Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
My machine is flashing h20 and wont start why
Hi my machine is flashing h20 what does it mean
Posted on Apr 02, 2011
My Indesit 7105 has flashing H20 lights, have checked but no blockages. It fills and drains fine, It wont agitate though, any ideas?
The machine does not fill with water or 'H20' flashes in the display.
The water inlet hose is kinked. • The water inlet hose is not connected to the water supply. • The water pressure is too low. • The water tap has not been turned on to allow water to flow into the machine. • There is no water supply to the house. • The inlet valve filter is blocked. • The START/PAUSE button has not been pressed.
Faulty pressure switch machine thinks there is no water in the machine.
Apr 01, 2017 | Indesit Washing Machines
My washing machine flashes H20
Try to put some hot water and drain it(not too hot)
Apr 08, 2014 | Hotpoint Ultima WF860 Front Load Washer
What is code H20 on hotpoint washing machine
Check to make sure that the water valves are open and water is getting to the machine.
May 29, 2012 | Hotpoint Washing Machines
Hi i got hotpoint ultima igot flashing h20 on screen
These are the notes I have-
Providing it is not in demo mode, H20 means 'no water is being supplied'.
Press and hold 'start/cancel', release then press again to cancel the drain. The machine should now be reset.
If H20 returns there is a problem with the water supply- the hoses are kinked or squashed, the taps are not turned on fully or the water inlet valve is malfunctioning, apparently!
Good luck,
John C
Mar 11, 2011 | Hotpoint Ultima WF860 Front Load Washer
Display periodically flashes H20
The faulot is related to the incoming water supply.
Chaek inlet hose for restriction or low water pressure.
Jan 19, 2010 | Washing Machines
Set wash program ,wont start ,there is a tap on display plus it flashes up H2O
H20 means a water inlet problem.
Check the inlet pipe/s are not restricted or kinked.
Ensure that the pressure is adequate.
This cold weather has caused some washer hoses to freeze up.
Hope this helps.
Jan 08, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpiont wf860 flashing fault code H20, please help
h20 code indicates that the appliance is not filling at all or filling to slow,check pipes are not kinked and taps are open correctly
Jun 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
Flashing H20
h20 means no water is getting to the machine. check your washing machine taps are on and water getting to the machine and the fill hose is not kinked.
Jan 26, 2009 | Washing Machines
Hotpoint aquarious + flashing H 20 on display
H20 is indicating that you have no water coming in.
Check water is turned on,check hose(s) are not kinked, and finally check inlet valve.
If you are not sure if there is water to m/c, turn the tap off, disconnect the hose(s), and hold over sink and turn tap back on, water should come out, if it does not, then there is a prob with the supply.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
218 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
