Question about Kitchen Appliances - Others
Can i get a circuit mother board for my biflame electric fire model number dbl2000a-dd2r? where can i purchase replacement parts for this fire?
3 Suggested Answers
SOURCE: Biflame on off switch fire
LOCAL ELECTRIC SURVAYER SOLVED THE PROBLEM
THANKS ENYWAY
Posted on Oct 19, 2009
Testimonial: "YOU HAVE BEEN VERY HELPFULL IF ENYONE ASKS ME I WILL REFER THEM TO YOU THANKS "
  • 123 Answers
SOURCE: can i get a motor 4 my biflame elec fire model
Yes you can. Pull the old motor out and read the information on it. You will need to look at the CFM RPM and Voltage to ensure that you get the same motor. Check on ebay for a new motor.
Posted on Jan 27, 2011
Leaking around heating element posts that protrude through dishwasher body
Some dishwashers like your model number are under recall for a potential fire hazard due to water leaking through the heating element posts onto the wiring.
Your serial number must begin with the 2 letters listed . Below is the list of recall serial numbers: FL, GL, HL, LL, ML, VL, ZL, AM, DM, FM, GM, HM, LM, MM, RM, SM, TM, VM, ZM, AR, DR, FR, GR
Call the phone # below or check out GE recall website. What GE does is replace the element and gaskets, unless there is burnt or arcing visible on the wires, they may replace the dishwasher.
www.geappliances.com/products/recall
GE has determined that an electrical failure in the dishwasher's heating element can pose a fire hazard. GE will provide a free repair to all consumers with units affected by the recall. We ask that you not use your dishwasher until it is repaired and to disconnect the electric supply by shutting off the fuse or circuit breaker controlling it and inform all users of the dishwasher about the risk of fire.
Consumers who instead wish to replace their dishwasher with a new model can receive a rebate towards the purchase of certain new GE and Profile brand dishwashers. Consumers can use a rebate of $75 for the purchase of certain GE front-control plastic tub dishwashers, or a GE rebate of $100 for the purchase of certain GE front-control stainless tub dishwashers or GE Profile top control dishwashers. See the rebate form for eligible models.
GE is aware of 15 reports of dishwasher heating element failures, seven of which resulted in fire and smoke damage beyond the unit. No injuries have been reported.
The model and serial numbers are important, as not all dishwashers are included in the recall. Look at the inside on the front left side of the dishwasher tub to find the model and serial number.
This recall is being conducted in cooperation with the U.S. Consumer Product Safety Commission, which will also monitor the effectiveness of the recall program.
Recall Hotline
866-918-8760
Monday through Friday, 8 a.m. - 5 p.m. ET.
Before calling, have the model and serial numbers on hand.
Customer Care
Apr 21, 2014 | General Electric Adora GHDA670N Built-in...
Can i get a motor 4 my biflame elec fire model dbl2000a
Jan 26, 2011 | Heating & Cooling
I HAVE A BIFLAME FLAME EFFECT STOVE THAT LOOKS LIKE THE MOTOR HAS GONE AS THE FLAME EFFECT SPINDLE IS NOT TURNING BUT EVERYTHING ELSE IS OK.WHERE CAN I GET A MOTOR FOR IT.MODEL DBL2000A-MS3R
Hi
i have found a seller in China who is posting 2 motors to me at a cost of $80 including DHL Shipping.
I ordered two so i have a spare if it goes again as nobody in the UK Sells them.
email him at Zq_qle@yahoo.com.cn
Your motor will be a TY-50A the same as mine.
Hope this helps
Paul
Nov 04, 2010 | Heating & Cooling
My Braun electric shaver model 7680 has stopped functioning probably due to a dead battery ( I had it for years). A service center is asking in excess of 60 dollars to fix it. Battery and mother board...
If the shaver is completely dead and the charging lights no longer illuminate when plugged in, the circuit board will need changed. If they still illuminate when plugged in, you can just change the batteries.
You will find the batteries and also the circuit board with batteries at shaveroutlet.com. You can order which you require. See links below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
http://shaveroutlet.com/shaver-replacement-parts/braun-syncro-circuit-board-with-batteries-select-models-p-772.html
There is a tip on the battery page for easier installation
shaveroutlet.com has an instructional video that shows you how to disassemble the shaver at the link below. It's the 4th video down
http://shaveroutlet.com/video_tutorials
Oct 14, 2010 | Braun Syncro 7680 Electric Shaver
I need to replace the batteries, but I do not know what part number to purchase. The batteries do not have any part number on them. Braun 6550 shaver
You will find the correct battery type at shaveroutlet.com. See link below. You will need two batteries.
I suggest that you read the installation tip on the item page as well.
Also, does the green charging indicator light still illuminate when you plug the shaver in to charge? If it no longer lights, don't waste your time with the batteries because your have waited too long to change them and the circuit board is now damaged. Unfortunately, circuit boards for model 6550 are no longer available from Braun
Oct 09, 2010 | Braun Flex Integral 6550 Electric Shaver
I need a switchboard for a hotpoint aquarius WF000 6kg washing machine
By switch board, I assume you mean the control module.
If you go to Hotpoint's web site, you should be able to locate the part you require.
WWW.HOTPOINT .CO.UK
Then click on-- SPARE PARTS AND ACCESSORIES in the menu on the left.
Mar 16, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Kenmore electric range: oven & broiler will not work.
All your oven features are controlled by the Electronic Range Control (ERC) board. This is your clock/timer assembly. Unfortunately, most do not have fuses and are not serviceable. You will probably need to replace the board. The following link explains how:
http://www.fixya.com/support/r3727366-replacing_control_kitchen_range
Replacement circuit boards can be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. For the model number you have listed, the part number for a new board is 316207511.
NOTE: The overlay, which is the plastic template with the numbers and letters preprinted on it, does not come with the new board. It has to be purchased seperately. However, if the current overly is still in good shape, it can be peeled off the old circuit board and reused. The part number (if required) is 316220841.
If you have questions about this repair, please post back and let me know. I hope this helps you.
Jan 21, 2010 | Kitchen Ranges
THANKS ENYWAY
Oct 18, 2009 | RELIANCE ELECTRIC WATER HEATER
Kenmore Elite 17483 Dishwasher Caught Fire!
Had the exact same problem (Control panel burning up, sparking, and smoking during wash cycle) last night with our Kenmore Elite DW model 665.16293400 purchased Nov. 2004. I have reported it to the CPSC and www.kitchenaidfire.com and will be contacting Sears first thing tomorrow. It is outrageous that this problem is apparently so widespread with nothing being done about it! I have no doubt my kitchen would have been in flames if I had not been sitting right here to shut off power to the D/W.
Feb 04, 2009 | Kenmore 24 in. 17483 Built-in Dishwasher
Part number: 316809100002-R02
I too have the same power board burnt out ... did anyone ever find the part you was looking for ... Thanks
Nov 20, 2008 | Computers & Internet
Kitchen Appliances - Others Logo
102 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
