Question about Spektrum Dx6i Computer Radio
WHEN SWITCHING ON THE TRANSMITTER IT BEEPS AND FLASHES F MODE AND T HOLD
  • john_higg81 Mar 26, 2011
    TRIED THAT NO DIFFERENT! STILL THE SAME!
Have a 1998 xj8 car drives no probs opens no probs with key but after a recent batery disconnect will not open the car with remote
Since you lost power your "fob" and receiver may not be communicating any more.
This is a process to for your fob to re-sync with your car.
Note : All transmitters being serviced must be available. If the learning process is carried out without having all the transmitters present, all previous transmitter codes will be overwritten, rendering the missing transmitters inoperable.
Hold headlight flasher back.
Turn ignition key to position 1.
Flash headlights 4 times.
Alarm will enter programming mode.
This will be confirmed by "beeps" from the alarm and flashing led on gearshift.
Program each transmitter (up to 5) by pressing the lock or unlock button on each transmitter once.
The alarm will "honk" when you press the transmitter button.
The alarm must honk 5 times to complete the programming. Therefore, if you are only programming one transmitter you should operate the transmitter 5 times.
If you are programming two transmitters you will operate one transmitter twice, and three times on the other.
For five transmitters you will operate each transmitter once.
Good Luck!
Oct 16, 2013 | 1998 Jaguar XJ8L
Skytech 1410 fireplace remote (8 yrs. old) has stopped working. Replaced batteries in the transmitter. The red light lights up when
It may need to be re-synchronized:
Make sure the receiver's slide switch is in the REMOTE position.
Press and release the LEARN button on the receiver.
When you hear the "Beep", press and hold the ON or OFF button for about 2 seconds on the transmitter.
You will then hear a series of beeps that indicate that your new transmitter has been accepted by the receiver.
If you press the LEARN button on the receiver and you hear no beeps, the receiver is unable to retain any more transmitter codes
(make sure the transmitter battery is properly installed and fully charged).
To delete all of the transmitter codes on your receiver, press and hold the LEARN button for 10 seconds. Then you will hear a
series of beeps, indicating that the receiver's memory has been cleared.
It could also be dead after 8 years. A new unit can be purchased here: Skytech Remotes. I would even suggest on of the new styles with a built in timer or thermostat.
Nov 08, 2012 | Skytech 1001-A Fireplace Remote Control...
How to set the date
Time and date setting
are only necessary if automatic setting by radio broadcast is unsuccessful.
To set time, date, and options:
1) With time and day showing, press and hold SET.
2) City code flashes. Press START/STOP to select city that represents your time zone. See table below
for city codes.
3) Press MODE. DST (daylight savings time) setting flashes. Press START/STOP to select AUTO (obey
setting in radio signal), ON, or OFF (disregarding setting in radio signal for ON/OFF).
4) Press MODE. Hour flashes. Press START/STOP to change hour (including AM/PM); hold button to
scan values
5) Press MODE. Minutes flash. Press START/STOP to change minutes
6) Press MODE. Seconds flash. Press START/STOP to set seconds to zero.
7) Press MODE. Year flashes. Press START/STOP to change year.
8) Press MODE. Month flashes. Press START/STOP to change month.
9) Press MODE. Day flashes. Press START/STOP to change day.
10) Press MODE. Date flashes. Press START/STOP to select M-D (month-day) or D-M (day-month) format.
11) Press MODE. Hourly chime setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch chimes on every hour.
12) Press MODE. Button beep setting flashes. Press START/STOP to select ON/OFF. When ON is
selected, watch beeps for every button press.
13) Press SET, at any step, when done setting.
Press and hold MODE to switch between 12- and 24-hour time format.
Press SET to view date. Year is at top of display and date is below.
Press RECEIVE to view current city.
Press and hold RECEIVE to begin manual reception of time signal, as described in ATOMIC CLOCK
SYNCHRONIZATION section.
(from the User's manual)
May 03, 2011 | Timex 1440 Prizefighter 53032 Sports...
How to program a 7752V VIPER REPLACEMENT REMOTE
Open driver door.
Push and hold "f" key until remote beeps.
Push remote start button once so "pair" appears on screen. Push and hold "f" until remote beeps three(3) times to select pair mode.
Insert key into ignition an turn to "ON" position.
