Question about Magix Audio Cleaning Lab 2005 for PC
Magix Audio Cleaning Lab 12
When I am recording LP's and cassettes I am getting what sound like sampling errors during track sections with low levels. Tracks with high levels sound OK but soft tracks seem to have 'holes' where the sound sinks down and then clips coming back in. Quite an unsatisfactory sounding result. This problem is evident on the Master project file. I have tried different sampling rates when recording and also different 'cleaning' effects with no success. Any suggestions?
  • 105 Answers
You certainly let the microphone or audio out volume during recording.
when you record from external source it is better to cut the volume master volume unchecking it in
the window mixer .
when no sound it amplifies itselfs and do a "larcene" I do not know how you spell it in english.
a mini effect like a micro doing that horrible noise when .. I thing you know what I mean.. :)
if not this, its a rca problem of quality of the cables, or the cables pass close to an adapter,
I've got this problem 'cos I have 2 mixtables chained and the cable was passing over the power
supply of one of my cpu.
Posted on Nov 22, 2008
6ya staff
SOURCE:
Problem operating Magix Audio Cleaning Lab MX
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
Hope it helps.
Nov 30, 2012 | Magix Audio Cleaning Lab Mx Magix
I HAVE LOST OR MISPLACED MY MANUAL. WHERE CAN I DOWNLOAD A MANUAL FOR MAGIX AUDIO CLEANING LAB 17 deluxe?
Here is a video guide http://www.magix.com/gb/au/audio-cleaning-lab/detail/tutorials/ You can also contact customer support.
Feb 28, 2011 | Magix Audio Cleaning Lab 12 Full Version...
How to record LP records to CD, using a 1978
All you need to do is connect two RCA plugs into the audio in of your laptop. The two RCA's go into a tape out of the recevier. If your laptop uses 3.5mm plugs for audio conections then get a 3.5mm plug to RCA plugs. See image below.
To record the music and convert it I would get Magix Audio Cleaning Lab, which you can pick up cheap on Amazon.
418f330.jpg The sound will then come out of your speakers on your computer and then you can record it with Magix and convert it with the software to any audio format.
Jun 18, 2010 | Bang and Olufsen Beosound 2000 Shelf...
Magix recording speeds up sometimes
you've hit the nail on the head mate.
It's your driver settings,you just need to change them.
but first i need you to check something,coz when you install MAGIX it also installs it's own AOSIO drivers & VST-DX Adapter Light.
but because you've up graded/dated windows these mite have changed,moved or even gone.
so open magix music editor 2.0 from the program files / magix then open a new project,click on the red OPT record button then choose your settings.
what are your options in the RECORD DEVICE AND FILE PATH drop down? let me known @
[email protected]
Aug 13, 2009 | Magix Audio Cleaning Lab 2005 for PC
No Volume - records a flat line
Can you hear any other sounds on your computer? If so, make sure your recording properties are set to the device name that is producing the sounds you want to record.
On my computer, this is called "stereo mix". To get to the recording control:
1) Double-click on the speaker icon next to the time on the very right of your task bar.
2) Click on properties
3) Then, click on the options menu item.
4) Next, click on the radio button next to record.
5) Select all the check-boxes
6) Click OK
At this point, if you aren't sure which device produces the sound that needs to be recorded, you can select one at a time until it works. There shouldn't be any more than 5 or 6 devices to choose from.
I hope this helps.
Aug 11, 2009 | Magix Entertainment Audio Cleaning Lab 11...
Serial Number on Magix Music Maker
hey, here is the best solution for you. if you want to download magix audio cleaning lab 12 with serial no check out the following links
MAGIX AUDIO CLEANING 12 PART-01
MAGIX AUDIO CLEANING 12 PART-02
or if you want to download MAGIX Music Maker 14 Producer Edition with serial, please check out the following link
MAGIX MUSIC MAKER PART-01
MAGIX MUSIC MAKER PART-02
Jan 13, 2009 | Magix Audio Cleaning Lab 2005 for PC
Not enough volume to record on my audio cleaning lab deluxe 2004
Try using a mic input. There should be on the mixer control a 10 decible button to use. This will increase the volume of your recording.
Jul 26, 2008 | Magix Entertainment Audio Cleaning Lab 11...
Audio cassette to mp3
Try Magix Audio cleaning Lab. I have version 12 it has presets that will clean the sound up and make it sound better. Once done you can save it to all manor of formats.
I got mine on Amazon.
May 24, 2008 | Magix Audio Cleaning Lab 2005 for PC
Magix Audio Cleaning Lab 2005 for PC Logo
110 people viewed this question
Top Magix Computers & Internet Experts
Peter Dragonetti
 Grubhead
Grubhead
Marvin
Marvin
Are you a Magix Computer and Internet Expert? Answer questions, earn points and help others
