Question about Kenmore Dryers
How to change timer control for Kenmore 41783142201 - top half of dial settings does not work. What is the part number?
  • Kenmore Master
  • 1,902 Answers
Hello & Welcome to FixYa
Please check this video for Timer part# 131960800 replacement:
Please get back to me if you have any other questions.
Kevin
Posted on Mar 26, 2011
11 year old Kenmore washer fills then stops.
in the machine under the front control panel will be a module that controls the wash agitation. Have it checked out as they fail . There is no connection between the timer and this unit as it comes in to play when the water reaches a set level. The timer just keeps working through the cycles believing the washer is agitating.
Jun 26, 2013 | Kenmore 24032\24036 Top Load Washer
Tip
Setting Your Timer
1. Move the control lever to the OFF-CLEAR position for about 20 seconds. The red indicator light will go off and any previ- ous time settings will be cleared from memory.
Program Using "Quick" Method:
2. Move the control lever to the ON position. The Red indicator light will start fashing.
3. Rotate the time dial clockwise at least one click, stopping at the half hour nearest to the present time.
NOTE: During programming, be careful not to press the dial while turning it. If you press the dial, you will ac- cidentally set a wrong time.
4. Press the dial once to set the present time. The Red indicator light will go off.
5. Rotate the time dial clockwise to the frst desired ON time. The Red light will pulse momentarily with each click.
6. Press the dial once to enter the ON time. The light controlled by the switch timer will turn ON.
7. Rotate the time dial clockwise to the desired OFF time.
8. Press the dial once to enter the OFF time. The light controlled by the switch timer will turn OFF.
Repeat Steps 5-8 for each additional ON/OFF setting. Continue to rotate the time dial until the Red indicator light comes ON and stays ON, indicating that the switch timer is in AUTOMATIC mode
on Oct 06, 2009 | RTO Intermatic Inc Ej351c Timer Night...
I have a kenmore 70 series heavy duty plus. my model number is 82372110. my washer will fill with water but when its time for it to start to agitate it drains the water then fills it and drains it the
Sounds like the main dial is gone on the top control panel. How a washer works, is the water level switch ( the dial that allows you to select the amount of water you want to wash your clothes in) sends a signal to the main dial, when the water level is full to turn on the agitate and the water to shut off. But it is emptying the water instead, so the main dial is skippiing the agitate cycle. If you take the back panel off the top control panel, you will see a mechanism behind the main dial. That is probably what needs to be changed. It costs anywhere from $120 to $180 for the part. You may want to invest in a new one instead but replacing this part should fix your problem as well. It is about a 2-3 out of 5 for someone without experience to fix. Not hard. Have you noticed any whining or abnormal mild grinding coming from the dial itself? This may be a clear indicator that the dial is on its way out.
Jul 18, 2012 | Kenmore 22422 Top Load Washer
We need clear instructions for setting the timer
Woods makes several outdoor timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Image that shows with this post is Woods model #49647.
Below are instructions for #49647 timer.
If your timer is different, add a comment with model number and I'll post instructions for that timer.
Woods model #49647 is outdoor timer with photoelectric control that turns timer ON at dusk.
There are 4 possible settings that show on dial.
Rotate dial to make timer selection.
OFF = timer is OFF full-time until you change dial.
ON = timer is ON full-time until you change dial.
Dusk-Dawn = timer turns ON at dusk and OFF at dawn
2, 4, 6, 8 hours = timer turns ON at dusk, and turns OFF 2, 4, 6, or 8 hours later.
Nov 26, 2010 | Woods Outdoor Lighting Timer
Fan is working but the condenser is doing nothing....I moved the fridge yesterday and today it is blowing cool but not cold air.
Check your defrost timer. It has a small dial that only turns one way. Turn it a half turn, if the condenser starts, the timer is bad.
Apr 29, 2009 | Kenmore 18.9 cu. ft. Top Mount...
Washer gets no power
are you sure the outlet has power? make certain by plugging in a lamp or something else to the outlet first. the timer does have to get power to turn on the unit, but its not likely it is the problem.
try a different cycle and see if it wont run on any position. like fill, wash or spin. then if your outlet is ok, it could be the timer.
i dont think it is but it could happen. usually if the timer fails, it will work on some cycles but not all of them. if it wont work on any cycle then i would expect the outlet first.
Jan 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore Washer timer dial is not advancing
ok " timer has a small stepper motor in it, and it can be replaced
take stepper motor out .
appliance parts store will have it
or just replace timer
take make and model number with you
Jan 13, 2008 | Washing Machines
Kenmore Elite, Quiet Pak II Top Loading Washer
there should be 2 screw on the left and right side of the console. remove the screws and the console flips back so you can get to the timer. youll have to remove the knob and dial from timer too to get to the screws that hold the timer in place. if you dont have a local appliance parts store in your area then you can order the timer at sears.com and theyll ship it to your house
Nov 24, 2007 | Kenmore 15944 Top Load Washer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
