With AC plugged in with the charger, sony vaio pcg-frv27 laptop powers goes off and shuts down
    Guru:
  • 433 Answers
Battery is bad
Posted on Mar 26, 2011
Sony vaio PCG-7142L keeps freezing
Can check if the battery is low ... or is not (or cannot) holding a good charge ... when you unplug it (from the charger) ... when this happens ?
If that is the case, it may "freeze" while it is busy trying to store the contents of your memory before it shuts down (or hibernates). Does it shut down (or goes into hibernate if you let it continue to "freeze") for a while ? If so, then it's your battery.
If the battery doesn't hold a good charge, the laptop will run only a short time (while unplugged) before it has to shut down due to low battery. And if this is the case, consider getting a replacement (new) battery. And follow the initial charging instructions (for a new battery) to lengthen the life of the battery.
Apr 03, 2014 | Sony VAIO Computers & Internet
Cooling fan stopped working
any 18-20 volt laptop charger should work only need correct power plug and that can be easily changed if necessary with soldering iron and volt meter. using old charger plug as replacement. volt meter is used to check out correct polarity of plug before and after you re solder plug on.generally outside is -ve and center is +ve ,alternatively go to ebay or google and type in Sony Vaio PCG 7Q1M charger,or type in part number ,or try 18-20v laptop charger, that is what I do when I need a replacement charger,cost around $10 delivered usually.
Jan 04, 2014 | Sony Vaio PCG 7Q1M Laptop Universal AC...
Sony vaio model pcg-61611L it turns on for 4 seconds and then it turns off using the ac adapter . help please
The charger may be bad, will it charge the battery? a common problem is the DC jack in the laptop breaks connection on the motherboard internittent operation or no power and shut down. If you can sub the charger that will tell if the power supply is bad or the problem is in the laptop. If the computer is the issue I recommend a professional because it will require extensive parts removal.
Mar 04, 2012 | Sony Vaio PCG-71318L
Sony vaio pcg-frv27 turns off after a while, I'm using ac power with batteries not in it.
Most likely overheating, check if it is getting hot as it shuts off, by hot I mean hard to touch the base.
If it is, you will need to remove the bottom cover and clean out the accumulation of any dust by the heatsink
Mar 26, 2011 | Sony VAIO FRV27 Notebook
Sony vaio pcg-frv27 turns off after a while, I'm using ac power charger with no batteries in it.
problem with the fan. take of the back cover of the laprop and clean the fun
Mar 26, 2011 | Computers & Internet
The battery charger of sony Lptop VAIO PCG-7T1L has become faulty, i m not able to get a support fron sony service center, so how to purchase or get it reapired in Delhi
can just buy a replacement in the link below
http://www.ebuybatteries.com/product/GBProduct.asp?id=973M69&item=Sony+VAIO+PCG-7R2L+PCG-7T1L+PCG-7V1L+ac+adapter+laptop+charger
Feb 26, 2011 | Sony VAIO PCG-7T1L Series Laptop Charger...
SONY VAIO PCG FRV27 I power on the laptop and the screen shows up but its very dark i adjusted contrast but it is not very visible
Diagnosis:
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen
Oct 06, 2010 | Sony VAIO PCG-FRV27 Notebook
I have a Sony Vaio PCG-661L I shut it down and it won't restart
do you get any leds when charger is inserted? if yes, try to remove battery, insert charger and press power on. also, i would recommend you test the output of your charger using a multimeter to rule out the possibility of a faulty charger.
Regards
Jul 23, 2010 | Sony VAIO Notebook
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
