Question about Behringer Pmp3000 16 Channel Audio Mixer
I have the PMP1680S and the vocal effects do not work, a friend researched this and found it to be a common problem with this unit, thank you
  • Behringer Master
  • 5,603 Answers
The most common problem is improper setup.
One needs to control the FX SENT to the effects unit with the FX1 and FX2 controls for each mic channel. You should see the levels on the tiny histogram alongside the effects selection dials/indicators. Next select the effect number you want so it is displayed in the window. Then PUSH in on the selector for each of the two effects to activate the selected effect. Now, lastly advance the FX to MAIN knobs to control the amount sent to the main mix. Some of the effects are subtle so try different ones.
Posted on Mar 26, 2011
I have a Peavey XR 8600 PA, I have tried adding an external vocal effects module into a mic line but it drops the output volume of the entire PA by about 75%. Any ideas why this is?
Well, I would say it isn't dropping the level of "the whole pa", it is just dropping the level of the input you have plugged the fx into. Check the settings on your fx unit, there are usually input, output and mix controls that are independant of "the pa" and affect the amplitude of the signal going into your mixer from the fx unit.
Nov 01, 2017 | Peavey Music
Effects quit working on Acoustic AG30 amp. what are the likely problems and costs to repair?
I am guessing it is solid state? If it were tubes it would be an easy fix but the solid state amps are very hard to diagnose and repair. I think the Guitar Center has a repair department and they probably know the trouble shooting steps. I am guessing it is a board, but the way to trouble shoot would be to know how much current should be flowing to individual leads. I do not have this information, but you will need a multi meeter in order to start the process. No reputable repair shop should charge you any thing to give you an estimate.
Oct 09, 2014 | AMP Acoustic Ag30 30w 1x8 Acoustic Guitar...
The vocal cuts out completely from time to time. Comes back after a while but keeps cutting out at intervals. Have two of these and both do it. Is it my set up, is it overload in some way. Guitar ok. Use...
The amp or pre-amp for the vocals built into the unit is failing when it gets warm. This is a common problem with electronics, that when it cools down cures itself until it warms up again a few seconds later.
The units need repair or replacement.
Dec 22, 2013 | DIGITECH VOCALIST LIVE 2
VoiceLive
I had this problem. I sprayed the switches with contact cleaner from outside and jiggled them a bit. I also powered it from a different socket. The problem has not recurred since.
Oct 22, 2017 | TC Electronic TC Helicon VoiceLive Touch...
I have a Fender Acoustasonic DSP 30 (Two 8" speakers) and recently my effects on both the instrument and vocal channels have topped working at all. I heard a small woooosh and a light pop sound, so...
Wrong assumption ! Most likely an electrolytic capacitor blew up. If you open the unit it should be obvious... it MAY also have taken out another component(s) as well. They can make a mess so clean up any residue as it will cause corrosion. Use distilled (non-ionic) water to clean up the residue. The little cans sometimes blow off or spit at the top and spew white crud all over.
Apr 13, 2011 | Fender Musical Instruments Corporation...
No vocal sound
It sounds like the guitar level input to the unit is too low.
NOTE: With this product you MUST use an amplified or electric guitar that has a preamp within it.
If you have a straight guitar that does not have an amp in it, buy a preamp to first run the guitar through.
Apr 26, 2010 | DIGITECH VOCALIST LIVE 2
Fostex MR 8 HD\CD adding treble and bass?
It APPEARS that the MR8 does NOT include the ability to EQ. They have delay effects and the like built in, but no EQ.
To answer your question then, you would need to have an EXTERNAL EQ unit and loop the vocal through that unit to do EQ to do it right.
When mastering, the "powerful/natural/and bright would be filters that will emphasize the bass (powerful) or the treble (bright) but these are really not EQ's and you can ONLY choose one at a time.
Jan 13, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
I need to output guitar and vocal separately. No matter how I hook it up guitar comes thru the vocal channel
Hi there. Use the "pan" pots to assign the guitar to left channel and all other pans to right channel. Also, turn all effects off or down all the way. (Effects return all the way down.
Thanks
Paul
May 03, 2009 | Digi-Tech Digitech Vocalist Live 4...
Behringer Pmp3000 16 Channel Audio Mixer Logo
128 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
