Question about Garden
Where might i find a wiring schematic for dayton 2x442 reversing drum switch. it is missing from inside enclosure. will be for reversing the rotation on a 110/220v 1725 hp grizzly g2532
MNfisherman
  • 11896 Answers
SOURCE: drum won't rotate. How do I replace the belt?
should be able to get at it from back or bottom and just unbolt the pulley and place new belt and pulley on at same time
Posted on Oct 01, 2009
  • 832 Answers
SOURCE: what oil is inside a 1/3 HP 1725 RPM effluent pump
You can refill it with capella oil. This is the same as the oil used in refrigerator compressors, and be acquired
from stores specializing in refrigeration and airconditioning. Send us an e-mail for further assistance.
Posted on Oct 29, 2009
lostreasurem
  • 22 Answers
SOURCE: Hello, I am trying to
look under the toilet!
Posted on Nov 09, 2010
HansPP
  • 2510 Answers
SOURCE: Bra wire has gone through the holes in the drum
Cannot make out if that is a typo. There are signs of the wire or there are not? If you can see the end of the wire, grip it with a pair of pliers and carefully work it out back through the hole it is stuck in. If there are no signs of the wire, look if you machine has any removable plastic paddles in it. If it has, remove one of the paddles, usually held in by screws and clips, and rotate the drum till you see the wire, and remove it. Also look around the front of the drum behind the door in case the wire is jammed in there. If all this fails there is only one solution and that is to remove the front of the machine and the front of the outer drum to gain access to the gap between the two drums.
Posted on Mar 08, 2011
  • 5245 Answers
SOURCE: Wiring diagram for Dayton winch 4zy95 forward and
Contact WW Grainger.
They own Dayton manufacturing
Posted on Jun 26, 2012
Reversing a Dayton motor model # c286c1 motor
electric motor reversal requires the field winding to be reversed
this is best done by an electrical motor repair electrician as not getting it right can burn the motor out
Nov 26, 2017 | Dayton Heating & Cooling
I have a dayton electric pallet model 2leb8..the fan got tore off and i can't figure out the wiring of it.where they go..the schematic shows one wire coming out of the fan into a switch but un
hi there
i found some electrical schematics at the site below, pages 16, 17, 19 and 20.
if not exactly what you need, there should be enough information to help figure it out.
good luck! (:
http://www.grainger.com/ec/pdf/Dayton-Electric-Pallet-Truck-2LEB8-OIPM.pdf
Oct 26, 2014 | Cars & Trucks
Wiring diagram for Dayton winch 4zy95 forward and reverse switch
May 26, 2012 | Electrical Supplies
I installed a Dayton 4m205j condenser fan motor. It comes on but turns the wrong way. I switched the wires and it still turns the wrong way.
From what I can find on the internet, there should be a plug very close to the motor body that can be reversed to reverse the rotation of the motor. It should be a small rubber plug on the wires leading into the motor.
Also, check inside the wiring compartment for a sketch or notes.
Gary
Aug 15, 2011 | Dayton Permanent Split Capacitor Motor Fan
. How do I wire this for forward and reverse use
you can reverse the rotation CCW to CW if you reverse the wiring on the brushes
Jan 09, 2011 | Dayton Universal Ac/Dc Open Motor 1 Hp...
My Dayton 3E382D heater will not light because the plenum is missing. Where can I buy a plenum and where can I view a schematic for this unit?
For a schematic go to Dayton Furnaces on the internet and type in your model # and you should be able to download a parts diagram. The plenum you can buy at your local hardware store.
Oct 15, 2010 | Dayton Gas Furnace Heater
I need a wiring diagram for a farm duty 6k714k
It is generally located on the nameplate of the motor or inside the wiring housing where the outside power is brought in. These motors are usually convertible from 115 to 230 volt by merely switching a couple of wiring connections inside the wiring housing. If you can do so, 230 volt operation is much preferred due to the high speed start-up available and you can use wiring 1/2 the size required for 115 volt operation. Good luck!
Jun 05, 2010 | Dayton Audio Dayton 6K138 CapacitorStart
Hooking up my heater
The white is the common neutral, it is probably a 3 wire unit, and you are missing the ground wire. Check inside the control panel and see if someone wired it using the white wire for the ground, it will be screwed into a terminal lug. Check the schematics to see if the unit requires a common neutral to run the controls.
Nov 24, 2008 | Dayton G73 Utility Heater
Dayton Attic fan running backwards
First see if the switch has a reverse position. Sometimes you turn the fan assembly in the frame, sometimes you turn the whole frame around. Take the cover off the wiring compartment to see if there are instructions there. Also check on the name plate on the motor, there may be instructions there. Attic fans are usually engineered to blow out.
Aug 02, 2008 | Dayton (2C373) Fan
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
