Question about Crosley Dehumidifiers
We have a 40-pt Crosley purchased in 2005. Gave us 6 years of perfect service. It stopped working recently; it will not turn on. No lights, no response...dead. Is a unit this old worth repairing? Repair service would cost at least $60-80, parts extra.
    Brigadier General:
  • 4,736 Answers
Shinn, I'd say you've gotten your monies worth out of 6 year old dehumidifier. Most of the time, it's more expensive in the end, to repair one than it is to purchase a new one. With that said, I'd vote for purchasing a new one. Just take as good of care of the new one as your did the old one. Obviously, you performed preventive maintenance on the old one and that's very important. Which makes you the exception to the rule, that most consumers don't take care of what they have and are astonished when an appliance fails.
Keep up the good work!
Posted on Mar 26, 2011
Crosley conservator dehumidifier will not capture humidity
Have you noticed it not running as often or not being noisy? Also have you tried to select a continuous drain setting if your unit has one?
Aug 14, 2012 | Crosley W.C. Woods DCW40S Electric...
I have a Crosley Model # DCW405, spec.D40F-LCRF270. Last year the compressor would not kick in. I did some simple thing to get it to work. This year, i again cleaned the filter, plugged, unplugged, scooted...
It may very well be that you have the humidity extraction level set to high. Lower it to 32-35%. If you have a manual unit, set the control to Maximum. Since it's a basement application, raising the unit up off the floor on to a sturdy table or counter top that can handle the weight of the unit, plus a full bucket of water, may also solve the problem. As, the air temp at floor level is colder than at chest or shoulder level. Dehumidifiers do not work well at temperatures between 40 - 60 degrees F. Unless you have what's called a Low Temp Model. They are specifically designed for basement applications.
Hope this helped you to troubleshoot and solve the problem
Jul 03, 2011 | Crosley Dehumidifiers
Won't come on
Definitely check the air filter, it has a sensor and will stop working if it's dirty. Easy to clean by running water through it.
Jun 09, 2010 | Goldstar DH304 Dehumidifier
Crosley dehumidifier does not collect water.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 13, 2010 | Crosley 40-pint Dehumidifier
Soleus 40 pint dehumidifier... used for 3 years, stopped making water. Recently overfilled, auto shut off hadn't worked and water level overflowed. 2 days later can't get to make water. Tried all the...
Check to see if the styrofoam is still in the lever of the shut off arm. It's atop the water reservoir. If there is nothing there it will not float causing the arm not to shut off.
Nov 25, 2009 | Soleus CFM-40 Dehumidifier
Compressor won't kick in
heatman101
Jun 14, 2009 | Crosley W.C. Woods MCR40ES Electric...
Dehumidifer - Working??? Not Sure.
if you can verify that the compressor is still active (is there a noticeable hum or buzz and / or do the room lights slightly dim during power on?) then the most likely problem is a loss of freon. if the compressor never turns on, then a faulty humidistat is likely...an electrician can run a test of this by "jumpering it out" to force on the compressor motor.
May 20, 2007 | Crosley 40-pint Dehumidifier
Collecting no water
My crosley dehum. acted the same way. It turned out to be a bad defrost thermostat on the evaporator coil.
May 14, 2007 | Crosley 40-pint Dehumidifier
Dehumidifiers Logo
155 people viewed this question
Top Crosley Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Crosley Dehumidifier Expert? Answer questions, earn points and help others
