Question about Maytag MHWZ600TK Front Load Washer
It is plugged in it is not running but the door wont open it seems that it is locked
Not a solution, but just wanted to say this seems to be a common problem with this model. Havin the very same problem.
Come on Maytag! Get this taken care of!
Posted on Aug 09, 2011
Open locked door
To open the door when locked. Start new wash cycle and the door will lock - unlock then lock again. when it unlocks open the door quick.
Feb 15, 2015 | Kenmore HE2 Plus Front Load Washer
So I have a 98 volkswagen jetta tdi front doors lock with the fob but the backdoors wont lock they seem to move slightly when u set the alarm and lock it but they remain open because you can just open...
IF YOU HEAR A MOTOR RUNNING WHEN U LOCK THE DOORS THEN THERE IS A DAMAGED DIAPHRAGM AT ONE OF THE DOOR LOCKS TRY THE PETROL LOCK FIRST.THEY ARE THE ONES THAT GET RIPPED!!IF YOUR LOCKS MAKE A SHORT SOUND THEN THEY ARE ELECTRICALLY OPERATED.IF THEY DO SO THEN THE REAR LOCKS NEED TO BE REPLACED!!FOR FURTHER INFO I NEED UR VIN NUMBER!!
Jan 10, 2014 | Cars & Trucks
Lg Washing machine. WD11020D will not open.
door lock sounds like its broken, you will need to remove the two screws on the back of washer top and remove the top. (power off) now as you look at washer from the front you will see a round object with a pipe. remove the pipe and see if the door opens. this is just to check to see if its this part stopping the door to be open, you are going to need to use a flat blade to push the pin in the lock you should see the pin as this stops the door from being open. the part looks like this https://www.ebay.com/i/253266384384?rt=nc if the door is slammed or banged, it can damage the lock, easy to replace when the you can open the door. wiring plug only fits one way.
Dec 06, 2017 | LG WD-1280FHD Front Load Washer
Central locking system
check central locking system fuse it controls all door locks and other acessories.need go to dealership buy remote keys..
Mar 28, 2013 | 2000 Volvo S80
What is the best way to remove the rear pasenger door panel when the door wont open? the door locks and unlocks manually and with the electric lock but the door seems stuck. I do not know if the childe...
The door panel on the inside just has snaps around the front, bottom, and back.
The handles also have to be removed.
Then the panel lifts up.
If the child lock is on, it should still open from the outside.
Try pushing in on the door as you attempt to unlatch it, to relieve any tension.
Feb 13, 2011 | 1995 Honda Passport
Y reg 307 passenger door wont open sounds like all locks are working ane handels seem to be still ok inside and out but door just wont open
typical french car,it has a plastic clip that if someone slams the door it breaks and you need to remove the interior door panel/inner skin(plastic)to get to it (the clips on the door will break off.)the clip runs between the door handle and the operating mechanism.
Jul 27, 2010 | 2005 Peugeot 405
My door handle wont open my door on the drivers side. I have to roll down my window to open the door from the outside latch. Is it repairable, or do I have to replace any parts?
I have shaved door handles on a 2000 chevy silverado and the drivers side door just recently stopped opening it seems like its completely locked out and the door is closed so i cannot get to the bolts of the latch assembly when i hit the unlock button it unlocks half way and when you go to open the door it relocks itself even if you manually try to unlock the door and hold the lock forward it still wont open
Jul 12, 2009 | 1999 Chevrolet Silverado 1500
Driver door wont lock, need help
Probably just needs a good shot of WD 40 or any other lubricant. Spray the catch on the door, and trip it with a screwdriver a few times. If that doesn't work, it may need adjusting or be worn out.
Jun 28, 2009 | 1996 Volkswagen Jetta
Passenger door wont open
Gonna have to try to remove door panel and access the rod that runs from interior handle to lock mechanism, or try to unlock door from outside with a slimjim tool.
Feb 07, 2009 | Hyundai Motor 1999 Tiburon
Maytag MHWZ600TK Front Load Washer Logo
23 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
