Question about Qep 60020 24Inch Dual Speed Tile Saw with Stand
I have a work force wet saw with a water pump. Does the pump go in the tray with the water?
Where do you put the water?
Most wet saws have a water tray below the table area. The blade moves thru this tray and gets cooled and lubricated by the water
Mar 06, 2015 | Qep 60087 Table Tile Saw 7" Wet
TILE SAW WON'T SPRAY, PUMP AN MOTOR RUN CHECK FOR DEBRI HOW DO I CLEAN TUBING TO SPRAYER I THINK IT IS CLOGGED
Make sure pump is submerged i water
Remove tubing from pump discharge and see if pump is pumping water/ If so your tubing is clogged between pump and saw. Remove tubing and rinse out with hose.
Nov 28, 2012 | Ryobi Saw. 3/4 HP 7 in. Wet Tile Saw WS721
I have a wts2000l and i have noticed that it is burning through blades. The water is pumping through but isn't hitting the blade at all. The water is spraying in opposite directions, I can't seem...
you just have to lift the blade guard and tweek the direction of the outlet, point them so they're spraying towards the blade. Not right at the blade but just so they're getting plenty of water spraying onto the tile. Don't put a bucket and catch the water "over flowing" from the tray, just drain the pan and put the bucket under the drain hole to catch the water. A lot less messier that way.
Aug 05, 2011 | Ridgid Wts2000l 10" Wet Tile/stone Saw...
Rigid wts2000l WEt saw is not sending water to blade even though it is in on position
look for weak pump, or blocked pump pick up.
I have a similar saw, and the pickup at the pump gets pretty grimey, and ned to blow it out once in a while to keep it clean and of cake like tile paste. also check the hoses for splits and/or cloggs.
Jan 07, 2011 | Ridgid Wts2000l 10" Wet Tile/stone Saw...
Cannot keep water on the blade of my 10" Rigid wet
if waters not getting to the blade you will see the powder of what ever your cutting coming off the back of machine,i like to put my pump in a bucket of water under the drain plug instead of puting the pump in the water tray,you can run bigger tubing up to the blade and reduce it down and it will give you better presure,good luck
Dec 31, 2010 | Ridgid 10"Wet Tile Saw with Laser and...
Ryobi 7" wet saw. water
Direct the water on to the slate itself just ahead of the cut. When you spray the blade, centrifugal force causes the water to fly back off. Good luck!
Nov 07, 2010 | Garden
Ryobi WS720S wet tile saw. Will not spray
Check the pump operation and pump intake screen for plugging. Make sure the water reservoir is not full of cutting debris.
Jan 24, 2010 | Saws
Ridgid Wet Tile saw water pump operates, however the water is not getting directed onto the blade. Hose partially plugged? How to clean nozzle?
You could clean the hose ... however, I think Id get to the hardware store and get a new piece.
Clean the end with a broom straw. You could trim a small piece of the hose off. Dont neglect to clean the filter on the pump. Slide the bottomoff the pump to expose the filter.
Oct 21, 2009 | D Cut CS-070 Wet Tile Saw
Pump has lost its prime. how do i get it to pump water again?
If the pump works but no water coming out try to do the old way of putting water from the side that the water come from and start the pump that reduce the time to build pressure and limited the air inside…Hope that help you and please do not forget to rate my service to be able to improve on it and help everyone.
Sep 19, 2009 | Mk Diamond MK - 170 Wet Cutting Tile Saw
How to fix a tile saw pump
take it all apart and clean it completely. They do not put pump in saw water, use only totally fresh and clean water.
Jul 14, 2009 | RTO 6391K Felker 24" Tile Master Plus Wet...
Qep 60020 24Inch Dual Speed Tile Saw with Stand Logo
Top Qep Saws Experts
JOHN LAPIER
Terry Hair
Tom Chichester
Are you a Qep Saw Expert? Answer questions, earn points and help others
