Is it hard to connect a router and what kind would you recommend. I am not that swift with things like that and my hubby sure isn't. Do I need an electrician to come in???? Thanks so much, JJ
  • 112 Answers
No need for an electrician. Routers are pretty easy to set up, the included instructions are really all you need. I recommend Netgear for beginners as I find their instructions the best, and they are decently priced at local stores. If you need any help in setting one up, or find the instructions confusing, feel free to comment back on this post, and I'll help you with everything.
Posted on Mar 26, 2011
Testimonial: "Thankyou so much. I appreciate your quick respons. Hopefully I dont have to contact you, but I will if I have. Thanx again, JJ"
Requiring password
If your wireless access suddenly requires a password, one of two things has happened...
either you are inadvertently trying to connect to a neighbor's wireless router, or someone has modified your router.
If you are certain it is your router you are attempting to connect to, and it is requiring a password you did not setup, your best bet is to perform a hard reset. There should be a reset button on the back of your router. You should press and hold this button for a few seconds. This will clear all setup information and return the router to factory setup.
In order to setup your router from this point, you will need to connect directly to the router, perform whatever setup options you prefer, and then you should be able to connect wirelessly.
It is highly recommended that you setup a password for wireless access. It is also recommended you change the admin password to prevent someone else from making unwanted modifications.
Jun 18, 2013 | NetGear N600 Wireless Dual Band Router
Do i need a router to get internet?
Not familiar with the Ninento DS, but if it has wifi capability then yes you will need a wireless router in the mix for it to connect to the internet at your home. I would recommend enabling security and changing the default password as a minimum if you get a wireless router. However it isn't a requirement to get it to work. Simply buy the wireless router, connect an ethernet cable from the wan/uplink/internet port on the router to the ethernet port on the cable/dsl modem and connect the power. That is the minimum required steps to setup wireless.
Nov 05, 2011 | Nintendo DSi White Console
I have a um175 pantech and can only connect on the desktop and not on my laptob.
There's a few things that can cause wifi connections to not work.
The most unlikely is just an incompatibility between your router and the wifi USB adaptor. There's not much that can be done then, except changing to a different adaptor or router instead.
Things you could check include:-
Make sure the router allows both kinds of wifi speed (B & G types - just to avoid errors while you test it)
If using any WEP passwords, make 100% sure you are using the right one - many people get a password just slightly wrong but are sure they haven't.
Make sure the router signal is strong enough to connect properly.
Make sure your router is able to have enough wifi connections (many are limited to 4, and neighbours may be using your connection too! pushing the router past its 4 limit).
All routers can have security settings tha can block in many ways, so if you didn't set it up yourself originally, whoever did may have put extra settings in place for protection.
Try having your laptop connect to another router - maybe at a cafe, library or friends house. This will narrow down the fact that it's your own router doing something wrong.
The first thing I would try before anything else is:-
If possible, connect using LAN a cable first, as that should work instantly - note that your firewall (if using Windows) may automatically block internet connections, and that would need sorting out in Control Panel first. You would usually use any CAT 5 or CAT 6 network cable (any length), of a 'cross-over' type. A cable of this type is sometimes included in the routers box if bought as new.
Good luck with it.
Nov 09, 2010 | Dell Computers & Internet
Pasword protect my router how?
There are two kinds of password protection for your ROUTER;
(1) The Web Interface can be password protected by changing the default password
(2) The Wireless connection password (encryption)
Which one do you want enabled to protect your router?
Jul 27, 2010 | NetGear WGR614 Wireless Router
I have my D-Link DIR-616 C1 connected t my desktop computer. I have AT&T high speed internet and it is connected through the router. Everything works fine with the desktop. My problem is with my...
you will need to add the wireless network manually.
First you will need to remove the network from the prefered network list. I believe the Operating system on the computer is XP. and the security on the wireless network is WEP. make sure that you are typing the correct network key.
Click here for more information about routers and network
Feb 11, 2010 | D-Link DIR-615 Wireless Router
How do I get my wireless internet connection to work? I live in a rural area and NETGEAR is the only option with at least 3 bars. Where do I find my network security key? I'm a definite rookie here....
If you live in the rural area and you have a broadband connection/modem connected to the Netgear wireless router, then I suggest you look at my instruction on how to configure the wireless router with encryption (security) - click on this link for instructions. :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 11, 2009 | Sony Computers & Internet
I have reset my tw100-s4w1ca trendnet router,but still default username and password dont match
There are two kinds of resets in a router. Soft reset(reset the connection) and hard reset(reset all the settings). I think what you have performed is a soft reset. To perform a hard reset press and hold the reset button for 10 seconds. Please be aware that if you perform a hard reset you will have to re-configure your router before you connect to the internet, so make sure you have the settings handy. The default username and password is usually admin or Admin.
Let me know if you need further assistance configuring the router.
Sai.
Oct 12, 2009 | Trendware TRENDnet TW100 S4W1CA...
How to connect two remote device with a phone line in between.
no, not with a phone line... you could but making a bridge connection with an utp cable... but with all respect, if you were thinking about a telephone cable you are surely not qualified to do that bridge without assistance... so i recommend the following.
You surely know that UTP cable (lan cable) supports a distance up to 90 metres which is about 295 feet. If you need to go outdoor for that connection i would recommend outdoor cable for that connection its very cheap... and you dont need two routers if you just have four computers tops...
other stuff like amplify antennas might help your reach the far away computer via wireless...
other way is to find info on how to build a bridge with two routers on the net by searchin on google, its not that hard, but you still need utp cable... never phone line.
Mar 17, 2008 | Computers & Internet
Linksys wirless g broadband router
I will need the model number to better assist you.
Jan 03, 2008 | Computers & Internet
Can't Ping D-Link Di-704P
Hi, A couple of things you can try: 1. verify that your LAN cable from router to PC is good. There should be some indicator LEDs lighting up when connected/linked; 2. Co to Start, Control Panel, right click on your Local Area Connection, Properties, highlight Internet Protocol (TCP/IP), click on Properties, tick Use the following IP address > IP address 192.168.0.254; Subnet mask 255.255.255.0; Default gateway 192.168.0.1, OK; 3. Check if you can ping 192.168.0.1; 4. If not, you may need to do a hard reset your router. Pls be reminded that all configurations on the router would be reset to default; 5. If the reset does not work, then perhaps the router would need replacement. Hope this be of some idea/help. Pls post back how things turned up or should you need further information. Good luck and kind regards.
Sep 21, 2007 | D-Link DI-704P Router
Computers & Internet Logo
171 people viewed this question
Alun Cox
David Payne
David Payne
