Question about Acer Aspire One Netbook
My battery is not working - Acer Aspire One Netbook
  • 188 Answers
To fix this problem please follow the links below
http://alturl.com/zvnbe
http://findtechhelp12.blogspot.com/
Thank you
Posted on Mar 26, 2011
Got new batteries but chRger won't charge them
Battery CHARGERS must have the correct batteries (NiCd or NiMH), plugged into a working outlet, and the batteries much be in a specific position. IF 2 batteries are in a 4 battery charger, and they are both in the center, It won't work. If 2 batteries in a 4 battery charger on the left, it will work if they are both securely positioned.
Once in awhile you get a non-working charger. Make sure you have the right charger with batteries. A few have a switch for NiCd or NIMH.
Jun 03, 2016 | Golf
Toshiba satellite c655-s5132 the laptop, charger and battery work well, but did not charge the battery
If they all work well, then the battery would charge. The most likely fault is with the battery. Try to run the laptop without the battery. If it works then replace the battery.
May 27, 2013 | Computers & Internet
What'My laptop works fine when I have just the battery but when I plug it in it does not work even without the battery. Could it be the Adapter cause all my outlets work and so does the battery.s
if the charger cannot charging is the problem,then you need to repair the Battery management software,because you say that the battery is working,then the error should be on the software,that it doesn't indicate that the battery is charging,first go to Device Manager (Right click My Computer,select Properties,click Hardware,click Device Manager) by type "Device" on the start menu and select Device Manager
Expand the Battery categories and right click on Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
On the Device Manager taskbar, click Scan for hardware changes .
Aug 26, 2012 | Compaq Presario CQ50-215NR Notebook
I have this model and the outdoor temp sensor isnt working, and yes both modules have brand new batteries in them. what should i do to get the outdoor temp sensor to work.
My outside display stopped working, but the inside display still worked. I found that one of the two batteries in the inside unit was almost all the way dead. Once I replaced both batteries the outside display worked. I also checked the batteries in the outside unit. After all batteries were installed, I pushed the small button that is inside the battery compartment on the outdoor unit. It's now working perfect..
Oct 10, 2010 | Acu-Rite Acurite Wireless Weather...
My dell vostro 1000 laptop's display aint working. The screen remains black. Even the battery light doesnt glows. Only the power light comes on. Please help.
hi,
try these two things if both don't work you should call dell tech support
1) take out the battery and the ac adapter and then push and hold down the power button for 15 seconds, this releases flea power in the laptop and makes it work sometimes
if it didn't work
2) take out the battery and put in the AC adapter and try to start your laptop on AC adapter alone, if it starts that means either your battery or *********** board is bad, you can check if the battery is bad by replacing it with a new battery and if it works with new battery that means the old battery was bad but if it only works without battery with ac adapter and new battery also didn't work, that means motherboard is bad, Call dell tech support
If you think the info given by me was helpfull please do rate me
Regards
Ltoso
Jul 07, 2009 | Computers & Internet
Watch new battery installed still wont work
First you have to check if the battery is on full power, as sometimes even brand new batteries are underpowered. Good battery should have 1.54 - 1.57 Volts of charge.
If battery is ok and watch still not working - get the battery out and clean (scrape) all battery related contacts with steel needle untill they are shiny. Use the dust blower to get rid of cmall dirt particles.
Replace the battery. Now the watch should work.
If the watch doesn't work after cleaning contacts, then this is mechanical fault and you will need watchmakers help.
Do not forget to rate, please.
Feb 03, 2009 | Bulova Watch
Acer 1641 laptop keyboard doesnt work
we removed the battery and used only the AC. all works fine.
Nov 26, 2008 | Acer Aspire 1642WLMi Notebook
BATTERIE
There is no setting to change, Thinkpad batteries work and charge automatically.
If the battery does not work, either the battery is faulty, or there is a fault in the battery charger contacts , inside the battery slot.
the most likely is a defective battery.
Go back to the shop and ask to test the battery on a different thinkpad, if battery works, then there is a bad contact in laptop battery slot. If it doesn't, then the seller must replace the battery.
Sep 29, 2008 | IBM ThinkPad T20 2647 Notebook
Doesn't work on battery - battery is at 100%
the battery terminal has to be worked on or serviced
Jun 01, 2008 | Compaq Armada M700 Notebook
Compaq Presario v2000 having problems powering on
hi!
i'd say first try a known working ac adapter and if that Working AC adapter works and the system detects the battery well, then it could be the ac. If not then try to borrow a working battery to get your final conclusion. if the working battery still doesnt work properly, then it could be the system motherboard. If battery and ac adapter (working) are not available, then check the BIOS and see if it really doesnt detect the battery. try flashing the BIOS and still if that fails, then replace the battery.
hope this helps!
Regards,
Karlox
Jan 23, 2008 | HP Compaq Presario V2000 Notebook
Acer Aspire One Netbook Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
