Question about Sanyo PLV-Z4 Multimedia Projectors
Hi, i have the projector since january 2009, i use it no more than 2 hours a week, sudenly the lamp stupped to work, and when i try to get it on - the replace lamp is flash, what is the prublem?
Hellow from Moscow. Privet. How are u. Kak dela. I love your country.
I need your help. I have a very good projector Sanyo plv-z800. But i have same troubles and i need to enter in secret service menu. Tel me plz combo buttons. Peace from Russia
Posted on Mar 29, 2011
  • 442 Answers
Was it new when you bought it. (that is, are the lamp hours approximately 220 hours genuine)
take the lamp out and check that it looks OK.
The unit may have an electronic fault on the lamp power supply board.
Posted on Mar 26, 2011
I have an Optima HD 8000 DLP Projector and have had it for a year. The issue I am having is that the projector works find but for only 3-5 minutes and then it turns off and the Lamp Indictor turns on. Any...
hi,
First of all check the lamp hour of projector. just reset the lamp hour and try again.
1. Press the menu button
2. Select system
3. Then select lamp reset
4. Select reset
The lamp hour will be retested.
Try to do this before you projector turns off. it is recommended that do this only after replacing the lamp.
If doesn't work then check the following
Check the lamp cooling fan of your projector . may be its has some problem. its not running at the correct RPM. Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now you can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
ok
Mar 31, 2011 | Optoma HD8000 Projector
My lamp light is yellow green? what could be the cause?
hi ,
Do one thing just reset the lamp hour of your projector. For resetting the lamp hour do the following.
While simultaneously holding down the Right arrow ( >) button and Auto sync button on the projector press Power ON button and Left arrow ( button . The lamp hour will indicate zero.
If doesn't work you have to replace the lamp.
Remember on thing Lamp hour reset is recommended only after the lamp replaced. so try to replace the lamp if it work after the resetting procedure.
ok
Mar 27, 2011 | Sharp Notevision PG-B10S Multimedia...
Will not coming on ,standby light is orange temp and lamp light not on
hi,
Just try to reset the lamp hour of your projector. For resetting the projector do the following.
While simultaneously holding down MENU/HELP, ENTER and Down arrow button on the projector, Press STANDBY/ON on the projector.
Remember one thing lamp hour reset is recommended only after the lamp replaced. Before going to buy a new lamp just reset the lamp hour and confirm that the projector doesn't have any other problem.
If these doesn't help then check the lamp of you projector chances for lamp became faulty.
ok
Mar 19, 2011 | Sharp XR-10SL DLP Projector
The first lamp "burned out" after only half a year of use and we only used it once a week. We bought a replacemente lamp and it burned out after three weeks... Someone plugged in the projector, the lamp...
The early lamp failures are due to poor air flow or longer hours of use.
So take care to clean the filters, see that the lamp brigtness is not put too high and reduce the hours of continuous use.
Sep 29, 2010 | ViewSonic Office Equipment & Supplies
SANYO PRO xtrax MULTIVERSE PROJECTOR
Likely the projector has seem some hours on it before being sold second hand to you. A worn out metal arc lamp will wink out like this when it is at END OF LIFE. As the lamp operates, pressures build from high voltage arc current passing through the pressurized bulb. More and more voltage is required to keep the arc struck and operating as temperature rises. As the bulb ages, it requires more power to maintain the arc in the glass envelope bulb. It can rise to a point where it overruns the ability for the power supply in the projector to safely maintain the arc and it winks off, only the fan is left running. When the unit cools, the arc re-strikes and illuminates the lamp.
In short - replace the bulb, but buy TWO of them. One to fix the projector, the other as a spare on hand while awaiting another replacement bulb down the road. These metal-arc lamps typically run anywhere from 50 to 100 hours depending on power supply design and cooling ability of the projector as a whole.
May 10, 2010 | Sanyo PLC XU35 Multimedia Projector
Cannot Reset Infocus LP 350 Projector after replacing a bad lamp
that model has a history of bad ballasts. you'll need to replace it.
Mar 03, 2010 | InFocus LP350 Multimedia Projector
Projector sharp dt100 not working!
It is possible the lamp has died even though you only got 800 hours. Rated Lamp life is always up to and never a surety of those actual hours in the brochure will be acahieved. If you would like a quote for a replacement lamp let me know as we ship internationally. Regards Kevin Andreassend http://www.iceav.co.nz +0064-9-4142348 iceavtech@gmail.com
Dec 22, 2008 | Sharp DT-100 Multimedia Projector
Sanyo PLV-Z4 Multimedia Projectors Logo
206 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
