Question about Sony Audio Players & Recorders
We have a Sony VAC5 system. When we try to play a tape or CD it plays for 3 seconds then reverts to standby. In order to get it off standby we have to unplug it and replug it in. Is there something we can do?
5 Suggested Answers
Cruel dog
  • 8 Answers
SOURCE: system keeps sayin protect
The word PROTECT appears because there is a short. It can be in your speakers, try running it without the speakers plugged, or look if the wires arent shorting. If it stil ldoes that, its cause there is a short in it, from the output section. The system does that to prevent from damaging the electronic components inside.
Posted on Feb 21, 2007
techman
  • 3130 Answers
SOURCE: CD changer not playing CD's
If this did not help the problem by cleani9ng the lens, the laser is bad or the spindle moteo is bad. if this unit is over 2 years old, buy a new unit. Good Luck
Posted on Jul 15, 2007
SOURCE: CD player fails to read CDs
Hi Everyone !
We got the same problem two month ago and we fix it. The problem is drying lubricate oil from elector motor which spin the cd disk. You need to open top cover its 5 screw , 4 an sides and 1 on back. Then you see black cd changer in side. You need to open top cover of cd changer by unlock plastic clips and slide cover. Under cd holder you can fined elector motor that spin cd. You just need two drops of lubricate oil on top bearing at electromotor. My works fine right now .
Good luck.
Posted on May 23, 2008
SOURCE: Help - CD won't eject! I press 'Open' on my sony
I have the same problem and it's due to dirt!
I'm going to try using compressed air, but -
this definitely works:
:) Seriously:
tilt the cd player to a 45 degree angle (flat, basically - as if they tray were horizontal.)
I had my player for 10 or 12 years, and this problem is only coming up now. My house gets very dusty.
Also - vertical load disc players are hard to clean. X_X (inside the disc tray)
I love this stereo too!
I don't want to have to go out and buy another stereo!
Posted on May 04, 2010
Where is there a Sony Service centre in Bradford West Yorkshire
http://www.yelp.com.au/biz/sony-a1-regional-authorised-service-centre-yorkshire-multi-bradford
Sep 18, 2014 | Aiwa Audio Players & Recorders
My Sony PS3 is the orginal 60 GB unit and worked fine for quite a few years until the icon stopped appearing. This meant I could play blue ray, CD, DVDs. I had no problem playing a game that was on the...
You can try to do a system recovery on your PS3. this will set your PS3 back to factory settings as the settings may have been changed during the use. Here is the process in which you can do a system recovery.'
PS3 Recovery Menu
  1. Place the PS3 in standby mode
  2. Press and hold the power button for a couple of seconds, you should hear a beep
  3. Keep a hold of the power button for a couple more seconds, the PS3 should shut back down to standby mode
  4. Once this happens, press and hold the power button again for a couple of seconds, waiting for 1 single beep.
  5. Ignore this beep and keep it pressed until you hear 2 consecutive beeps, release the button.
I think you choose option 3 and then repeat and choose option 4. Once you are done with this, try out your PS3.
Aug 05, 2011 | Sony Playstation 3 (PS3) Console
My Sony mini hifi component system is going berserk!! 2 problems: 1- CD system skips tracks and on playing on repeat song, the song skips certain times and jumps ahead of the track. 2- Tape system plays...
Your cd player is fubar and in definite need of replacement.
Tape unit seems to have a mind of its won. Try to reset the electronics to factory defaults. If that has no remedy, since it is a sony< best advise is to trash it. Repair cost is prohibitively expensive.
Sep 19, 2017 | Sony MHC-RG222 CD Shelf System
The tape plays songs so fast sounds like donald duck. The speed the tape is feeding is to fast.
Hi, the casette deck has a mechanical system (servo-driver) most of the problems that happen when in your case, plays song so fast is that you look at the pinch roller. The pinch roller is a rubberized free spinning wheel typically used to press magnetic tape against a capstan shaft in order to create friction necessary to drive the tape along the magnetic heads with a normal tape speed if the pinch roller brakes, get lost from his place or got dirty then you get this fast sounds play, check the pinch roller if still good in his place or clean his rubber with alcohol, then the problem should be fixed.
Jan 29, 2011 | Sony CD Radio Cassette Boombox, CFD-E90...
My Sony Bravia will play for less than a minute and then reverts to standy. Any suggestions?
Please unplug tv from wall socket for minute or so,, replug back in and turn it On.
If tv still goes to standby itself than its standby light would blink to show an error in somewhere inside tv circuits.
Let me know how many times standby red light blinking? There would be 3 seconds long pause in blinking so count pause to pause to determine problem section.
Thanks.
Jun 13, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
CD is not playing on my SONY Home Audio CMT-EH15
HI. that grinding sound is signaling a lens assembly issue. the linkage and gear assembly seems to be jammed. this assembly must be able to move freely i order for the lens to track the CD. if the lens assembly is stripped or jammed, it will not be able to read and it will shutdown into stand by mode to prevent the motor from damaging itself. its most likely gear failure.
Unfortunately, the repair parts for this unit are only available from sony repair depots and, you will need to contact sony manufacturing in order to receive a repair ticket.
May 19, 2009 | Sony Audio Players & Recorders
Sony tr707 hi8 circa 1994
No puedo abrir el compartimento de la cinta
Oct 31, 2007 | Sony Handycam CCD-TR416 Camcorder
"mecha error"?
i've dismantled my system found the top fuse had blown on the transformer also aligned the cd tray all works sweet now wahoo :)
Feb 11, 2007 | Sony MHC-RG660 CD Shelf System
Tape open message... tape does not play
mechanism switch problem,needs service.
Jan 24, 2007 | Sony CMT-HPX9 CD Shelf System
355 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
