Question about Honda Garden
My countax C300H starts OK but when I engage the cutters it immediately cuts out. If I let the engine run for 10 minutes then engage the cutters they usually work ok but this is pretty annoying. Is there a remedy? Many thanks, Phil
Just got one of these mowers myself - accidentally got a large stone caught in the blades which caused the same problem. It looked to me that there's a sensor on the flywheel that cuts the motor if the blades aren't rotating freely. You might find either that the sensor is broken (check it by pulling off the connectors and connecting them together) or that the blades aren't rotating for some reason.
Posted on Apr 21, 2011
  • john rickett
    john rickett May 08, 2014
    where is the sensor
My countax c300h will not start
Check for spark. If it has spark, then it is a fuel issue. Try a shot of ether in the carb. If it starts, then you know it is a fuel issue. May need to clean the carbureator.
Sep 12, 2014 | Garden
Countax C300H running problems
carb jets probably need to be cleaned
May 14, 2014 | Garden
Where can i get I a new cutting deck for my old countax c300h? I am in Leicestershire and would like it fitted also. Thanks
Sorry to be the bearer of bad news - but it's either ebay, or pay Countax GBP 350 or more. Any C-series deck will physically fit, but power becomes an issue if you over-do it (don't fit a 42" deck if you only have 12HP)
May 05, 2014 | Garden
Countax C300H Garden Tractor Manual
I have a countax 300h about 8 years out Will not start and a warning letter C is lit up any ideas what is wrong
Apr 04, 2012 | Garden
Mower cuts out when cutter engaged
Check your blades for turning. A OTHER REASON COULD BE THE AIR FILTER GOT WET. If got wet. Put in the sun for a few days.
Mar 03, 2012 | Garden
My countax mower c300 keeps blowing the p c b board
hi, my countax k18 is needed for this season for my buisness, after about 10 or so minuits it cuts out on me, no deck attached And i havnt engaged or disengaged anything... any ideas?? its defo electric as it cuts out really quick....
Mar 25, 2011 | Garden
I have an atco commadore B20 that cuts out when I
it could be tight cutter bearings in the deck next time it cuts out switch off the motor and try to turn the deck by hand if its realy tight its seizing up on you
May 02, 2010 | Garden
Blades not cutting checked all belts they are ok but not driving blades countax c300h tractor
Either the belts are worn making them too loose, or you may have a spindle issue there. Check the spindles to make sure they aren't seized. Also, check the blade center nuts to make sure they are tight. Good luck.
Oct 04, 2009 | Garden
Ride on Mountfield Lawn mower 1228H - engine cuts out
Check to make sure there is no obstruction in the blades or on top of the deck where the belt goes. Also check that your pulleys turn freely and that a bearing didn't freeze up.
Let me know if this helps.
roundo4
Aug 08, 2009 | Garden
Garden Logo
893 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
