Question about Kitchen Ranges
Stopped working, water on floor. - Kitchen Ranges
  • Kitchen Ranges Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 26, 2011
How do i stop my water pipes from rattling
Secure water pipes to floor joists, install a water hammer arrester. Try securing pipes first, they should be secured at every other floor joist. If you can't get to floor joists try a water hammer arrester.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
May 18, 2014 | Plumbing
Kenmore model 106.72009010 leaking water onto floor
Defrost is not working and that is causing the leak.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Have a 2008 Saturn aura. Water leaking on back passenger floor board. Was told that it could be clogged which was causing water leak. Took it to the shop, they said its not clogged. They said its the...
problem solved water in floor in drive floor an behind driver floor rear seat floor water in door drain holes was stopped up in door rain filled door up and over flow thru the panel into the floor of the car check by shake the door and see if u hear water that the problem drain holes is stopped up in the door poor design it also most under the weather stripping on the bottom of the door
Jul 19, 2012 | Cars & Trucks
GE Refrig. Water leaking on floor after ice maker stopped
look at water delivery tube to the ice mker . it has iced over and pluged up causing the water to go out the back and down on floor . . clear the water tube with hot water and problem is over . .. some models cah use a updated water tube. mm
Jul 16, 2010 | GE GSH25JFR Side by Side Refrigerator
Stopped
This is a typical Anti Flood system activation. This system activates when water leaks onto the floor of the machiene due to a leak fault (pipe/hose clamp/ partly blocked pipe). The machiene automatically switches to pump out mode and stops water inlet. The anti flood system is a polystireen float / micro switch at the base of the machiene floor. Dry the floor and drectify the leak and it should work.
Jan 24, 2010 | Baumatic 23 in. BDW13 Built-in Dishwasher
There is no water going into the dishwasher even though the water supply is on.
Jan 24, 2010 | Miele 24 in. G665 Built-in Dishwasher
Hi my whirlpool dishwasher wont stop drainning even when the start button is of
Jan 24, 2010 | Whirlpool ADG450 Slim-Line Built-in...
Wahser does not stop filling water
replace the water inlet valve
May 03, 2009 | Washing Machines
My refrige leaks water on the floor from the freezer side on the left. I turned the water off and disconnected the water line. Still once or twice a week the refrige leaks water on the floor.
Sounds like ice build up on the freezer coils. Disconecting the water line doesn't stop regrigerant from flowing through the coils since they are still working. Easiest way would be a hair dryer to melt the built up frozen consensation. After you should see no water on the floor and you can turn the water back on (i assume the water is for your ice water and ice cube tray).
Apr 16, 2009 | GE GSH25JFR Side by Side Refrigerator
Kitchen Ranges Logo
47 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