Push and release "valet" button on antenna, push again and hold until remote emits a series of beeps and displays "passed"
Feb 08, 2011 | 7752V Replacement Transmitter Supercode...
Wired unit asper instructions. try to program unit, starting with transmitter. cycled key as says ,then with in 15 seconds bushed progrm button twice holding in on 2nd time, parklights flash and led...
you need to push it 3 times and then hold, to program the unit for tach, voltage or timer. It will not work until you actually program the unit on HOW YOU WANT IT TO START.
Jan 30, 2011 | RS60 Stand Alone Remote Car Starter System...
How do you program the keyless remote on a 2002 Intrigue?
1. Close the vehicle doors.
2. Turn OFF the ignition.
3. Remove the key from the ignition.
4. Press and hold the driver side door lock switch in the UNLOCK position.
5. Insert the ignition key into the ignition lock cylinder and remove the key. (Do not turn the ignition key in the lock cylinder.)
6. Insert the ignition key into the ignition lock cylinder and remove the key. (Do not turn the ignition key in the lock cylinder.)
7. Insert the ignition key into the ignition lock cylinder. (Do not turn the ignition key in the lock cylinder.) Leave the ignition key in the ignition lock cylinder.
8. Release the door lock switch. The vehicle will sound three beeps in order to verify the Program Mode has been activated.
9. Press the LOCK and UNLOCK buttons together on the keyless entry transmitter and hold until the vehicle beeps twice to verify that the transmitter has been successfully programmed (this take approximately 15 seconds).
10. Perform the previous step to program up to four transmitters (including your old ones).
11. Remove the ignition key in order to exit the Program Mode.
Good luck and thank you for using Fixya
Mar 09, 2010 | 2002 Oldsmobile Intrigue
How to set up garage door opener on my 2002 diamante
Detail Instructions from the owner's manual 1. Turn off engine
2. Prepare transmitter by erasing all three of the factory default channels by holding down the two outside buttons until the red light begins to flash. Release both buttons.
3. Hold the end of your hand-held transmitter (garage door remote) against the Homelink transmitter keeping the red light within the Homelink icon in view.
4. Using both hands push the hand-held transmitter button and the deisre button to be programmed on the Homelink transmitter. Do not release the buttons at this time.
5. Hold down both buttons until the red light on the universal transmitter flashes, first slowly then rapidly. When the light flashes rapidly, release both buttons.
To program the remaining two buttons, follow steps 3-5.
Jan 17, 2010 | 2002 Mitsubishi Diamante
Can you give me the instructions for programming the remote for a 1999 Jaguar XJ8. Thanks! Alan Broyles
  1. Hold headlight flasher back.
  2. Turn ignition key to position 1.
  3. Flash headlights 4 times. Alarm will enter programming mode. This will be confirmed by "beeps" from the alarm and flashing led on gearshift. Program each transmitter (up to 5) by pressing the lock or unlock button on the each transmitter once. The alarm will "honk" when you press the transmitter button. The alarm must honk 5 times to complete the programming. Therefore, if you are only programming one transmitter you should operate the transmitter 5 times. If you are programming two transmitters you will operate one transmitter twice, and three times on the other. For five transmitters you will operate each transmitter once.
Mar 12, 2009 | 1998 Jaguar XJ8L
Need to program autopage 5b remote
Note: This mode will only retain the last 4 remote transmitters programmed. If the transmitter memory is exceeded,
the security system will start deleting transmitters from memory in chronological order.
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in ON position. Within 15 seconds.
2. Push the Valet switch 3 times and holding in on 3rd push until a long chirp is heard then release the valet switch.
You are now in the Transmitter programming mode.
3. Press and hold any button of the transmitter until the siren responds with a confirming chirp, indicating the signal
has been stored into memory.
4. If you have additional transmitters (up to 4) that need to be programmed, repeat step 3 for each transmitter.
Exit: Turn Ignition to 'OFF' position, or leave it for 15 seconds. 3 long chirps & 3 parking
light flashes will confirm exit.
Feb 17, 2009 | Megatronix - TW71 - 5 Button 2 Way LCD...
Spektrum Dx6i Computer Radio Logo
195 people viewed this question
Top Spektrum Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Spektrum Toy Expert? Answer questions, earn points and help others
