Question about Canon GL2 Mini DV Digital Camcorder
I am trying to put my GL2 in 16:9 mode but the menu item is in pink and won't let me select it...what do I do?
  • Canon Master
  • 3,083 Answers
Make sure you have the camcorder set to record on the dvd, since you can't go into the 16:9 mode when recording to the memory card- at least that's the way it was on one of my camcorders.
If you already have the dvd selected, you might be experiencing a faulty switch pad or similar problem, in which case the unit will have to be serviced. You can take it into a local camera repair shop, or contact Canon. Here's their support site:
http://www.usa.canon.com/cusa/support
If you're not sure of the menu settings that will allow 16:9 mode, refer to your manual. If you take it into a camera shop, they should be able to assist you if it's just a setting, or verify if there's a different problem.
Good luck, and hope this helps.
Posted on Mar 26, 2011
Clear/stop 1, 0, 7 color start does not work
Each menu is classified into two "Modes" depending on how you enter the service menus.
"Menu Mode" can be executed by pushing a sequence of keys.
"Special Mode" can be executed if you press certain keys at the same time as you turn the power on.
Each menu is classified as follows:
Menu Mode
Maintenance Mode Menu This is a menu for maintenance and service.
Special Mode
Fax Service Test Menu This is a menu for checking the fax mode.
MAINTENANCE MODE MENU
Selecting an Item
To select an item, press the "Up" or "Down" key.
Going into the Next Level/ Returning to the Previous Level
To go into the next level of an item, select an item then press the "OK" key.
To return to the previous level of an item, press the "Return" key.
Exiting the Maintenance Mode Menu
To exit the maintenance mode menu, press the "Clear/Stop" or "Return" key until the
"Ready" display appears.
For clear SC 543 Enter the engine maintenance mode.
Press "O.K" in "Fuser SC Reset" with engine maintenance mode, and then turn the main power switch off and on.
Oct 08, 2013 | Ricoh Aficio SPC232SF All-In-One Laser...
Tip
Reset firefox
Resetting preferences
Actions
* Edit this page
* Translate this page
Show content customized for:
* Windows
* Linux
* Mac OS
* All
If you want to reset your Firefox preferences, this article provides instructions on how to reset them through Safe Mode.
To reset preferences:
1. Close down Firefox completely: At the top of the Firefox window, click the File menu, and select the Exit menu item.Close down Firefox completely: On the menu bar, click the Firefox menu, and select the Quit Firefox menu item.Close down Firefox completely: At the top of the Firefox window, click the File menu, and select the Quit menu item.
2. In Windows, click Start, open the All Programs list, and navigate to the Mozilla Firefox folder. In the Mozilla Firefox folder, select Mozilla Firefox (Safe Mode).Hold down the Option key, as you start Firefox.Go to your Terminal and run:
firefox -safe-mode
You may need to specify the Firefox installation path (e.g. /usr/lib/firefox-3.5).
3. Firefox should start up with a Firefox Safe Mode dialog.
Note: You can also start Firefox in Safe Mode by clicking Start, selecting Run (or use the Start Search box in Windows 7 and Vista) and then entering the following in the text field:
firefox -safe-mode
4. To reset your user preferences, click to put a check mark by Reset all user preferences to Firefox defaults.
5. To apply your changes, click Make Changes and Restart.
Firefox will restart with your settings changed back to the defaults.
on Nov 19, 2013 | Mozilla Firefox
Clear/stop 1, 0, 7 color start does not work for getting into service mode?
Menu Mode
Special Mode
Selecting an ItemTo select an item, press the "Up" or "Down" key.
Going into the Next Level/ Returning to the Previous LevelTo go into the next level of an item, select an item then press the "OK" key.
Exiting the Maintenance Mode MenuTo exit the maintenance mode menu, press the "Clear/Stop" or "Return" key until the
Am I missing something simple? Read the manual and can't set the time or date on KDC MP628.
