Question about GPS
Where can i find wiring diagram for GEMINI ALARM SYSTEM 861?
5 Suggested Answers
jpk528
  • 95 Answers
SOURCE: install alarm system
Battery- RED RED (+) IGNITION SWITCH HARNESS (2 CONST WIRES)
Ignition 1- PINK (+) IGNITION SWITCH HARNESS
Starter 1- YELLOW (+) IGNITION SWITCH HARNESS
All Door Trigger- WHITE (-) SMALL HARNESS BELOW ASHTRAY
Trunk Trigger- RED/BLACK (-) AT TRUNK LIGHT
Parking Lights- BROWN (+) BEHIND FUSEBOX UNDER CONSOLE OR SWITCH
Power Unlock- WHITE (+) POSITIVE TRIGGER OR DRIVERS KICK PANEL
PowerLock- LIGHT BLUE (+) IN CENTER CONSOLE "BEHIND FUSEBOX"
Posted on Apr 12, 2009
Rickygittins
  • 715 Answers
SOURCE: Need a wiring diagram
www.wiring-diagram.com/purchase.htm I found mine for a small price, very good diagrams.
good luck
Posted on May 28, 2009
SOURCE: 1994 crystler labaron alarm system deactivation
I have tried all the solutions for this problem and I still cannot get it to shut off my car alarm system on a 1994 Chrysler Lebasron Convertible GTC? Any other solutions?
Posted on Dec 14, 2009
toplus_lee
SOURCE: Wiring diagram of alarm system for Myvi
Posted on Mar 04, 2015
Wiring diagram for gemini gourmet multifunction thermofan
Request the wiring diagram directly from Gemini.
Feb 09, 2017 | Ovens
Gemini 4001 alarm
I got a replacement aftermarket alarm fob at: http://www.remotesunlimited.com/car_alarm_remotes.php
Sep 15, 2013 | Vehicle Parts & Accessories
I bought a home with this system and need to be able to use it. Who can help me set it up?
i bought a home with a gemini system in it / i dont have the old codes can i reset this key pad
Oct 07, 2011 | Gemini Sound Products Gemini Napco...
Gemini home security system needing disabled
yes the system has to be powered by something most times there is a security panel that all the wires run back to, their should be a transformer pluged into the wall somewhere or on the panel itself there should be a red and black wire that is hooked up to power in or 24v in, disconnect these wires or just take the fuse out if it has one. more than likely you will see the power supply. if not take a insulated srew driver and run it across the power contacts on the main board.
Dec 01, 2009 | Gemini Sound Products EQ-300 Home...
I have a JVC TM 9060U and a JVC BR 9050U (CCTV Monitor and recorder) which interfaced with my Gemini 3200 alarm system. I can't find any diagrams or instructions for the hardwire connections provided which...
The Napco GEMP3200 Control has 2 built-in alarm outputs. One on terminals 3, 4 & 5 and the other 6, 7 & 8. The first output is normally for burglary and is factory set for 12VDC output on terminals 3(+) and 5(-). If you don't have sirens in your system you can convert this output to a dry (no voltage) relay output by cutting Jumper B on the circuit board which is just right of those terminals. Likewise terminals 6(+) and 8(-) can be used as a relay output by cutting Jumper A which is also right of the terminals. However to use this output you will have to reprogram the system to make this output for burglary also. The easiest way,if you are currently using sirens in your system, is to go to a local electronics store and purchase a 12 Volt DC relay module for about $15. Run wires from terminals 3 & 5 to your relay's + and - inputs. The relay should provide a dry closure output which you can then run wiring to your recorder. When your system alarms it will not only set off your sirens but also trip the relay.
Nov 27, 2009 | Home Security
Manual for a Gemini 7200 car alarm
hi i have gemini 7200 and the sensor is to high its pick while the car passing right beside dont know what to do and when i turf off the alarm with the keys central lock doesnt work than need help
Nov 16, 2009 | Vehicle Parts & Accessories
My gemini car alarm system has stopped responding to my key fobe, iv'e changed the battery in the fobe to no avail. The red light on the car alarm system dose not flash or show any signs of life, is there...
it may have some lose wirings thats why its not responding, try checking the cables or the connectors of the alarm. if its all intact then you may need an alarm replacement. hope this helps.
Jul 03, 2009 | 1998 Volkswagen Passat
Re: Gemini car alarm 7208-7218
hi i am greek and i lost my manual of my car-alarm gemini 7208.can you help me?my email is jigi1313@yahoo.gr
Dec 09, 2007 | Car Audio & Video
GPS Logo
76 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
