My messages run off right side can't read - Computers & Internet
  • 86 Answers
Change your Screen Resolution to a bigger size.
Posted on Mar 26, 2011
How do I turn the voice command off on text messages
To turn of this setting:
1. From the home screen, press the Voice Commands key on the right side of the phone. The Voice Commands screen appears in the display. 2. Press the right soft key Settings.The following options appear in the display:
• TXT Msg Readout: Reads out the text in a TXT message. (Turn this off)
Jan 04, 2015 | Samsung SCH-U450 Cell Phone
Close section properly
Its not talking about the bypass tray. Its saying the right side door isn't closed. There is a cover above the fuser that may not be closed. Open the right side door and see if you see any broken parts. If everything is closed correctly and not broken, the message will go away.
Jan 24, 2014 | Konica Minolta bizhub C250 All-In-One...
How to delete an email from ipad without opening it
When your listed e-mail is on the left side of IPad mail, place your finger on the right side of the message and drag left and it will expose the "Delete" option. This will delete the message without opening or reading it. See attached graphic.
Jan 18, 2014 | Tablets & eReaders
02 montana abs pump comes on running 55 with no brake applied or abs lite
the problem is front wheel speed sensor. to check witch side .you have to know voltage of speed sensor at 20kmh steady. ex, left side read 800mv right side read 330mv then the right side is defect for example.
Aug 04, 2013 | 2006 Pontiac Montana
I cannot intalled the yahoo messenger 11,the application has failed to start because its side by side configuration is incorrect?
Try running ChkDsk to check your drive for errors. Right-click your Drive icon/ Properties/ Tools/ Error Checking. Try it first by not checking either box (this will run it in a Read-only mode) to see if it flags any hard drive or file problems. If it does, restart it by ticking both boxes, and rerun it to allow it to attempt to fix any found problems.
Let us know.
Thanks.
Nov 08, 2011 | Yahoo Messenger
My yahoo mail is working, i can recieve messages.. But I cannot see it as a whole on my screen. When I click on Inbox, the messages should appear on the right side right??.. But the only thing that i could...
Try to reset the Reading Pane. On the Yahoo Mail header (next to 'Delete', 'Reply', 'Forward', etc.) Click the arrow next to 'View' and fiddle with the settings in there - I think it is "Preview Pane" or "Reading Pane".
Mar 18, 2011 | Yahoo Mail
Wat is an LSU error on a phaser 3200 MFP
Change the toner cartridge , i have many units phaser3200 and this is one of the problem , but only if the toner cartridge is very old and many time refilled , if not , change the Laser unit .
  1. Remove a misfed document if the copier displays a message reading "Document Jam." Lift up the document feeder cover and turn the roller to remove an Exit Misfed document. Lower the document feeder back into place and feed the document through again. If the document is jammed on the Input side, open the cover and gently pull the misfed document to the right and out of the feeder.
  2. Pull out the paper tray and lift the tray to release it from the copier if the copier displays a message reading "Paper Jam O." Remove the jammed document, and open and close the side panel of the copier to clear the error message.
  3. Unplug the power cord and plug it back in again if the copier displays a message reading "Fuser Error, Open Heat Error, Heating Error and Overheat." If the problem persists, call for a service.
  4. Remove the toner cartridge and shake it from side to side if the copier displays a message reading "No Developer Cartridge." If this does not do the trick, you may need to replace the cartridge. Pull the release latch to open the side cover, and open the front cover. Twist the cartridge locking-lever upwards and remove the toner cartridge. Insert the new cartridge and lock the lever into place. Shut the front cover and the side cover.
  5. Power off the unit and power it on again if the copier displays a message reading "LSU Error." A problem has occurred with the Laser Scanning Unit. If the problem persists, call for a service.
Jan 04, 2011 | Xerox Phaser 3200MFP/N Laser Printer
The wii is giving the message "unable to read
  • This message can display if you eject a disc during game play. If this is when the message displayed, make sure that you return to the Wii Menu before changing discs if you wish to play a different game.
  • If your Wii console is laying flat, it may be positioned upside down. Ensure that is positioned right-side up: the game disc slot should be above all three buttons and the SD Card slot.
  • Ensure that you are properly loading a Game Disc.
    • If your console is placed vertically, the disc label will face to the right.
    • If your console is placed horizontally, the disc label will face upwards
Dec 29, 2010 | Nintendo Wii Console
TEXT/CALLS
When you receive a text message while you're talking on the phone you can read your message without getting off by pressing the envelope button on the lower right side of the phone and the message menu with appear then click text messages
Mar 17, 2009 | T-Mobile Dash Smartphone
Computers & Internet Logo
16 people viewed this question
Alun Cox
David Payne
David Payne
