Question about Modems
Kea in need
Have a lexmark x1185 printer can someone help me i have no disk
thank u
kea
  • 298 Answers
Hi!
You can download the driver here. click here. just select the Operating System of your computer.
Posted on Aug 04, 2008
How do I get my printer to communicate with my computer
If you have the software then this is easy. For the setup, plug your printer into your computer and run the software. It will find the printer and prompt you to set it up wirelessly. Go through and answer all of the prompts and it will be complete. At that point you can disconnect the cable and run it wirelessly on your network or Bluetooth.
Aug 25, 2014 | Lexmark Pro 205 Multifunction Printer -...
Printhead error 2
Oh boy,
the last time this happened to me, I lost a rather good HP printer.
I was not able to save it due to the ink drying on important componets.
Sorry I have no constructive info for you, but I do wish you luck.
Mar 11, 2014 | Lexmark S515 Color All-in-One Printer
Bottom page cut off
Hi, can you provide a little more detail as what you mean by bottom page cut off?
Are you saying that the printer is not printing the last part of the page?
Jun 18, 2013 | Lexmarkr Impact S305 Multifunction Printer...
INVALID SCANNER CODE error
You need to download the firmware from support.lexmark.com then send it to the printer either via the network connection or usb. If you are connected by ethernet you can put the devices IP address into internet explorer and send it via the printers built in webpage, you will find an update firmware option there in the configuration menu. To use usb you would need to get the usb flash utility first
Jan 21, 2013 | Lexmarkr X646E Multifunction Printer -...
Printer cannot connect to wireless network
Make sure that you're typing in the correct WEP/WPA password for your network. If you're sure you typed in the correct password, powercycle your router and printer then connect the printer again to your network.
You can also connect the printer using an ethernet cable straight to your router. Your printer will still be shared to your network.
Oct 08, 2012 | Lexmark 90P3000 - Printer Office Edge...
Lexmark 205 copy and scan pages have small gray blocks all over the page
If this is also happening when you're printing from your computer, then it could be a problem with your printhead. Try to update the firmware of your printer. Just go to http://bit.ly/ghfW8H to download the firmware update.
After running the firmware update, perform a maintenance on the cartridges. To do that, on the control panel of your printer, press on Setup > Maintenance > Deep Clean Printhead.
If you still see the same problem and your printer is still under warranty, contact our technical support team to have the printhead replaced.
Aug 05, 2012 | Lexmark Pro 205 Multifunction Printer -...
It keep jamming up on the left side
check in tracks for paper pieces or dust or other small lint that can cause a one side imbalance on a lexmark
May 31, 2012 | Lexmarkr Impact S305 Multifunction Printer...
Computer cannot communicate with printer
Check if your printer is up to date. Just go to http://bit.ly/ghfW8H to download the firmware update.
Also, make sure that you're using genuine Lexmark cartridges. If there's an error message on your screen that your black ink is low even if you replaced it, you won't be able to print or scan. It will send a busy signal or communication not available to your computer. If this is the case, replace the cartridge.
If it still doesn't work work, try to reinstall the software: http://bit.ly/d3ftso
May 11, 2012 | Lexmark 90T9105 - Pro 901 All-in-1
Lexmark z45
use Lexmark Z42 driver included in Vista.
control panel, printer, add printer, virtual usb port, lexmark , z42
work for vista 32 and 64
Jul 06, 2008 | Adtran LIU Quad T1+ Protect T1 (1180109L1)...
Modems Logo
52 people viewed this question
Top Modems Experts
Brian Sullivan
Brian Sullivan
Are you a Modem Expert? Answer questions, earn points and help others