Step 1:
In standby mode:
Enter Menu mode:
Press the [MENU] button for at least 1 second.
"Menu" is displayed.
Step 2:
Select Clock Adjustment mode:
Push the Control knob to [FM] or [AM].
Select the "Clock Adjust" display.
Step 3:
Enter Clock Adjust mode:
Press the Control knob for at least 1 second.
The clock display blinks
Step 4:
Adjust the hours:
Adjust the minutes:
Push the Control knob to [Back Search] or [Forward Search].
Step 5:
Exit Clock adjustment mode
Press the [MENU] button.
Step 6:
Date Adjustment...
Select Date Adjust mode
Push the knob to [FM] or [AM].
Select the "Date Adjust" display
Step 7:
Enter Date Adjust mode
The date display blinks.
Step 8:
Selecting the item (day, month, or year) to
adjust
The items that are blinking are items that can be
adjusted.
Step 9:
Adjust each item
Step 10:
Repeat step 8 and 9 operation and adjust the
date
Step 11:
Exit Date adjustment mode
Step 12:
Setting the date format.
Select Date Mode
Select the "Date Mode" display.
Step 13:
Select the date format
Step 14:
Exit Menu mode
Hope this helps.
Cheers,
Scott
Jan 14, 2013 | Kenwood KDC-MP628 CD Player
How to change japani language in to english
Press the MENU button, select the toolbox icon, then select the third item on the menu.
Nov 04, 2012 | Sony DSC-WX7/P - La Cybershot Wx7 Pink...
Clear all the memory
1) User data mode selection
Press the Data Registration button.
Service mode selection
Press the # button.
Menu item selection
Select the menu item by pressing the or up down button.
SERVICE MODE
#12 CLEAR Param.
select ALL
then OK
Jul 08, 2009 | Canon LaserCLASS Fax 710 Printer
I want to put color bar in pd 170
dear when u will open menu .. at last where we check ..HR. METER ,if u remmber ...
der is the option for the colour bar
Jan 25, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
''Nonresponsive Script''
Try "Firefox Safe Mode". If the problem goes away, disable your extensions, one by one.
How to start Firefox in Safe Mode
  2. In Windows, click Start, open the All Programs list, and navigate to the Mozilla Firefox folder. In the Mozilla Firefox folder, select Mozilla Firefox (Safe Mode). Firefox 3, Mac OS: Hold down the Option key, as you start Firefox. Firefox 2, Mac OS: Go to the Utilities directory (in the Applications folder) and open Terminal, then run:/Applications/Firefox.app/Contents/MacOS/firefox -safe-modeGo to your Terminal and run:/path/to/firefox/firefox -safe-mode
Nov 17, 2008 | StumbleUpon Social Network
Language
Enter the menu,
Change Language set to American. It is under symbol sets. Also change code page to usa.
Menu Mode
1. Verify that paper and the ribbon are installed.
2. Power ON the printer.
3. Press SELECT and place the printer OFF-LINE (SELECT will not be lit).
4. Press QUIET to enter Menu Mode.
5. The line shown below will print.
Printer Control Emulation Mode Epson LQ 6. Go to Step A to print the current menu.
Go to Step B to change the menu.
Step A
Press PRINT to print the current Menu.
Press EXIT to exit Menu Mode.
The printer will go ON-LINE. (SELECT will light.)
Step B
Press GROUP to move through the groups of the Menu.
A line prints, showing the Group.
Press ITEM to move through the items in a group.
A line prints, showing the Item.
Press SET to change the setting for an item.
A line prints, showing the Setting.
Feb 15, 2008 | OKI MICROLINE ML-395 Matrix Printer
Problem with oki microline 395
Enter the menu,
Menu Mode
2. Power ON the printer4.gif.
5. The line shown below will print4.gif.
Step A
Step B
A line prints4.gif, showing the Group.
Canon GL2 Mini DV Digital Camcorder Logo
67 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
