Maytag MAF1200AAW My Maytag MAF1200AAW has given me years of trouble free washing but lately the clothes smell musty after the wash. There is no apparent mould and all the water seems to drain away. What could be happening. Regards Pete
    Scholar:
  • 93 Answers
WASHER MAGIC is the revolutionary product specifically formulated to safely and effectively clean the family washing machine. Top loading machine use whole bottle. Front loading use 1/2 bottle. You may rub Washer Magic on with a rag to eliminate odors.
Why Use WASHER MAGIC? Every time you wash your clothes, hard water and detergents causes lime scale and rust to build up inside the tub, pump and hoses. This build-up reduces the ability of your washing machine to perform. Mineral build-up acts as an abrasive increasing the wear on your clothes. The result: your clothes are not as clean as they could be and wear out sooner.
If you are unhappy with the way your clothes comes out of the wash, then WASHER MAGIC may be the solution you have been looking for. Only WASHER MAGIC can restore the family washing machine to the way it performed when it was new. Use once a month for optimal washer performance and to keep control of trouble causing build-up.
Posted on Aug 04, 2008
There is a musty smell in the maytag washer even b4 I fill it with water, I've disconneted the hoses & flushed with bleach that did not take care of it,Iv'e run washes without clothes in it...
When a moldy or musty smell develops in a washing machine, many times the smell is coming from the open areas of the agitator. Water along with soap and/or liquid softener sometimes splashes into an open agitator, and when the lid is closed it does not dry out. Instead, mold begins to form, and a musty smell wafts from inside the machine, even after the lid has been opened for an extended period of time. Until the mold is removed the washing machine will continue to smell bad, even if it is used and allowed to air dry with the lid open.The tub can also be the source of the smell. Lint can gather and collect in the holes, and when it does not dry fast enough it ends up smelling musty and moldy. Even the top of the rim can become moldy and musty, but proper cleaning can get rid of the odor.
So that said.To clean the machine,fill to just above the top row of holes in the tub.Add 2 cups of bleach.Let sit for 1-2 hours.Then let the machine run it`s wash cycle.Lastly use bleach water and a rag to wipe the machine down inside and out.If the agitator has a cup on top remove and clean with bleach.Leave the top open so the machine can dry.
Now it should smell better,if so use as normal,and leave the lid open when not in use.
May 15, 2011 | Maytag Washing Machines
Maytag front load washer - smell musty
the water in the unit is normal, to kill the smell when you are done doing wash for the day dampen a rag with bleach and whip down the door gasket. You can buy a cleaner called "afresh" it works as well. If your unit is a neptune check with maytag it might have a recall on the door gasket for growing mould
Nov 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune washer smells musty. what is
I owned a maytag neptune washer and had to run dishwashing liquid thru it occasionally to get the smell to go away. Finally we learned about a new gasket retrofit that they were doing which was covered by the maytag company we called and they installed it for free and the smell stopped. I had that washer for about 10 years and probably spent as much fixing it over the years as it cost. I now have a whirlpool duet front loader and love it. no smell and not problems. Try the electric dish washer soap.
Aug 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Hotpoint Washing Machine smells mouldy as has mould
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Jul 02, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Musty smell
Run your machine through its cycle with NO clothes and when it is filling up with water put bleach in the water. Put bleach in only at the start of cycle.
Before you do this clean all inside parts the best you can yes with bleach and you can run something like fleecy to make clothes soft and smell nice when you wash your clothes as well. Our machine has a special holder to put softener in.
Do NOT have clothes in when running the heavy bleach through it. This should kill the bacteria .
Aug 12, 2017 | Maytag ATW4475TQ Washer
1994 Kenmore 90 series washer smells musty
Do a boil wash without clothes & detergents, with a cup of bicarbonate of soda in the soap drawer.
Mar 30, 2009 | Kenmore Washing Machines
Clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
Clothes come out of washer smelling musty
It sound like lint bult up under agitator orIn Between inner and outer tub it would have to be manualy cleaned thanks and good luck:)
Nov 16, 2008 | Maytag MAV3855A Top Load Washer
Our Clothes smell musty and the washer smells too
clogged water screens , defective water level pressure switch , clogged drain, kinked drain hose ,. defective water pump , defective water tempeerture switch, damaged water valve solenoid , water inlet valve has an interal malfunction
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Clothes Smell Musty and Damp
It sounds like a build up of washing residue. Clean inside the door seal and do a very hot wash with a bit of washing powder and no clothes. Repeat this once a week until smell has gone.
Oct 28, 2007 | Hotpoint WMA30 Front Load Washer
Washing Machines Logo
179 people viewed this question
Top Washing Machines Experts
