Question about Frigidaire Washing Machines
Drum light does not come on. I can't find a bulb. does this model come with a drum light?
  • Guest Mar 26, 2011
    Model # FAFS4272LW
  • Guest Apr 09, 2011
    Hi Kevin. Sorry for the delay in getting back to you. The model # for my Frigidaire front load washer is FAFS4272L0. Does thi model come w/o a drum light? Or am I over looking it somehow?
    Thanks
  • Frigidaire Master
  • 1,902 Answers
Hello & Welcome to FixYa
Please get back to me with the model# so that I can check and tell if you the solution to your question.
Kevin
Posted on Mar 26, 2011
  • Kevin White
    Kevin White Mar 26, 2011
    Please check the
    connection to motor and if that is fine then replacing the panel is recommended
    repair. You can also refer to these pictures. Please get back to me if you have any other questions.
    Kevin
    Please check the connection to motor and if that is fine then replacing the panel is recommended repair. You can also refer to these pictures. Please get back to me if you have any other questions.
    Kevin
  • Kevin White
    Kevin White Apr 09, 2011
    Kevin
    Kevin
The drum light is out in a GLER104FSS
first, unplug machine. open the dryer door, Remove light protector cap. (pry with flat screwdriver), unscrew bulb and replace a new one
tadamm!! :-)
Mar 30, 2014 | Frigidaire GLER104FSS Gallery Series 27...
Why does dryer spin with door open?
Hi Mandy,
The fact that the light bulb is out *and* the drum continues to spin when the door is opened - all point to a faulty door switch.
This switch tells the machine the "status" of the door position. When the door is open, it turns on the light *and* stops / prevents the drum from starting. When closed, the light is shut off *and* the drum is permitted to spin. You should have the switch serviced as if a wire came loose it adds a potential shock hazard - in addition to the safety issue of placing hands into a spinning drum.
Jul 10, 2013 | Dryers
My Whirpool LGB6000KQ1 Dryer -- The drum won't stop turning when I open the door and the light doesn't come on either.....
You have a faulty door switch. Here is the replacement switch.
There is a video on that same parts page to show you how to replace it.
Feb 10, 2013 | Dryers
My dryer heats and dries, but when i open the door the drum doesn't stop nor does the light come on. We've changed the bulb...not the problem with the light. Also was squeekin quite a bit..now...
as far as the drum not stopping when door is opened that will be a bad door switch
the noise could be anything from a drum support roller to a blower wheel,the bearing on the motor,the rear drum bearing or even something such asa coin caught between the drum felt seal and the drum
nosies a hard to diagnose online since they dont sound the same in written form
Aug 26, 2011 | Dryers
I have a 2 year old Kenmore HE3 electric Dryer. Model 110.8708. The drum light never worked. I opened up the door and found a broken bulb. I replaced the bulb. the light stays on all the time,...
the door switch has something wrong with it,it's keeping the bulb on all the time and that's why it burnt out the first time,also you're missing the last four numbers on the model number
May 15, 2011 | Dryers
Where is the light bulb located ?
what model # ? most are inside the drum area - put head in (with machine off) and look around for a plastic cover. behind that is the dead bulb.
Dec 17, 2010 | Maytag Dryers
Drum light keeps flashing wont print
check if the DRUM are correctly installed, if are ok, consider replace it cuz the drum has and internal quartz bulb for heat up and sometimes they blew
Feb 26, 2010 | Brother HL-2030 Laser Printer
Dim bulb, copies nearly black, but prints fine
The dim bulb is your clue. The more light that is reflected on the Selenium drum, the more the drum is demagnatized and less able to attract the toner. The printer now thinks you're running really dark stuff through it because there is not much light to reflect off of your original documents. See why the bulb is so dim. Good luck.
Jan 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
