Question about Pentax Optio Z10 Digital Camera
My camera is all messed up It's a Pentax Optio Z10. When I turn it on it is stuck in "Green Mode" then after a few seconds, turns off. If I press the "Playback" button it will come on and I can review pictures, but can't take new ones. When I close the slider the power stays on. I have to remove battery to shut it down. Looks like lots of other people have had this problem but I haven't seen one good solution . Please help
  • 2 more comments
  • techtradermi Mar 26, 2011
    Really? All these people have had this same issue and there isn't a better solution than "Buy a new camera?" It's only a year old!
    Isn't there another solution? So many people have had this problem and the camera is only a year old
    Nothing else I can do? So many people have had this problem
    Pentax Optio Z10 stuck in "green mode" then turns off after a few seconds. If I press and hold the playback button, it will come on and I can look at my old pictures but can't do anything else. Then when I turn it off the power stays on. Is there ANYTHING I can do other than buy a new camera?
  • 668 Answers
The problem you describe indicates that inner switch mechanism is broken that's why the camera turns off. You need to replace the inner switch so it will work properly. You need to take to near by the service center to get it repaired. It will cost you around $20-30 to replace the switch.
Hope this helps.
Shane
Posted on Mar 26, 2011
  • 10,319 Answers
Capacitors are embedded in the circuits of these cameras which hold needed additional power to operate. When a capacitor gets weak the camera will offer these odd operations such as yours here. Repair cost usually outweighs the cost of a replacement camera these days
How do i remove green mode on a camera pentax RS1000
Pentax Optio RS1000 Digital Camera Green - Questions ...
www.fixya.com > ... > Optio > Pentax Optio RS1000 Digital Camera
turn green mode off my camera how to turn offf green mode just hit the green button, its the delete pic button as well, but it can be used to turn green mode on ...
Oct 27, 2015 | Pentax Cameras
What is pentax optio z10 reset button
The reset is on the settings menu, it does not have a reset button.
To get to the settings menu press the menu button then press the right button on the controller to get to the setting menu.
When you are on the setting menu you need to go down using the down arrow on the controller to the 3rd page were the reset option is.
Press right to access the reset options then select Reset then ok.
Jan 29, 2010 | Pentax Optio Z10 Digital Camera
Me kids have played with my camera and set the green mode.if i push the menu button it tells me that the green mode needs to be canceled touse this function
You may need to look up how to reset your camera to factory settings. Look that up in the manual. You will not loose any pictures.
Hope this helps.
Jan 05, 2010 | Pentax Optio Z10 Digital Camera
Optio Z10 is stuck on green mode, how do i fix it?
Go into the menu and find "reset"...follow the on-screen instructions.
Dec 10, 2009 | Pentax Optio Z10 Digital Camera
Green Mode stuck on
remove the batteries and the memory/SD card. replace the batteries first. power up the camera (this will help save your pics from possible deletion). If you can get to the menu of your camera, here is where you'll find the 'green mode'. check the settings. if its on, turn it off. after saving, reload your SD card and try to take another picture.
Aug 24, 2009 | Pentax Optio M10 Digital Camera
Pentax Optio M20 in Green Mode switches off after turning on
Try to press & hold down the Green button (the trash can button on the bottom right corner) & see if it gets u out of green mode.
Jul 27, 2009 | Pentax Optio M20 Digital Camera
Pentax Z10 won't turn on.
Press and hold the playback button for 2 seconds. The camera should turn on and be in playback mode. Switch to Camera Mode by opening the from slider cover. Hope that fixes it. See Pentax Z10 Manual Page 34.
http://www.pentaximaging.com/files/manual/OptioZ10.pdf
Cheers Jon. Sydney Australia.
Jun 10, 2009 | Pentax Optio Z10 Digital Camera
I have a pentax optio z10. when i turn it on (slide the front open) it says "green mode" then proceeds to turn blank..
i got the same problem. try holding the play button and turning on. it wont help fully, but i was able to look at my already takin pics
Jan 13, 2009 | Pentax Optio Z10 Digital Camera
Pentax M20 Green Mode Stuck
i just had the same problem....
here's how i fixed it...
turn it on... then as it's loading up... hold the "menu" button
i think this forces it to stay on...
i changed the green button to be something else... not green mode
then i just turned it off and on again
Aug 20, 2007 | Pentax Optio M20 Digital Camera
Pentax Optio Z10 Digital Camera Logo
88 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
