Question about Magellan Roadmate 1200 Car GPS Receiver
Will not hold battery charge - Magellan Roadmate 1200 Car GPS Receiver
  • 6,771 Answers
If the battery is one to three years old, chances are it will need to be replaced, the fact it will not hold a charge is a sign the rechargeable battery needs to be changed.
Posted on Mar 26, 2011
Why will my ellipsis 7 no longer hold a charge ?
All rechargeable batteries will eventually fail to take and/or hold a charge. In some cases it is due to being worn out, in others it is due to what is called "battery memory". Battery Memory occurs when a battery is charged often, but is not allowed to fully discharge between chargings. It was really bad with the old Ni-Cad type batteries, but all batteries can have some affects.
Oct 01, 2016 | Tablets & eReaders
WHY isn't MY TOMTOM CHARGING? It's BEEN PLUGged IN FOR 45 MINS.
Usually an old (or older) battery will no longer hold a charge ... or will only hold a small charge (that will let you run the GPS for only a few minutes).
Often, when the TomTom device is always connected to the charger (in a vehicle), where it charges every time the car is turned on, whether the TomTom is being used or not, the battery gets charged (partially or fully) often enough to use up the "maximum number of charge" cycles for the battery. Hence, it will no longer charge properly or hold a strong charge.
Like for all lithium batteries, it's better if your device is not always connected and being charged (whether you are or are not using it). The battery will last longer and it will still be able to hold a stronger charge.
Feb 24, 2016 | Tomtom GPS
Motorola radius cp200 will not hold a charge
when charging a new battery for the FIRST time, most require a full 24 hours to be properly charged. Failing to do this will drastically diminish the life of the battery. If you did fully charge the battery the first time, another issue is recharging after EVERY use vs charging when completely drained. Battery will develop memory (although the manf. will say other wise). If you charge after every use and have only used a third of the charge, after a few time of doing this, you will notice that the battery will not last as long. Try one more battery in just one raido. Fully charge it the first time and only recharge when COMPLETLY drained. If the battery is still not holding a charge, it is most likly a short in the radio itself. Return it.
Jan 07, 2014 | Radio Communications
My old 611 dosent hold the battery charge for long even though I have put in a new battery
An in car charger will not charge as well as the mains, when charging for the first time you should use the mains, and charge for at least 8 hours. If it didn't charge correctly, it will be the same low charge all the time, as the battery has a memory that makes it charge the same each time. Try charging from the mains, you might be lucky.
May 22, 2012 | Cell Phones
The bike dies, after a fully charged battery.
Bike has magneito (thats spelled wrong ) On line youtube veido shows how to fix that.
Apr 01, 2012 | MBK Motorcycles
My garden tractor is not holding it's battery charge. I replaced the battery, but still doesn't hold a charge after I use it.
If you replaced the battery with a new one and it is not holding a charge, then your charging system is not putting out enough power to run the mower AND recharge the battery. So you need to figure what is wrong in the charging system.
Mar 26, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have a Ryobi 18v drill with battery 130429002 that will not hold a charge. Expensive battery with very little use. Can you help?
If both batteries won't hold a charge the problem may be the charger (not providing a full charge). If one battery is OK and one not holding a charge, the problem is probably a defect with the battery. I know there expensive, (I recently had to replace one for DeWalt).
Aug 18, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Does not hold battery charge
Since you have a new phone and a new battery and is still doesn't work ... the first step should be to take it back to where you got it ... have then evaluate it for possible replacement.
May 16, 2010 | LG Shine KE970 Cellular Phone
My sanyo pm 8200 wont hold charge!
Since the battery and charger are new and yet it does not still hold charge.
Have put the battery in another similar phone and try to charge with your charger to see if it will hold charge? if you have.
It means the charging port of your phone is bad and you will need to replace it.
The charger is not charging the battery in anyway because the charging port is bad, so just change your charging port, your phone will now hold charge.
Take care.
Apr 14, 2010 | Sanyo PM-8200
IRiver H340 new battery won't hold a charge!!
It can be the charger that is actually causing your battery to not hold a charge. The closest thing to you would be www.iriverstore.com. connie
Jul 09, 2007 | iRiver H340 MP3 Player
Magellan Roadmate 1200 Car GPS Receiver Logo
101 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
