Question about Kenmore 98702 Stacked Washer/Dryer
Hotpoint washer VBXR1090B0WW
MY WASHER AGITATES and pumps fine; but will not spin. The belt looks fines; but it wont spin. help
    Champion:
  • 210 Answers
Check the lid switch.
Posted on Aug 07, 2008
I have a top load washer model LSR 8433 KQ0 the machine will not spin but agitates, rinses, drains fine but when it clicks to the spin cycle it just pumps out any water and does not spin. Would this b
Either the belt broke or the hood switch is not working. Sometimes it could be the contacts in the main control knob but if everything else is working correctly, then check the belt, and the hood switch first.
Jan 11, 2015 | Washing Machines
Ras7233kq0 washer won't spin Washer agitates and
Check the belt on the drive system to the motor.if the motor is working the belt might be broken. If the belt is intact it could be a relay to engage the belt drive.
Oct 16, 2013 | GE WCVH6260FWW
I have a Maytag Atlantis MAV6200AWW Washer agitates and spins. Water sometimes empties. Pump is fine spins freely and the impeller is fine. Could it be the belt ?
You will need to check for an article of clothing stuck between the basket and tub that may be partially blocking the drain hole.
Nov 22, 2012 | Maytag Atlantis MAV6000 Top Load Washer
Will not spin on spin cycle
That is a single belt driven washer built by maytag. Check the lid switch for propah operation. If it is fine tip the washer back do an inspection of the beltthemobilian_2528.jpg
Check the pump for tightness sometimes they lock up or get something in em. If that is fine turn the main drive pulley and see if it releases the brake and lets the drum turn easily. One direction it locks the tub and agitates and the other direction is pumps out the water and spins.
Manual and more HERE
Jul 01, 2011 | Magic Chef CAV2000 Top Load Washer
Kenmore washer doesn't spin
the conection b/w the motor and the gear got damage you can get the part online and do it yourself.
you just need to take the pump out and the motor wich bouth connect by clips .
hop it help you
Jan 12, 2010 | Washing Machines
Washer wont spin or drain
did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
Feb 07, 2009 | Frigidaire Washing Machines
Maytag Washer, LAT2300AAE, won't spin
ok lets see here;your transmission can go in two directions.if you turn the middle pully one way it will agaitate if you turn the oppisit direction you can watch [from under neath]the brake raise as the cam seperates and lifts the brake.now with the brake lifted ,your tub should spin.if its not lifting the brake you need a new center pully kit[i have had to do many]it comes with washers ,bearings and cams.if the brake lifts and your tub still wont spin you may have a pice of clothing between the two tubs[i had that one to,many times]i hope that helps.you can email thru fixya if need more advice God bless ,tom
Jan 26, 2009 | Maytag Dependable Care LAT9706
My kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Washer won't spin
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
Sep 13, 2008 | Westinghouse WWS833ES Super Capacity Top...
Kenmore 98702 Stacked Washer/Dryer Logo
59 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
