck because of rust. The best way I know how to get the spinner basket out, is to try spraying the shaft with a lubricant like penetrating oil, or WD-40 and letting it sit a while. Allow the lubricant to settle into the area where the shaft seats into the bearing. If this does not provide you with any luck, place the outer drum face down on something to elevate the spin basket up off the floor. I suggest using a couple of saw horses, or blocks of wood. Allow the outer shell to rest on supports, leaving the spin basket free. Place some padding or old towels on the floor underneath the basket. Take a mallet (I prefer a rubber mallet, as it tends to be less abusive) and tap on the end of the drum shaft. The spin basket should pop free and drop from the tub shell. I hope this helps you.
PS You only have to elevate the basket and tub off the floor enough to allow the spin basket to drop free of the tub. About a foot is all I would recommend. Make sure you inspect and clean the spin basket shaft once you get it removed. Some very fine emery paper is what I would recommend to make sure the shaft is not scored or have any rough areas. DO NOT use any electric sanders or dremils for this! It should be clean and smooth before re-installing. If you cannot get the basket free, or if you do, and the shaft is damaged, you may consider replacing it as well. Placing a damaged shaft into a new bearing may not seal properly.
Posted on Aug 28, 2008
docjohn174
  • 943 Answers
SOURCE: TOP LOAD WHIRLPOOL WASHER BRAND NEW CRACK IN OUTER PLASTIC TUB.
HI the agitator comes off. 7/16 bolt under cap remove pull agitator off. now you take off that big nut in the middle. remove. pull tub out. replace the tub. thanks
Posted on Oct 15, 2008
onthejob5130
  • 640 Answers
SOURCE: spin cycle very loud,
spin surpport defective,,,this part is under warranty,,lifetime warranty..contact whirlpool for replacement of spin basket,,onthejopb
Posted on Feb 07, 2009
aborcass
  • 2651 Answers
SOURCE: sock stuck in outer tub whirlpool cabrio
youll need to "pop" the main top.. then unsnap the outer ring that cvers the outer tub. if you look at the center of "agitator/ or bump plate depending on model" theres a small cap that will come of fand reveal a 7/16 screw remove the screw, and then oyull be able to lift the entire inner basket right out to retrieve any debris.
Posted on Feb 14, 2009
SOURCE: Leaking around center spindle gasket of outer plastic basket
There was a hole in the plastic liner tub from the inner metal basket rubbing on it during the spin cycle. I got some plastic cement and put it in there and it willl hold for a little while while anyway. Not a very well designed washer when you look into the guts of the monster.
Posted on Feb 22, 2009
Why do I have this Clicking Noise after bearing and seal replacement
  1. Ft. Cabrio Top Load Washer‎
    Adwww.sears.com/‎Black Friday Sale Save Over 40% on Select Appliance
    Hot Buys. Free Delivery Over $399.
  2. Appliance Hot Buys
    You'll Save More When You Shop Hot
    Appliance Buys on Select Products!
Search Results
    Whirlpool WTW6400SW Cabrio Washer Makes clicking ...
    www.fixya.com > ... > Whirlpool WTW6400SW Cabrio Washer
    Whirlpool WTW6400SW Cabrio Washer, makes clicking noise spin cycle related issues. Get free help, solutions & advice from top Whirlpool experts.
Nov 26, 2015 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool cabrio loud noise
Check your bearings. This post will show you most of what you need to know about your bearings:
http://www.squidoo.com/how-to-replace-bearings-in-a-whirlpool-cabrio-maytag-bravo-or-kenmore-oasis
Nov 06, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio makes excessive noise during spin cycle
Your model has a bearing under the tub which is probably going bad and needs to be replaced. cabrio washer bearing replacement YouTube
Oct 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer sounds like a turbine engine during spin cycle
It is the bearing in the outter basket. Some of the units had 5 years on the outter baket. I am a service tech & fixed several of these.
Sep 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
During spinning it is really noisy now. works
you should never use bleach in any machine as it will damage your machine beond repair.and yes i think your spot on the main bearing is gone and needs replaced.adrian,,,,
Jun 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
NOISE DURING SPIN CYCLE
You have to take the tub out, take off the rotor from the bottom of the washer, remove 4 bolts and take off the stator, take off the bearing retaining nut, then drive the 2 bearings out with a drift. I bought the bearings online for 20 bucks from a supplier (VBX). They are standard metric bearings number 6005 and 6006. I put some silicone grease on the shaft seal and drove the new bearings into place. Then reassembled, and the washer is whisper quiet.
Jul 20, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Loud sounds coming from the washer on spin cycle
That is a characteristic of bearings gone bad. You should look into replacing the bearings.
Mar 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio Washer
it is the bearing, call 1800-905-9505 and ask for a service smart agreement cost about 200 and it will cover your washer for 1 year parts and labor and the machine will get fixed
Feb 14, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
42 people viewed this question
Dan Webster
Dan Webster
Sal De
