Question about Denon AVR-4306 Receiver
On screen display
I have a Denon AVR 4306 receiver and am using an HDMI connection. I am unable to get my on screen display to turn on so that I can access some of the set up/adjustment functions. I have run an s-video cable from the monitor out jack of the receiver to one of the inputs in the back of my Mitsubishi TV with no results. Any ideas??
TAA
Try connecting to the yellow RCA monitor output on the amp and corresponding input on the TV. This works for me. You could also try the composite outputs on the amp. This is one flaw the amp has that the setup screen will not display through the HDMI connection.
Posted on Sep 11, 2008
Sudden "No signal" reveived from Receiver
try another hdmi cable if that doesn't work replace the mainboard in that set
Jan 30, 2013 | Televison & Video
Trying to connect HP M9060N and Sharp Aquos through Denon AVR 1508, only get 'no signal' response. Have HDMI 1 set to DVD, HDMI 2 to AUX, HDMI 3 to TV, which is order of HDMI outlets on receiver.
Depending on your TV inputs, you are better off to run video componenets through TV first then, connect TV to reciever via digital optical. Recievers have video pass through but, noyt the best route. You can use TV's menu to choose what you watch and, only have the one output from TV to reciever. Make sure you scan through TV and reciever menus to make sure you are selecting the right channel.
Jun 21, 2011 | Denon AVR-4306 Receiver
How can i upgrade denon avr 4306 up to 1080p?
You don't need to upgrade that model as it already supports 1080P. If you are using HDMI connections between the receiver your TV the receiver will upconvert the other analog video sources (composite and component video) to 1080 content. Most likely 1080i as this is the standard format when upconverting.
Feb 28, 2011 | Denon AVR-4306 Receiver
Denon AVR-4306 + Motorola DCT-6416 Blanking
Hi Jim,
I tried connecting my dvr via component and optical to see if it was my hdmi or my dvr. Ended up being a bad hdmi plug in back of my amp. I was fortunate enough to have both style connections on my dvr. Hope this helps
Turk
Oct 13, 2009 | Denon AVR-4306 Receiver
Can PS3 go to receiver but not to TV if reciever hooks to TV?
Sounds like you just want audio I would just use the optical audio from the PS to the Denon and assign and input and you;ll have PS video and audio on your tv and just audio at the Denon
Feb 18, 2009 | Denon AVR-4306 Receiver
No component output on AVR-4306
This does not work... You can only upscale the video signal with 4306; meaning you can covert s-video, component video to HDMI but can not down-convert HDMI input (coming from your HD DVD player) to Component video output. Sorry that I could not give you a solution as this is the 4306's limitation (written on the 4306 manual.).
Nov 21, 2008 | Denon AVR-4306 Receiver
Install ps3 on avr-4306
PLUG THE STANDARD PS3 CABLE INTO PS3 THEN TO TV GO TO SET MENU FOR PS3 AND SET VIDEO OUT TO HDMI,PICTURE WILL GO OFF SO BE QUICK AND PUT HDMI CABLE INTO PS3 THEN TV,NOW SET AUDIO OUT PUT TO HDMI,THEN CONNECT TO AMP,IF YOU STILL GET NOTHING CHECK AMP SETTINGS IE INPUT SELECTION FOR HDMI.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Denon AVR-4306 Receiver
Coonecting receiver to computer
If you are using a Windows OS then you will need to go to the speaker icon on the bottom right of your screen and open the menu that allows you to select the line in input. Good luck.
Apr 12, 2007 | Denon AVR-4306 Receiver
Denon AVR 4306 receiver not connecting up 1080p with playstation 3
HELLO, I DID A LITTLE RESEARCH FOR YOU AND FOUND IN YOUR MANUAL ON PG 103 IT STATES "RES OF 1080P ARE NOT HANDLED"
Jan 21, 2007 | Denon AVR-4306 Receiver
Open Questions:
See all Denon AVR-4306 Receiver Questions
Denon AVR-4306 Receiver Logo
418 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
