Question about Maytag Neptune FAV6800AW Top Load Washer
Our Neptune Washer won't start up. It shows a Code (ol). What does this mean? We;ve tried unplugging & and Re-loading it. Still OL code.
  • 335 Answers
From the FAV6800A/FAV9800A Service Manual page 14 that error code = oL Machine Paused-Load Wedging
Google this "16022808 Revision 0 December 2003" to find the Service Manual if you are going to DIY the fix.
Posted on Mar 26, 2011
When machine goes into final spin cycle it gives me a OL code
OL means the washer is overloaded or there is excessive drive load. Go to the link for a full explanation of the OL code and its repair. What might be causing the OL error code on my Whirlpool Cabrio washer...
Oct 12, 2016 | Whirlpool Washing Machines
Getting oL code even after diagnostic check
OL, usually means Over Loaded. It is an error code thrown up by the on board computericon1.png.. generally when TOO much wet weight is in the bowl.
This condition is could be caused by faulty solenoid or solenoids at the water inlet valve. Unplug the machine, turn off the water, and remove the supply hoses. Check the solenoids at the water inlet valve. They can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity will indicate a faulty solenoid and the inlet valve assy will need to be replaced.
Try unplugging for 12 hrs before reconnecting
If the problem continues then the controller board is damaged and will need to be replaced.
Jan 13, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
OL error code
Hi jbrundage1. I believe you have a UL error code on the washer. It means that the sensors in the washer are sensing the unit is unbalanced. When the washer is empty, set it to a spin or rinse and spin setting. Run the washer through the cycle empty, as it will help to remove any excess water in the tub. Also, make sure the washer is level, as it is balanced on springs, and that could be throwing the sensors off. I hope these suggestions prove helpful. Sincerely, Melanie, Maytag Social Media Representative.
Jun 03, 2012 | Maytag Bravos MTW6600T Top Load Washer
The washer stops half way through all cycles and displays "oL" .
Error oL means overload.
If the "oL" error code appears, the washer has been filled with a load that is too large for its capacity, causing it to drain.
*Remove some items from the washer and add more detergent since the previous amount will have drained with the water.
*Close the washer and press the START/PAUSE/Cancel button to remove error displayed and restart the cycle.
If Pause/Cancel does not work:
*Unplug washer or disconnect power for one minute.
*Plug in washer or reconnect power.
*Re-select the cycle and press Start.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Hope this helps.. :)
Jun 08, 2011 | Washing Machines
Ol error on oassi elite washer
my washer told ol code ,i know that means over load ,put its told me that even when i put small load
Mar 01, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Code ol
Hi
Error OL means overload. oL flashes when the machine/motor control detects a load size that exceeds the washer's capacity. To clear the error open the door lid and restart the cycle by removing excess laundry. If error doesn't clears then unplug the washer for 5-10 minutes and check. Hope this helps... Please post back if you need more information.
Daniel
Nov 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore washer OASIS errror code OL
OL error means the Motor Controller has sensed an Overload.
The oL code means the motor control board is struggling to power the motor up. If it recurs after removing some clothes - usually this means a new motor control.... or worse - a new bearing.
If it were a problem with the tub floating up, the unit would spin instead of nutate.
Bearing failure in this machine is very common.
I suspect the drive shaft and bearing are the problem. The bearing and shaft are part of the outer tub.
The new outer tub with bearing W10128830 cost approximately $197 dollars.
If you can get access to the shaft it may be an Emory cloth will help smooth things down so that you no longer get the OL code.
This is an ambitious do-it-yourself project... as most appliance repairmen don't understand how this machine operates.
http://media.fotki.com/1_p,srrtbrrfbdbqgkkxgtqsskgwtqkq,vi/bqkfstqqfxrqqbkwgqdxbwsqrwrtq/1/1303472/5961857/image828956817962821589img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 22, 2010 | Kenmore 22422 Top Load Washer
Screen says oL. Kenmore oasis elite he 110.2708,2709
OL, usually means Over Loaded. It is an error code thrown up by the on board computer.. generally when TOO much wet weight is in the bowl.
Jan 29, 2010 | Kenmore Oasis HE 27082 Top Load Washer
When washer spin the machine stop mark the code ol
Sorry I missed the error code oL
oL Machine Paused-Load Wedging….I think that may mean something like the tumblers are jammed up but that’s a guess. I have never seen that error code before. If no one on the forum can help I will give it a try. I need to do some digging in. If I hit a dead end for this error code I will ask on another forum if any Maytag repair folks have knowledge of this error code and it’s cause. We could do some basic troubleshooting if you want to try. If you recycle power on the machine will the machine run a normal cycle?
If you want to dig in and troubleshoot the issue I will try to help. See my last post of how to get into Service Mode. I would suggest reading the Diag codes and see what the machine has logged with past error codes.
Here are links for the Service Manual and parts look up. FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Waiting to hear back from you….Rich
Dec 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
298 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
