Question about Barbeques Galore Capt'n Cook 4-Burner (NG) Grill
I have a black and red, 4 burner, capn cook grill from about 1990. do you have any idea where the model number might be?
    Brigadier General:
  • 4,736 Answers
With the age of the grill it's hard to know where it's located or even if it still exist. I would suggest that you call BBQ's Galore, Customer Service Dept 800-752-3085, as they can probably tell you where to look or even what the model number was 11 years ago.
Posted on Mar 26, 2011
Glass turns black inside
You don't indicate where the glass is that becomes black/sooty but you can get cleaner specifically intended for cleaning glass fireplace doors. It is more effective than using ordinary glass cleaners
Apr 29, 2013 | Napoleon Fireplaces Napoleon Prestige PRO...
Got married about two years ago. One of our wedding gifts was a gift certificate for Barbecues Galore. We picked up a Cap'n Cook 4-burner unit with an infrared rotis burner. Wanted to use the rotis...
No, John, Yo do not want to use the rotisserie rod/spit without the wooden handle. Call BBQ's Galore Customer Service 800-752-3085 for a replace handle. If they can't help you, go to the following link and search by the Model Number of your grill (FYI - Capt Cook is not a model number).
http://www.appliancefactoryparts.com/
I hope this helps you and thanks for choosing FixYa. Happy Grilling!!
Aug 22, 2011 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Can i get parts to convert my capn cook 4 burner bbq grill to lp
The BBQ's Galore grills are the only ones that are approved to be field converted. All you need a 4 LP Gas Burner Orifices and a Hose Regulator Assembly to hook to a LP Gas grill tank. You can buy the orifices from BBQ's Galore and the Hose/Regulator Assembly from any hardware store or home improvement center that sells grills & accessories for about $30.00. Gas grill burner orifices are pretty universal, so any LP Gas ones should work.
Hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Have 4 burner Capn Cook grill. Burners fire ok, but sound like air escaping Usually from all burners, but not all at once.
From what you described, it sounds (no pun intended) like the venturi valves on the burners need to be cleaned and/or readjusted, as the air gas mixture (ratio) may be off.
Hope this helps you to troubleshoot and solve the problem.
Apr 20, 2011 | Barbeques Galore Capt'n Cook 3-Burner...
Need grill cover for B2610alp but cannot find anywhere ?This is a 4 burner infrared grill with ceramic tiles. Also need user manual which has been lost. I found part number 361345 for model b3208alp which...
You should be able to get a grill cover from the website MightyCovers.com. They have covers in every shape and size and can make a custom one if they don't have the one that you need. I do not have the owners manual. Sorry I can't help more.
Jun 17, 2010 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Gas will not flow to burner to light grill?
could be the reg on the tank , not working no flow of gas ,
May 15, 2010 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
The new style OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
Mar 28, 2010 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Kenmore elite16690 gas grill - main burner replacement
Call 1-800-4MYHOME and request a brochure for that model. Then you can call the Parts line at the same number and order the parts you need.
The actual grill model number is 141-16690
May 03, 2008 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Sputtering grill
I have a TEC Pattio II. I have owned the grill for almost 10 years and TEC grills have a ten year warranty on many of the parts including the burners. The burners on my grill have a ceramic inserts. The pop and loud whooshing noises indicate the ceramic insert or the seal on the burner is "cracked". I have replaced both of the inserts and burners on my grill once about 5 years ago under warranty. I have one burner now that will not stay burning and I contacted TEC today regarding the problem, and I will replace the ceramic insert only under warranty. .
The newest TEC grills like yours have the TEC Radiant Glass Infra-red Cooking System with stainless steel burners with glass surfaces. I assumed this burner system had eliminated the problem of the burners going out with a loud boom or sputtering.
YOUR ONLY OPTION IS TO CONTACT THE CUSTOMER SERVICE GROUP AT TEC. THE TELEPHONE NUMBER IS 1-800-331-0097. TEC IS LOCATED IN COLUMBIA SC. TEC HAS A USEFUL WEBSITE.
May 01, 2008 | Tec RadiantWave Grill
Barbeques Galore Capt'n Cook 4-Burner (NG) Grill Logo
110 people viewed this question
Top Barbeques Galore Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Barbeques Galore Grilling Expert? Answer questions, earn points and help others
