Question about Samsung Televison & Video
I have connected my DVD/VCR to my Samsung 32 inc television but I get no sound
    Problem Solver:
  • 5 Answers
I had a strange issue yesterday too.
Our Samsung DVD/VCr all in one combo did a similar thing.
I used the HDMI cable for the DVD into the TV input labeled HDMI/DVD. That worked okay.
But the VCR part didn't work.
At one point I got sound but no picture. Using the RCA cables in the back on another input "Component 1"
I was trying to squeeze the best picture out of the player using the S-VHS cable.
I thought it did picture only, but the Plasma seems to be more picky about input sources.
I got everything to work keeping the DVD as a separate HDMI to Plasma TV feed.
The VCR was 3 RCA's Yellow (picture) red and white for stereo sound.
I then reset (toggled through the inputs to "reset" the TV.
It finally worked but I was two days mulling it over.
See if this works for you.
My TV was a Panasonic Plasma, but shouldn't matter.
Skip the S-VHS line and connect the inoputs with the TV off.
You MAy need to go into the input of set up menu on the TV (ours had a wrench as an icon) and set the Component 1 or 2 to "VCR".
Posted on Aug 04, 2008
LCD TV connection to DVD-VCR
OK here is a possible solution: 1) The best solution: Connect the antenna to your DVD-VCR through the RF Input and the the RF Out to your TV This take care of the VCR part. Then you get an RCA three way cable (Video-yellow marked, Right Audio-Red marked, Left Audio-white marked)connect the yellow marked RCA cord to the Video out of your DVD player then connect the other end to your video in of your TV. Ater that connect the red marked audio cable to the R Audio out of your DVD player to the R Audio in of your TV do the same for the white marked Audio cable. You will now be able to switch from VCR-RF to DVD-RCA.
Sep 11, 2007 | Televison & Video
Samsung DVD-V3650 DVD Player / VCR Combo no sound when connected via component cable
Component connections between your DVD player and TV (they will be colored red, blue, and green) carry video only. You will need to connect two more cables for left and right audio channels. The connectors for these audio cables will be colored white and red for left and white respectively.
Nov 04, 2017 | Samsung DVD-V3650 DVD Player/VCR
VCR shows tape is playing, but no picture or sound.
First, you need to check if the cables are properly connected to the television. Then you also check if you have your television on the appropriate channel that is to work with the DVD player/VCR combo for instance the AV channel. Then you can further try to change the cord used in connecting the DVD player to the television, if it does the same, then the problem is most likely from either the DVD's Audio Video port or from the Televisions Audio video port.
Have them both checked to detect which is faulty, and replace with the same type of port where fault is detected.
Take care and good luck
Oct 13, 2010 | Samsung DVD-V4600 DVD Player/VCR
Can't connect Samsung VCR DVD combo
this will only workif the vcr has a up convert feature whit out up convert it will not work you will have to connect vcr whit yellow red and white cables then dvd and vcr will give u the picture, if u connect dvd with commponent cables if u tv has this input picture from dvd will be better
Jan 26, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
DVD hookup to LCD monitor only appears in black and white!
I have a RCA flat screen television and my dvd player when hooked up is in black and white. How would i fix this and if so plz be more specific then these other people.
Jan 02, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
Dvd/vcr combo connection
Click here to download the user's guide and check page # 9 for more info on connecting your DVD/VCR device to the LCD. Use the yellow, red and white cables connected to AV1 or AV2 and select the appropiate input from your LCD.
Sep 13, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Complete black screen on samsung 46 inches
Thats Samsung for you. They are designed to last just right outside the warranty then fail. Typically the LCD panels are bad, and they are the most expensive part on that Korean unit.
Sep 07, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Wire up tv dvd vcr and freeview
hello
connect your sound output from the rear of the TV to your surrond sound system input.
and all should be well.
Thanks Guy9
Mar 14, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture/sound on RF or A/V input
reset mirco by pressing with tv off. display , 5 volume up power on .then press 8 then enter.
Aug 19, 2007 | Sony KV-32S42 32" TV
Televison & Video Logo
180 people viewed this question
Henry  Thomas
Henry Thomas
