Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
I have tried unplugging my side by sude Kitchenaid but its stopped working all together. Before today it would come on and off randomly..I would literally have to slap the back of the fridge to get it to come on and now that isnt even working.
    Guru:
  • 1,524 Answers
Change the "Motherboard"
Posted on Mar 27, 2011
KitchenAid Mixer struggling to spin?
Check everything you have done for a mistake, the pin through the planetary, the pin through the fuse gear and the pin in the main shaft that drives the bevel gear. That's the gear that pinion gear on the fuse gear shaft mates with. After that you are left with a fuse gear fault. I am assuming that the motor is turning at normal speeds and not somehow binding up, no reason why it should as motor stays in one piece during gear changing procedure.
Apr 18, 2014 | KitchenAid Food Mixers
Tip
Too many suds in your clothes washer?
Washers built today use less water and energy than ever. With this reduction in water a reduction in detergent is needed. Detergent manufactures along with the assistance of appliance manufactures have developed HE or high efficiency detergents to use in the washing machines we buy today.
This detergent is low sudings and is very concentrated to effectively and efficiently clean your laundry. Always use the recommended amount on the label and no more. Do not use not HE detergents or additives that are not recommended for high efficiency machines or sudings may occur.
The over sudsings can cause poor washing, odors due to residue left in the machine and on laundry and poor drying as the washer may not be able to extract the maximum amount of water from the clothes. Washer failures caused by excessive suds can include odors, premature bearing wear, motor failure and an array of failure codes that can be hard to troubleshoot at times.
Other clothes washer issues:
ODORS http://www.fixya.com/support/r4621314-odor_from_towels_or_clothes_washer
Wont Stop Filling http://www.fixya.com/TipsAndTricks/preview.aspx?thid=4621172
Control Locked http://www.fixya.com/support/r4624473-control_locked
on Apr 23, 2010 | Washing Machines
Dispenser panel
Is KSRS25ILSS the correct model number? Check the pin plug that is under the hinge cover on the freezer door side to insure it is together snug, Sea Breeze
Jun 13, 2013 | KitchenAid KSRS25ILSS Side by Side...
Can not get printer to copy 2 sudes of a paper
Try to unplug and replug the printer into the power source to reset it. When the printer turns on, try to copy 2-sided again. Refer to the Lexmark 7500 Series User's Guide for the step-by-step instructions on how to copy on both sides of the paper.
Notes:
  • Use only plain paper in Letter or A4-size. Do not make duplex copies on envelopes, card stock, or photo paper.
  • You cannot print duplex through the PictBridge port.
May 22, 2011 | Lexmark X7550 InkJet Printer
My keyboard just randomly stopped working and I don't have a warranty. I'm very upset, this is a used phone, but today the keyboard just stopped working. And ,y phone is an LG Voyager
on ebay you can buy phones just for parts if your handy or know someone who can take your phone apart and put it back together that will work
Mar 10, 2010 | LG VOYAGER VX10000 Cellular Phone
Right side stopped working
In the manual:
Check to see if the toaster is plugged in; if it is, unplug the toaster, then plug it back in again.
A tone will sound when the toaster is plugged into a live electrical outlet.
If no tone sounds, check the electrical circuit the toaster is connected to -
is a fuse blown or a circuit-breaker tripped in your home?
At least with "unplugging and plug it back again in the electrical outlet" the right side of our toaster works again. The tone that should sound with plugging in didn't work...
Aug 15, 2009 | KitchenAid KPTT890 Pro Line 4-Slice...
KitchenAid KSBP25FKSS Side by Side Refrigerator Ice & water dispenser ondoor not working
I had the same problem and had to have the entire door replaced. I thought it was a random thing since sometimes it would just start working again, but finally it just stopped for good. The wires that
are below the door on the left hand side (you can see them better when the lower front piece is removed) were severed and they can't be put back together without replacing the door. My repair guy (the refrig. was still under warranty) told me it was a design or installation defect and that he has seen it time and again. Evidently, when they install the wiring, they don't leave enough room to stuff the wires out of the way of the closing door and eventually, it severs them over time.
Oct 27, 2008 | KitchenAid KSBP25FKSS Side by Side...
Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Aug 02, 2007 | KitchenAid KSCS25FKSS Side by Side...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
