Question about KitchenAid Dishwashers
I have a kitchenaid KUDKO3CTSS3 stainless steel dishwasher and it appears the middle sprayer has stopped working. I took it apart last last weekend for cleaning hard water issues and I thought clearing out the ports would have worked but with no luck...any suggestions...
SOURCE: want stainless steel front door for dishwasher
There are a couple of ways to do this. The easiest one is to check out www.applianceart.com and they have many different options for "wrapping" the front of your dishwasher. They change it often so if you don't see it, call the company becuase I know they have it.
Posted on Jul 11, 2009
milten1
  • 1304 Answers
SOURCE: I have a stainless steel Kitchenaid dishwasher and
there a good chance the springs popped
or the ropes came off the pullys take off the toe kick and peek in on the edges you should see exactly whats going on
Posted on Oct 03, 2009
MIlfordPrint
  • 90 Answers
SOURCE: I have a Danby countertop dishwasher.
You may be able to find your answer at the link below:
http://www.retrevo.com/support/Danby-DDW1805W-Dishwashers-manual/id/886dj686/t/2/
Posted on Oct 05, 2009
SOURCE: Sprayers Will not work.
so what is the problem fills but wont spray
Posted on Nov 05, 2009
  • 246 Answers
SOURCE: Want to replace dishwasher panel with stainless steel
Yes indeed! If you know the measurements, you can buy a stainless panel from www.applianceart.com cut to any size you would like. THey also have a cheaper "faux" stainless option too. Many colors and designs as well.
Posted on Feb 25, 2010
My dishwasher door springs appear not to work and will not hold the door open. How do you replace or reattach the springs? Thanks, JoAnne
they actually arent springs, it is a cable and has probably broken or come apart. You can order this part through KitchenAid and replace yourself. Or call a repair rep.
Feb 10, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Four months new dishwasher, stainless steel inside....glasses are being pitted. This is for my next-door neighbour so I don't have a model number etc. thanks Carol Scott
Make sure that there is no grit in the water inlet or in the sprayer arm itself. You can imagine what particles like that can do to glass. I would take it apart and make sure that it is completely rinsed. Also, make sure the tub filter is cleaned as well.
Dec 21, 2010 | KitchenAid Dishwashers
Reattaching sprayer arm?
This is a backward (left hand) thread, when you put the spray arm back on to the nut turn the nut to the left.
If you need more information this link shows how to clean out the sump (which you do not necessarily need) but it also has a picture of how the lower spray arm pieces fit that might be helpful.
May 01, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Top rack dishes not getting clean
Hey- Two things could be wrong.- clog, or bad motor. Sump screen needs to be cleaned of debris. Removal of sump cover to access screen requires torx bits and some patience. Replacement of pump requires pulling out dishwasher to access bottom. Motors fail when seal between motor and pump fails. Will still operate, but become weaker over time. Parts available- motor about 100$ at appliance parts pros.appliancepartspros. Hopes this helps- Thanks- ED
Feb 26, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
The top sprayer or cleaning system doesn't seem to be working,bottom works but glass seems to have a film to it
1)check the boiler tank scaling formed.(clean the tank)
2)check water pressure.(solenoid filter get block)
Jan 07, 2010 | KitchenAid 24 in. KUDI02FRSS Stainless...
My Kitchenaid dishwasher not cleaning dishes on top shelf
You need to clean the jets on the machine arm with an old toothbrush etc... then clean out the debris filter on the bottom of the tub near the dryer bar. The calcification in the little jet areas causes this problem. This should help.
Jan 18, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher not cleaning/water sprayers not spraying it appears
I had the same thing recently. Everything appeared fine mechanically, but no water would spray. I inspected the bottom arm as closely as possible and actually found a half melted clear plastic straw inside of it. 30 minutes, tweezers and a small pick eventually got it out and all is fine.
Sep 14, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
99 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
