Question about Ovens
My wife said it seemed to go crazy and spark inside the oven compartment
  • Ovens Master
  • 43,501 Answers
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Posted on Mar 26, 2011
Cant find where the battery is for the gas ingnition
Hi, Usualy the battery is inside a service panel right at the bottom, it may be inside a little plastic box or compartment with a spark smbol on it.
Aug 06, 2011 | Ovens
Model h4080 bm smoke and sparks come out of the circular cover? on the inside top of the oven compartment whats wrong and how to repair?
The insulation on the wiring has broken down and the metal on the wires has come in contact with the metal frame of the oven...this causes the wires to short and throw sparks...
Remove the cover and repair/replace the wiring with wire that is rated for extremely high temperatures...
This often happens as a result of using the self clean feature on many ovens... the temperatures get too high and ruin the wiring...
This is probably not a job for the normal DIY'er....
heatman101
Dec 26, 2010 | Miele MasterChef H 4080 BM Electric Single...
Help! I have a GE Oven and the oven won't light. I have replaced the ignitor already. Still doesn't work. The ignitor does not glow, there is nothing. Checking the volts at the oven temperature selector,...
Check the voltage at the ignitor connections.
If low voltage is not there,replace the oven control.
I can not be more specific without a model number.
Nov 27, 2010 | GE Ovens
I saw sparks? or small flame on back wall behind fan inside oven
It sounds likely that the fan motor is faulty,more so if the oven is heating to some extent.
You should be able to see or hear if the fan is working or not
Hope this helps with your prob.
Nov 26, 2009 | Gaggenau EB 270/271 Electric Single Oven
Electrice oven not working
Hi.
You are quite correct in saying that a new element will solve the problem.
It is usually located at the rear of the oven compartment behind a removeable cover.
Please rate my comments.
Thanks.
Nov 20, 2009 | Frigidaire Ovens
Neff B1432 oven element and fan not working
If the element has failed again in such a short time , then I would suspect that the fan is the culprit.
If the fan is not working, then the element overheats, and burns itself out.
The fact that the fan spins freely, proves nothing, as the fan can be still faulty.
The only way to prove if the fan is faulty, is to remove the oven from the housing, and remove the rear outer panel of oven,.test with a meter set to ac mains and test the fan motor terminals to see if there is power there when oven is set to heat, disconnect the element first. ,if there is ,and the fan is not running then the motor is faulty..
If there is no voltage there, then problem is elsewhere, and you will have to investigate furher.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff B1432 Single circotherm plus Electric...
Turning on grill blows fuse on Electrolux EOG7330WN
get i an accredited electrician to check the grill element and fitting
there is a dead short in that area
Apr 23, 2017 | Electrolux EOG7330WN Gas Double Oven
Starter
Sounds like one of the control knobs got stuck or shorted in the start cycle. Can you get access to the inside where you can see each of the control knobs? Look for wiring and unplug one at a time. This may help you figure which one is shorted.
Mar 21, 2008 | GE JGRP17 Gas Single Oven
Ovens Logo
49 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
