Maytag washer model mtw5820two will not start in any wash option, will start in the spin cycle of any wash option (delicate, regular, etc)
  • 114 Answers
SOURCE: Maytag PAV1000AWW washing Machine
Your machine has a two speed motor. If the motor hums as it tries to spin in the normal cycle, it could be the motor. If there is no noise, it could be a timer related issue.
Posted on Sep 27, 2007
  • 131 Answers
SOURCE: Whirlpool Washer no spin cylcle
Motor coupler strikes again!
Posted on Apr 01, 2008
SOURCE: maytag washer, lat9606aae only works in delicate cycle and hand washable
My girlfriend's LAT9704 had the EXACT same problem. I replaced the timer module an now it works in all cycles. Part wasn't cheap though - $80
Posted on Apr 09, 2008
  • 18 Answers
SOURCE: Maytag Washer Getting stuckon wash cycle
the possibility of it being the timer is most likely..as the rest of the cycles remain ok.. if you require a timer,you can get one here at this link..(click the link here) http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=HAV4657EWW&mfgModelNum=&fkMfgID=1
please be aware that you will need the machine serial number in order for them to issue you with the correct part/s you will require.. parts are cross referenced with the serial number.
these diagrams will also enlarge in order for you to maintain your machine by yourself at little but the cost of the parts required... but please DO NOT ATTEMPT ANY REPAIR YOURSELF if you think you may not have the technical know how to follow these technical drawings..hope this helps
Posted on Dec 27, 2008
eeevaaa
SOURCE: Maytag washing machine skips rinse cycle
I found this problem with mine intermittently and it was because i had filled the machine too full that it was too heavy to initiate the spin. maybe try a lighter wash?
Posted on Jul 05, 2009
I have a Maytag Performa PAV 2300 Washing Machine. Recently, clothes are still wet after spinning in the delicate cycle. This is not an issue in the Regular cycle. For now, I'm re-spinning the delicates in...
The belt is real easy to replace. Tip the washer back and yank the old belt off.
Loop the new one over the 2 small pulleys and then ease the belt over the large pulley.themobilian_2154.jpg
Important info a manual and more here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 06, 2011 | Washing Machines
Amana washer only works on delicate cycle
Open the control panel. Unplug the timer and then plug it back in good and firm.
If it does not work correctly after that,
Replace your timer.
Mar 12, 2009 | Amana Washing Machines
Maytag Top Loader won't work on Regular Cycle
I suspect bad motor windings. it has enough power to run delicate but not other cycles?
Nov 13, 2008 | Maytag Atlantis MAV6000 Top Load Washer
MAYTAG PREFORMA 2 SPEED 10 CYCLES 2004 TOP LOADER
Check your lid switch, some machines stay running when you add clothes when it agitates, but will shut off if you lift the lid in rinse and spin, lid switch may be broken.
Jul 15, 2008 | Maytag MAH6700AWW Neptune Front-Load...
I have a maytag washer-n-dryer(stacked). When the washing machine is filling in the wash cycle of the delicate or the permanent press cycles, it will not stop filler the drum with water. The washing...
it sounds like your water inlet valve is bad,change it,also try your washer on another water level like small load or med load and see if it cuts off,it might also be your water level switch,hope this helps,thanks-mike
Jun 02, 2008 | Maytag Washing Machines
Maytag washer, lat9606aae only works in delicate cycle and hand washable
Dec 18, 2007 | Washing Machines
Does not spin in most cycles
It sounds like your timer is defective.  If this is the case you will have to replace it.
Oct 17, 2007 | Maytag Performa PAV2200
Washing Machines Logo
95 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
