Question about HP PhotoSmart Pro B9180gp - - colour - ink-jet - 330 x 482 mm - 4800 dpi x 1200 dpi - up to ... InkJet Printer
How to print 11x14 print on a sheet of 11x17 paper with a HP B9180 printer
  • Thomas Becker Mar 26, 2011
    how can I do that
    I am using Qimage to print and win xp pro
    President:
  • HP Master
  • 2,246 Answers
You need to change the bottom margin of 11x17 paper to 11x14
Posted on Mar 26, 2011
  • 1 more comment
  • Lastoni Wibowo Mar 26, 2011
    go to control panel>printer>click at your printer
    then right click and chose properties and you will dirested to hp printer properties
    at general tab click printing preference
    and from there you can change the paper type and margin
    or you can set margin from the software that you use for printing for example microsoft word
    you can change the margin of ms word that can be applyed to your printer
    see the manual at link http://www.ddisoftware.com/qimage/tutori...
    there you can see how to resize the paper size
    at my answer before at win xp
    go to control panel>printer>click at your printer then right click and chose properties and you will dirested to hp printer properties at general tab click printing preference and from there you can change the paper type and margin
  • HP Master
  • 1,679 Answers
which application are you using to print ? is it Excel or Word or any other ?
Regards,
Ron
  • ONE-Touch-Solution
    ONE-Touch-Solution Mar 26, 2011
    You need to do custom paper setup settings in the print setup properties for Qimage. Have you tried it ?
    Set 11x17 printing under the print setup settings of Qimage and it should print on it.
How do I print two 8 1/2x11 sheets of paper on a 11x17 sheet on the riso 220? It keeps cutting my originals off.
RZ 220s have a smaller print area on the drum. I think around 9x14. Although the 220s can take 11x17 paper they cannot print over the entire area. (This is why I personally went with a RZ390. It has the 11x17 print area) Sorry, you're out of luck pal.
Oct 25, 2012 | Riso RZ220 Duplicator
11x17 paper jams from drawer - will not feed from sheet bypass
Check to see if the actuator arm is stuck in the bypass tray,therefore not seeing the paper and be sure the side guides are up against the paper. If that doesn't work and you have 2 cassette cavaties put the 11 X 17 where the other tray is . Hope it works for you.
Apr 09, 2010 | Office Equipment & Supplies
I want to use 11x14 paper on my dj1280 but it is not in the menu. neither is there a provision for user-defined paper sizes. what to do?
The 1280 isn't compatible with 11x14 paper. You can either use legal size (8.5x14) or ledger size (11x17), but you can't customize it to use 11x14.
The best solution would be to print onto 11x17 paper and then cut it to 11x14.
Jan 14, 2010 | HP DeskJet 1280 InkJet Printer
Cannot print 11x14 paper on my Canon Pro9000 printer.
The printing software you are using should have that size for you, I use photo gallery, after you select the image the pop-ups should be your printing software with the paper size choices.
Sep 10, 2009 | Canon PIXMA Pro9000 Photo Printer
When I press print on the computer, the Epson R1800 just sends the paper through the printer without printing on the paper.
It may have taken care of itself. Problem occurred when I was using letter sized sheets. Switched to 11x17 sheets and after running a couple of these through the printer, it started to print again.
Sep 08, 2009 | Epson Stylus Photo R1800 InkJet Printer
I put in 11x14 size paper in tray 2(11x17) but only get 8.5 inches of width printed instead of 11 inches. how do i solve this problem? thanks, joe.
Go in [user tools /counter]=>[system settings]=>
=>[paper size settings]
Please telll me for what machine you talk about
Jul 16, 2009 | Office Equipment & Supplies
Won't print
Hi, try upgrading your firmware to version 27A.
Look there to learn how : http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01326792&lc=en&dlc=en&cc=ca
Apr 06, 2009 | HP Photosmart Pro B9180 InkJet Printer
Hp photosmart pro B9180 does not sense paper
Hello sir; You need to clean paper pick up roller, and rubber pad(right underneath the roller) as well as paper sensor.
Jan 12, 2009 | HP Photosmart Pro B9180 InkJet Printer
I have a HP Deskjet 9800. It' doesn't want to print 11x17 size paper. It will feed an 11x17 sheet but nothing printed on it, after that the paper feed light blinks, and eventually the printing task bar...
I can't tell you for sure which thing I tried and worked, but I noticed the USB cable looked slightly damaged, so I switched it out. But the thing that I actually think did it was that I was using the A3 size paper because there was no 11x17 paper size with the exception of a banner 11x17, which I didn't try becuase I wasn't creating a banner.
But none the less, that did it.
Sep 23, 2008 | Office Equipment & Supplies
HP PhotoSmart Pro B9180gp - - colour - ink-jet - 330 x 482 mm - 4800 dpi x 1200 dpi - up to ... InkJet Printer Logo
166 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
