Question about Vacuums
I need maual for Revlon 1875 IONIC hair dryer Model # RV479 i want to download the PDF manual if possible
  • 3,230 Answers
Well you may please follow the link below to get your manual -
http://www.conair.com/instruction_booklets/1875Watt_Ionic_Styler_146XR.pdf
Good Luck!!
Thanks for using FixYa!!
Posted on Mar 27, 2011
I need to find an instruction manual for a euro pro shark 473. Someone gave this machine. Thank you.
http://www.sharkclean.com/manual/473C_REV_0706A.pdf
Euro-pro 473C Manuals
https://www.manualslib.com > Brands > Euro-Pro Manuals > Sewing Machine
Euro-pro 473C Pdf User Manuals. View online or download Euro-pro 473C Instruction Manual.
[PDF]Model / Modelo / Mod?le 473C
www.sharkclean.com/manual/473C_REV_0706A.pdf Translate this page
Use this appliance only for its intended use as described in this manual. .... As the owner of a new EURO-PRO sewing machine, you will enjoy precision quality ...
[PDF]Instruction Manual Model
www.sharkclean.com/manual/412N_REV_0706.pdf Please read the instructions carefully before operating ... EURO-PRO Operating LLC warrants this sewing machine for a period of 5 years from date of the.
Jul 15, 2018 | Shark Vacuums
Bissell pet hair bagless instruction manual
Do you mean the Bissell Pet Hair Eraser bagless vacuum cleaner? The user manual for this vacuum is available from the product page: http://www.bissell.com/pet-hair-eraser-vacuum/ . Look on the right hand side of the page. The direct link to the English version of the manual is: http://www.bissell.com/assets/0/132/134/228/e5babada-7240-40ea-93c0-90427ed32741.pdf . Note: you will need Adobe Reader or a similar product to access (read/print) the manual.
Bissell has a number of vacuums for cleaning up after pets. Look for your vacuum here: http://www.bissell.com/pet-vacuum/ . The manuals for most are on the product page. For example, there is also the Bissel Pet Hair Eraser OptiClean Cyclonic vacuum. The manual is here: http://www.bissell.com/assets/0/132/134/228/dd4a7280-504f-4483-84a1-bfcc3a239f45.pdf . Older product manuals may be available here: http://www.bissell.com/customer-support/ . Scroll down to the Users Guide search box.
I hope this helps.
Feb 07, 2013 | Bissell Vacuums
My silent ionic breeze GP just stopped working (no blue light, no static). only a couple of years old. cleaned weekly. how do I obtain someone to possibly fix it as trouble finding replacement?
http://www.airpurifierrepair.com/ProductDetails.aspx?ID=0&ProductId=473&gclid=CKWj6N--u6cCFYjsKgodLxrBBQ
Airpurifierrepair will fix your unit but it starts at 159.00 flate fee.
Here are some other things to try first:
Dirty Collection Grid.
  • In case of a problem with your Ionic Breeze air purifier, the first thing you should do is clean the collection grid. According to the Ionic Air Breeze instruction manual, the most common problem with the units is that the collection grid gets too dirty and the unit no longer effectively cleans the air. Removing the collection grid from the top of the unit, then wiping it down with a damp sponge or rag, as well as turning the entire unit upside down several times to dump out any dirt from inside the housing, will help restore the unit to maximum operating efficiency.
Glowing Blue
  • Another common problem with the Ionic Breeze unit is that it no longer glows blue, which it is supposed to do when operating in germicidal protection mode. If the unit is no longer glowing, it is likely that the UV fluorescent bulb inside the unit has died or has decreased in output. The bulbs are meant to last for about a year, and touching the bulbs or getting them in contact with oil or dirt will shorten their lifespan. Try replacing the light bulb before assuming there is a more serious problem with your Ionic Breeze air freshening unit.
Transformer or Circuitry Issues
  • Other problems that may occur with the Ionic Breeze that you will need to troubleshoot and repair include transformer or circuitry problems. If the transformer goes bad, the unit will not work at all, and will have no power when you attempt to turn it on. Similar problems can occur if the circuit board is defective. Because of the danger of electrical shock or damage, it is best if you have a repair facility work on your Ionic Breeze unit if you suspect transformer or circuitry problems
Mar 06, 2011 | Vacuums
Need info on changing belt, no longer have maual
You will need a Phillips screwdriver and a new belt.
Unplug the vacuum, lower handle to lowest position, and turn it over so the bottom of the power head is up.
Remove the screws from the bottom plate and lift it off.
Remove the flat (outer) belt, or any fragments.
Slip new belt on to motor shaft, then over the large pulley. It's easier to get the belt over the pulley if you spin the pulley toward the brush while doing so.
Diagrams and information are found in the manual.
Click on the below link to get a downloadable copy of the manual. You can print it from there as well. How to change the flat belt is on page 10. The V-belt is on page 11.
http://www.hoover.com/pdfs/manuals/U6616900.pdf
Mar 02, 2011 | Hoover U6616-900 WindTunnel Bagless...
We owe ionic pro turbo air pur. ever since we cleaned it first time, it's making this static noice and it get really loud at times that it makes hard to sleep. What can we do?
Water or debris in the collection blades or wires can cause a snapping or arcing noise. Water should have dried after a day or so. Look for a hair or lint that is between the blades and wires. Ionic also suggests that the noise may be from misalignment of the blades after cleaning. They suggest removing and replacing the blades to reset the position.
http://www.ionicproturbo.com/images/IP_TurboPro_Manual.pdf
Good luck from Detroit.
Mar 02, 2011 | Vacuums
Is it possible to download a manual for my recently purchased used Shark Intelli-Sew Europro Model 9110 sewing machine? Thanks in advance for any help you can give me... Kitty...
You could download the same from :-
http://www.sharkclean.com/manual/9110_REV_0104E.pdf
You need to have acrobat reader to view the file.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 08, 2010 | Vacuums
Need a user's manual for bissell pet hair eraser vacumn model 3920
You can get the manual on the link below.
http://img.meijer.com/assets/product_files/pdf/1001371_3920_manual.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 13, 2010 | Vacuums
Vacuums Logo
1,624 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
