Question about Dell Inspiron M5030 Laptop
Where is the memory slot located on inspiron m5030 and where can i get instructon on how to replace it and upgrade it.
  • 675 Answers
There may be one located under the keyboard...there should be screws on the bottom that have a keyboard symbol next to them..remove these to remove the keyboard and carefully lift the keyboard to avoid pulling on the ribbon cable
Posted on Mar 26, 2011
Where is the lid sensor on a Dell Inspiron M5030?
1) http://www.parts-people.com/index.php?action=item&id=12015
2) http://www.ebay.ca/itm/Genuine-OEM-DELL-Inspiron-M5030-N5030-Series-Sensor-BD-10630-1-48-4EM19-011-DJ2-/261068854360?pt=LH_DefaultDomain_0&hash=item3cc8ea9458
3) Location;
http://en.wikipedia.org/wiki/Inspiron
Hibernation sensor problem,
http://en.wikipedia.org/wiki/Inspiron#Hibernation_sensor_problem
Dell Support > Inspiron M5030 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/insM5030/en/sm/index.htm
What condition is the Video Cable in? (Dell = Display Cable)
Continuity check with a multimeter prove it to be OK?
Regards,
joecoolvette
[LED backlighting, no screen Inverter used; for those who may think it is a screen Inverter problem ]
Oct 09, 2012 | Dell Inspiron M5030 Laptop
When i turn on dell inspiron m5030 it beep 3 times then go off???
Looks like the motherboard died.
Beep codes from m5030 manual found here: http://support.dell.com/support/edocs/systems/insM5030/en/index.htm
Beep Code Possible Problem:
One - Possible system board failure or BIOS ROM checksum
failure
Two - No RAM detected
NOTE: If you installed or replaced the memory module,
ensure that the memory module is seated properly.
Three - Possible system board failure or Chipset error
Four - RAM read/write failure
Five - Real Time Clock failure
Six - Video card or chip failure
Seven - Processor failure
Eight - Display failure
Jun 25, 2012 | Dell Inspiron M5030 2800B3D 156Inch Laptop
Memory upgrade
According to Dells website, the max RAM is 6 gb for that model.
http://www.dell.com/us/p/inspiron-15-m5030/pd
Jun 05, 2012 | Dell Inspiron M5030 2800B3D 156Inch Laptop
I just upgraded memory and my b130 only reads the A slot
Re-seat the memory modules. If that doesn't work try swapping the modules to see if one is defective. If both modules work in slot A then you have a damaged slot B memory slot and the motherboard needs to be replaced.
Aug 27, 2011 | Dell Inspiron B130 Notebook
I need to find out how to replce the memory sticks on a dell inspiron m5030
you will need to go to the Dell site and enter your model number and the user guide and download it. It should be in PDF format.
this will give you detailed instruction on how to replace and upgrade you laptop.
http://support.dell.com/support/index.aspx?~ck=pn
Jun 13, 2011 | Dell Inspiron M5030 Laptop
Where are the memory slots on a dell xps m140 laptop?
One memory module, ('Stick') slot is located on the bottom of the laptop, in the Memory Compartment. (Has two Philips screws on the cover, and is located close to the battery release button)
The other memory module goes under the keyboard.
Here's how to replace them from Dell Support,
http://support.dell.com/support/edocs/systems/xps140M/en/sm/upgrades.htm#wp999869
Sep 02, 2009 | Dell Inspiron XPS M140 Notebook
Adding memory to my laptop
http://www.ubuntu1501.com/2007/02/upgrading-your-ram-guide.html
Here is a nice visual for you of where the ram is located. ( On bottom- not under keyboard for your model)
Hope this helps :)
Please rate
Apr 12, 2009 | Dell Inspiron 1501 Notebook
Installing Memory
Hi
Yes, you can replace/upgrate the memory module under the keyboard.
Before you proceed, note that Dell Inspiron 2650 uses DDR200 3.3V SODIMM modules. Also, memory module capacities supported are 128MB and 256MB with a Maximum memory of 512MB. If the current memory installed is 128MB, you need to order 2x 256MB modules to replace/upgrade both memory slots. If the installed capacity is 256MB, you just need another 256MB for the slot underneath the laptop.
Check "Removing the Keyboard" for guide removing the keyboard to access the 2nd memory slot.
Read "Preparing to Work Inside the Computer" before committing to the above procedure.
Let me know how you get on.
Mike
May 24, 2008 | Dell Inspiron 2650 Notebook
Memory location Dell inspiron 2200
The memory inside is fixed but there is an open slot . Just open the access panel on the back and the slot is there. You can add up to 1GB
May 02, 2008 | Dell Inspiron 2200 Notebook
Dell Inspiron M5030 Laptop Logo
279 people viewed this question
Alun Cox
